Доброго дня.
помогите пожалуйста разобраться. по поводу стирания(полного или хотя бы частично) программ и информации в генах и крови человека– которые идут от предков по маминой и папиной линии а также то что лично" мое "так сказать .
а также по внесению в свою кровь и гены-программ любых новых-чтобы они работали полностью( или насколько это возможно) в нашей реальности.
интересуют любые эффективные методики. надеюсь на помощь).
вопрос про очищение и программирование крови человека
Борис Ткаченко
- Христос
Isolation of large numbers of human peripheral blood CD34+ cells could lead to therapeutic applications, including purging of malignant cells from blood cell transplantations, purging of T cells from allogeneic bone marrow, and even blood cell transplantation. This procedure has limitations if there are not sufficient numbers of progenitor cells in the leukapheresis concentrates available for selection after detection of tumor cells in apheresis products. Use of frozen/thawed peripheral blood mononuclear cell (PBMC) samples would make feasible pooling of two or even more stem cell harvests collected at different time points and the total number of CD34+ progenitor cells available would increase. We established an efficient method for purification of CD34+ cells from cryopreserved apheresis products, using a nylon-fiber syringe system and immunomagnetic microspheres. We compared purity, recovery rate and clonogenicity of CD34+ cells purified from fresh (n = 22) and cryopreserved apheresis products (n = 14), using a nylon-fiber syringe system and immunomagnetic microspheres. The purity of CD34+ cells from cryopreserved products was less than that from fresh products (85.9 ± 14.4% vs 94.6 ± 10.0%), but the recovery rate of CD34+ cells and colony-forming cells was comparable between fresh and cryopreserved products. One patient underwent grafting with peripheral blood CD34+ cells selected after freezing, with good success. Therefore, these cells are capable of rapidly reconstituting hematopoiesis after high-dose chemotherapy
Препарат иммунопротектор
"Амрита"
Описание препарата
Препарат обладает следующими действиями: противоопухолевое; противовоспалительное, бактерицидное, иммунностимулирующее, ранозаживляющее, противопаразитарное, болеутоляющее, антиоксидантное; общеукрепляющее средство, повышающее жизненный тонус организма. Применяется для лечения злокачественных и доброкачественных опухолей, болезней желудочно-кишечного тракта и кроветворной системы. Отличное профилактическое средство при простудных и инфекционных заболеваниях. Ускоряет выздоровление, восстанавливает иммунный статус организма от состояния полного угнетения до нормы в рекордно короткие сроки за 24 дня.
Краткая характеристика препарата.
Состав: Препарат "Амрита" представляет собой жидкость опалесцирующего цвета с характерным запахом. Наличие запаха объясняется использованием в качестве компонента растворителя фракции белой нефти. Препарат природного происхождения, содержит в определенных пропорциях вытяжки из биологически-активных растений Уссурийской тайги (основной компонент - манчжурский орех), дефицитные аминокислоты, эфирные масла, органические кислоты, ненасыщенные жирные кислоты, дубильные вещества, витамины и биологически активные вещества.
Свойства: "Амрита" содержит высокоактивные вещества, стимулирующие кроветворную функцию костного мозга. Под влиянием препарата происходит быстротекущая "ревизия" состояния кровяных телец: активно вырабатываются клетки-киллеры, которые убирают из организма неполноценные, поврежденные и ослабленные эритроциты и лейкоциты; одновременно на смену костный мозг производит работоспособные, жизненно-активные новые клетки. "Амрита" метит взбунтовавшиеся клетки, образующие опухоли, они перестают быть "своими", подвергаются атаке фагоцитов и постепенно погибают. "Амрита" обладает ярко выраженным интерферонным действием, что позволяет применять его как прекрасное профилактическое средство при эпидемиях гриппа. Являясь активным иммунопротектором, "Амрита" тем не менее, не способствует резкому повышению артериального давления. Регулярный прием "Амриты" позволяет нормализовать артериальное давление у гипотоников и гипертоников до присущей организму нормы за счет приведения в идеальное состояние иммунной системы организма.
Показания: анемия; вегетососудистая дистония; недостаточность кровообращения (отеки); артериальная гипертензия (гипертония); гипотония; гриппозные состояния; ангина; токсоплазмоз; токсикоз в состоянии беременности; дисбактериоз кишечника; диарея; язвенные болезни желудка и 12-перстной кишки; дизентерия; сальмонеллез; отмечен положительный эффект при злокачественных опухолях различной этиологии; онкологические поражения молочной железы у женщин детородного возраста рассасываются полностью в 90 случаях из 100, суставные боли, артриты и радикулиты, а также такие болезни, как склероз, простатит, пиелонефрит, гипертония, тромбофлебит, ишемия, бесплодие, цирроз печени, мастопатия, кольпит, герпес, миома, фиброма, воспаление лимфатических узлов, диабет, опухоли головного мозга, зоб.
Неоспорим профилактический эффект "Амриты" - профилактический прием исключает появление опухолевых новообразований, делает организм невосприимчивым к различным вирусным заболеваниям.
