"Голос Бога"
Дмитрый
"Голос Бога"
Сообщение Дмитрый »
"Голос Бога"(Voice To Skull также) так называют устройств которые передают звуковой сигнал направленно прямо голову обькта.Согласитесь что много интересных опытов можно проводить с хожим девайсом.Интересно что смодулированный сигнал проходит через стены и прочие матерялы.Более подробно расмотрим один из таких приборов.
Лучше будет если посмотрим в оригинале а потом если будет интерес переведём))
There are 2 types of voice to skull:
1. The pulsed microwave method: every time the voice wave goes from positive to negative we generate a microwave pulse. For every pulse the brain hears a click. All these clicks are a form of digital audio. This goes through walls.
2. The silent sound method: a steady tone is frequency modulated with a voice wave. The ear hears hissing, but the brain hears a voice. This is a form of analog audio. This doesn’t go through walls.
Then we can combine the 2 methods: we use the output of method 2 as the input of method 1. This goes through walls.
1. Pulsed microwave method
1.1. Radio waves versus microwaves
1.1.1 Radio waves
Radio and TV signals have a smooth wave form that we call sine wave.
Such a signal can’t penetrate a nerve cell. The wall of a nerve cell has a small electric current that stops the signal.
1.1.2 Microwaves
Microwaves are short strong pulses.
Such a signal can penetrate a nerve cell. This was made public in 1962 by Dr Allan Frey from Cornell University in New York.
1.2. Voice conversion to pulses
Dr Joseph Sharp demonstrated microwave voice to skull for the first time in 1973.
Every time the sine wave goes from positive to negative a microwave pulse is generated.
1.3. Microwave voice to skull simulated with a 555 chip tachometer circuit
Eleanor White designed this 555 chip tachometer circuit to simulate Dr Sharp’s microwave voice to skull method. She has built such a device. She has demonstrated it to her collegues to prove that Joseph Sharp’s modulation method, using just clicks, can re-create speech or music reasonably well. It was connected to a normal speaker. In order to produce voices in the head, it has to be connected to a radar.
1.4. Voice to skull speech processor
Eleanor White designed this exact replica of Dr Sharp’s microwave voice to skull method. It was connected to a normal speaker. In order to produce voices in the head, it has to be connected to a radar. It should be redesigned with automatic gain control to keep the volume constant. This design worked with careful adjustment of the input volume level.
Capacitators are in microfarads unless otherwise noted.
Resistors are in Ohm unless otherwise noted (K or meg).
Shaded blocks indicate chip sockets which hold quick-change components.
2. Silent sound method
2.1. Slope detection of the brain
This is the text from patent 5,159,703 for Lowery’s silent subliminal presentation system:
A silent communications system in which nonaural carriers, in the very low or very high audio frequency range or in the adjacent ultrasonic frequency spectrum, are amplitude or frequency modulated with the desired intelligence and propagated acoustically or vibrationally, for inducement into the brain, typically through the use of loudspeakers, earphones or piezoelectric transducers. The modulated carriers may be transmitted directly in real time or may be conveniently recorded and stored on mechanical, magnetic or optical media for delayed or repeated transmission to the listener.
As you can read, it has the ideal ingredients for electronic harassment.
You see also that the patent doesn’t say which frequency is used. This seems to be Lowery’s secret.
Eleanor White believes that the frequency is around 14500 Hz.
2.2. Hypnosis via voice-FM
A voice wave is embedded in a steady tone by means of freqency modulation. In this example a steady tone is stretched where the voice wave has a small amplitude and contracted where the voice wave has a large amplitude.
2.3. Verifying the Lowery signal
A Lowery type silent sound FM signal should appear on an oscilloscope like this:
2.4. Silent sound demo device - "Voice-FM device"
Eleanor White designed this device based on patent 5,159,703. She has built this device. The chip that converts from analog to FM was extremely difficult to get in small quantities. She had to lie and say that she was a commercial circuit designer to get a handful of these chips. She demonstrated this device on the street. It produced voices in the head.
Eleanor White doesn’t treat silent sound as voice to skull.
She believes that silent sound is harmful when coupled to a microwave transmitter like in 3.1.
You can read more about this experiment in the Raven1 book (Reader 6 PDF, 46.4 MB, 5081 pages):
vfmbuild.htm page 4320
vfmdemo.htm page 4324
2.4.1. Top with the schematic
The device is chargeable with a battery of 1.2 AH, 25 ma drain, 48 hours per charge in theory.
If you want to use an ear phone then you have to use an attenuator (signal reducer).
Left is the input jack for the microphone. Right is the output jack for the tape recorder.
Left vertical black bar = VC.
Right vertical black bar = 3 V.
Q1 is a seperate amp for the speaker only.
The output jack gives a better sine wave at lower voltage level.
R10 = RA = controls sine wave distortion, may be an on-board trimmer.
R19 and R20 are 100R.