Противопоказания: Аллергия на йодсодержащие препараты. Запрещается принимать препарат при прохождении курсов лучевой- или химиотерапии.
Препарат "Амрита" - гарантия Вашего здоровья и долголетия!
Применение препарата
Наружное применение (в виде примочек и втирании, компрессов): компресс снимается после обжигающего ощущения во избежание ожога кожи. Его повторяют через день. Втирать можно по 2-3 раза в день. Примочка прикладывается на раны, язвы, опухоли, кровоподтеки и целые участки кожи. Обычно салфетку с лекарством не снимают с раны, а подмачивают, чтобы не повредить кожную ткань при заживлении.
При втирании лекарства в кожу головы с легким массажем прекращается выпадение волос. Процедуру надо повторять через день по необходимости.
Исчезают любой насморк и полипы при смачивании или закапывании лекарства в нос по 2 раза в день в течение двух дней. Гайморит и фронтиты проходят при 2-3 кратном смазывании скул и лба с легким массажем в течение 3-5 дней.
Кожа лица очищается от угрей, прыщей, порезов, кровоподтеков, синяков при трехразовом ежедневном втирании лекарства за 2-3 дня.
Мышечные боли с судорогами, кожные высыпания и зуд, потливость, грибковые поражения конечностей и другие недуги исцеляются путем втирания примочек или кратковременных компрессов.
Только при кратковременном соприкосновении со слизистой полости рта - полоскании и облизывании языком с последующим глотанием порции лекарства - проходит воспаление губ, десен, языка, глотки и гортани. Гнилостные стоматиты, зубные боли, ларингиты, ангины, фарингиты исчезают за считанные дни.
Последствия ожогов полости рта, языка, глотки, гортани, пищевода и желудка от горячей пищи и других сильных раздражителей проходят быстрее, мягче и легче, чем после приема иных лекарств, благодаря его маслянистости и ранозаживляющим свойствам.
Применение «Амриты» устраняет процессы нарушения пищеварения, налаживает перистальтику, избавляет от запоров. Начальные признаки геморроя с кровотечением, трещины заднего прохода, полипозные и кистозные образования исчезают при регулярном приеме лекарства в течение 10-15 дней.
Наружное применение Амриты лечит полиартрит, артрит, артроз, варикоз, предотвращает образование тромбофлебита. "Амрите" по силам одолеть суставные боли и радикулиты, а также такие болезни, как склероз, простатит, пиелонефрит, гипертония, тромбофлебит, ишемия, бесплодие, цирроз печени, мастопатия, кольпит, герпес, миома, фиброма, воспаление лимфатических узлов, диабет, опухоли головного мозга, зоб, шизофрения и даже рак. Не говоря уже о том, что быстро исчезают насморк, гайморит, фронтит и полипы в носу, если закапать в нос смесь в равных пропорциях растительного масла и "Амриты". Кожа очищается от угрей, прыщей, синяков, грибковых поражений, экземы, нейродермита, псориаза, труднозаживающих ран и язв, застарелых швов, если смазывать экстрактом "Амриты".
Помимо этого "Амрита" способна помочь в предотвращении сердечных приступов, в том числе и таких грозных, как инфаркт. Прием "Амриты" дополнительно к назначенному курсу лечения значительно снижает вероятность сердечного приступа. Кроме того прием препарата позволяет нормализовать состояние печени. При внутреннем и даже наружном применении "Амрита" значительно укрепляет стенки сосудов, предотвращая кровоизлияния.
«Амрита» НЕ ПАНАЦЕЯ, но препарат многопланового действия совместимый с любыми другими лекарственными средствами, кроме лучевой и химиотерапии.
"Амрита"
Описание препарата
Использую Амриту только четвертый день. Пока ничего особенного сказать не могу, кроме того, что примерно до после обеда, ощущаю что внутри меня нечто керосиновое. Выше я просто скопировал анотацию, ничего своего не добавляя.
Где купить эту Амриту?
Владимир Ком
Карма и кровь
Чёрная кровь
Чёрная кровь, это кровь, в которой находится тёмная субстанция, как результат грехов и чёрной магии (ЧМ) предков по линии крови матери и отца. Интересно, что на тонком плане красная кровь при появлении рядом тёмного человека, она чернеет, и нормальному человеку (не занимающегося чёрной магией) становится плохо. Такие люди постоянно сталкиваются с ЧМ воздействиями, не понимая, почему это с ними происходит.
Можно использовать для диагностики визуализацию и маятник. Визуализация покажет наличие или отсутствие чёрно магической энергии и динамику процесса перехода от красной крови к чёрной крови на тонком плане. А маятник поможет определить процентное соотношение наличия этой ЧМ энергии со стороны рода матери и отца.
Для избавления себя от родовой ЧМ, надо провести медитацию. Представить три Солнца: Белое Солнце, а на противоположной стороне Чёрное Солнце, посередине высоко Нейтральное Солнце, где обитает Отец Абсолют. Пожелайте посмотреть количество ваших родственников-предков, которые выбрали Чёрное Солнце. Определись сами, куда потянется ваша Душа и Души ваших детей. Если есть ЧМ по линии предков, а вы и дети выбрали Белое Солнце, то проведите медитацию.
Мысленно обращайтесь к Нейтральному Солнцу:
-Отец Абсолют! Прошу защитить меня и моих детей от влияния моих родных предков по крови, которые совершали чёрно-магические ритуалы, так как мы выбрали Белое Солнце и отказываемся от магии и колдовства. Прошу помочь очистить мою и кровь моих детей от тёмной субстанции, чтобы не притягивать зло в нашу жизнь.
Из своего сердца направьте луч любви к Нейтральному Солнцу и ожидайте прихода Луча Божественной Любви от Отца Абсолюта.
Результат можно проверить способом визуализации и маятником.
(продолжение следует)
Чёрная кровь
Владимир Ком
Очищение крови от ПСИэнергии
Кровь это прежде всего энергоинформационная среда, которая передаёт её всем внутренним органам организма. Энергия может быть позитивная и негативная, соответственно все органы будут насыщать той или иной энергией. Если в крови много позитивной ПСИэнергии, то человек будет здоров, если много негативной энергии, то естественно он будет болеть. Все эти виды энергии и информации поступают в кровь по линии рода матери и Души. Если много было грехов по этим двум направлениям, то возникают "родовые болезни", передающиеся на протяжении жизни многих поколений. Если имеются негативные накопления Души, то они могут проявляться во времени. Возможно это болезни с самого рождения или они появляются в середине жизни, а может быть в конце, от чего и умирает человек. И в этом переносе энергии и информации кровь играет ключевую роль. В этой среде уже заложены все будущие болезни человека, поэтому, если разработать методику очищения крови от всех видов негативной энергии и информации, то это будет действенной профилактикой.
Предложу следующую методику диагностики и последующее очищение крови организма. Надо в медитации представить прозрачную пробирку, заполненную вашей кровью. Посмотрите, какой у крови цвет, есть ли осадок или взвешенные частицы, имеется ли слоистость крови... При наличии большого количества негативной энергии, цвет крови тёмно-красный, а при её отсутствии цвет ярко-алый. Если кровь тёмная, то как правило это воздействие кода инволюции 666, а для тёмной крови код 6663.
Если вы решили духовно развиваться, не болеть сейчас и в будущем, то надо мысленно написать на пробирке с кровью светящимися цифрами код 9993. Внутренним зрением вновь посмотрите изменения крови и надо добиться цвета крови ярко-алого.
Если и после этого кровь имеет отклонения по цвету, то надо почистить карму своей Души и род по материнской линии, как это объясняется в статье "Письмо здоровья"
Владимир Ком
Примеры работы с кровью
Приведу примеры вида крови у группы людей, которые провели медитацию на вид своей крови, чтобы было понятны причины отклонений вида крови и мой диагноз маятником и объяснение причины:
Елена - в основном красная, но есть голубой осадок.
В.К. - Голубой осадок это гнев и раздражение на кого-то, попросите прощение.
Надежда - два слоя 50 на 50 %: вверху розовый, а внизу - сиреневый.
В.К. - Розовый цвет - доверчивость, а если человек Вас обманул, то доверчивость сменяется растерянностью.
Надежда - действительно, я часто это испытываю в жизни, доверчивая и меня обманывают.
Николай - в целом тёмно-красный цвет, но внутри плавают металлические шарики с шипами.
В.К. - металлические шарики это эгоизм, а шипы это ты любишь уколоть самолюбие человека, попроси прощение у Бога за свой эгоизм.
Н. - В крови плавают белые шарики и хлопья.
В.К. - белый цвет духовной энергии, но она не может раствориться по причине претензий к Богу и Светлым Духовным Силам, что они не помогали в трудные моменты прошлых жизней. Попросите прощение у Бога, что не понимали, какой урок проходите, познание глубин зла, поэтому Светлые Силы на время оставляют Душу человека, а теперь настало время Вам помочь, но надо снять претензию.
После того, как все написали на вооброжаемой пробирке код здоровой крови 9993, то большинство увидели и почувствовали изменения. Кровь стала алая, а разойдясь по организму пришла жизнерадостная энергия. А вот у Надежды кровь стала абсолютно белой.
В.К. - белая кровь это много духовной энергии, но мало земной энергии ИНЬ, поэтому напишите код 444 - энергии Богородицы.
Надежда: - Кровь стала алой, но не очень плотной, может быть ещё чего то не хватает?
В.К. - не хватает ЯНЪ энергий Бога Земли, напишите код 379.
Надежда - теперь кровь стала плотной и алой, спасибо!
Эти примеры работы по очищению своей крови показал, что следует использовать маятник, для диагностики причин отклонений вида крови. Для этого надо использовать диаграмму "вредоносных чувств и эмоций", а потом отмаливать эти ОЭ у Бога-Творца и применять указанные коды.
круто.. читаю и афигеваю... господа,тема данной ветки "машины доктора Райфа" может хорош уже размазывать тему???