IT goes to pin 7 of U7. It has to be limited to less than 3 ma. It controls the carrier frequency as follows:
R22 = R = nominal freq pot + 1K (1M pot + 1K)
R9 = RC = modulation coupling res (1M pot)
VC = modulating V ahead of RC
2.4.2. Bottom with the solder-side layout
This is the bottom side (solder side, wire side). The components are on the opposite side.
http://www.partsexpress.com is the source for Springboro OH, source of piezo tweeters.
Leave the solder hole closest to the mounting screw vacant to provide clearance for the nut.
Small shaded circles between perfs are vertically mounted 1/4 watt resistors.
Output jack on panel, 1/8", mono or stereo, builder’s choice but must match any plug-in device cords.
Use either crimped or soldered push-on connectors for the battery. Don’t solder directly to the battery terminals.
3. Combined method
3.1. Hypnosis via frequency modulation and pulsed-microwave voice to skull
Silent sound goes through walls if you combine it with the microwave method.
Дмитрый
Re: "Голос Бога"
Сообщение Дмитрый »
Интересно реально ли собрть такой "Чудо-Аппарат" ))
Просто Радар будет сложно наёти наверное))
XUPOH
Re: "Голос Бога"
Сообщение XUPOH »
Thanks for the schematic, gonna try building one.
Funny toy indeed.
Брэнд
Re: "Голос Бога"
Сообщение Брэнд »
Дмитрый,
По количеству ошибок понятно, что будет с оригиналом при переводе (принципы аналогии и подобия Гермеса Трисмегиста).
"Голос черепа" - дальше лучше не переводить. Перевод с неправильного увеличивает количество ошибок.
Затыкайте уши. Развод на бабки.
Бессознательность. Сон сознания. Спокойной ночи, черепа и velcom новым зомби.
У каждого свой Бог... или идол-божок. При фанатичности разница не очевидна.
Дмитрый
Re: "Голос Бога"
Сообщение Дмитрый »
Как то не понял вас уважаемый Брэнд
Лучше по сушеству говорить.
димыч
Re: "Голос Бога"
Сообщение димыч »
этот голос бога перекликается с роликом "операторы сознания", где кроме прочего- описывается, как на одного человека действует похоже подобная технология, просто сводит с ума...
что до этой схемы- что она даст в плане развития? куда ее приложить? я вижу только вредоносные аспекты, вроде приказа кому нибудь отдать деньги и отписать квартиру :) предводители сект вам хорошо заплатят! хотя можно действовать например на буйных соседей дебоширов, преступников и тд, диски Патрушева им крутить прямо в мозг :)
Брэнд
Re: "Голос Бога"
Сообщение Брэнд »
"уважаемый Брэнд" понимал, что его не поймут земляне, хотя он и говорил по существу.
Ланцелот
Re: "Голос Бога"
Сообщение Ланцелот »
Напоминает фильм о войне. Когда немцы, аналогичное оружие создали, но не смогли применить, вроде под Кенинсбергом. Там еще в виде резонаторов были туннели, заполненные водой.
Re: "Голос Бога"
Описание патента четкое и конкретное. То, что идет дальше, имхо, - это фантазии вокруг плохо понятого описания патента. :?
Для того, чтобы получить этот эффект в свое распоряжение вовсе не нужно ничего паять, тем более, что радар должен работать в гигагерцовом диапазоне - просто в открытой продаже не найти элементной базы. Да и на заметку органам можно попасть... :(
Для того, чтобы сделать это дома достаточно аудиоредактора Adobe Audition. Там есть функция модулирования одного аудиофайла другим. Берете в качестве несущей частоту 15,1кГц и модулируете ее голосовым файлом. Мои эксперименты дают основание предполагать, :) что для пущей разборчивости лучше брать не конкретную полосу, а шум, отфильтрованный от низких до 15кГц. В результате вы получите так называемый супралиминал (supraliminal) аудиопрограмму - довольно новомодное изобретение на рынке аудиопрограмм для модификации поведения. В отличие от саблиминала (subliminal), который (кто бы мне тут что ни говорил :)) без специальных ухищрений работает очень плохо, эту программу можно пускать на полной громкости в абсолютной тишине (ну, бывает, субгармоники проскакивают на низких частотах в виде слабого писка). Работает эта "штука" значительно эффективней саблиминала, но в результате прослушивания могут появиться довольно неприятные ощущения в голове, типа какого-то давления (вплоть до головной боли), если сделать слишком сильную громкость...
Другой веткой этой технологии является модуляция ультразвука. Сейчас в супермаркетах делают так, что, когда человек подходит к прилавку, то начинает слышать музыку, а чуть отшел - тишина. Это происходит за счет пьезоэлектрических свойств кожи, которая ультразвук переводит в обычный звук (вспомните Нейрофон). Поскольку ультразвук очень плохо передается по воздуху, то зона воздействия сильно ограничена.
Re: "Голос Бога"
Андрей Патрушев писал(а): Сейчас в супермаркетах делают так, что, когда человек подходит к прилавку, то начинает слышать музыку, а чуть отшел - тишина. Это происходит за счет пьезоэлектрических свойств кожи, которая ультразвук переводит в обычный звук. Поскольку ультразвук очень плохо передается по воздуху, то зона воздействия сильно ограничена.
Да, это давно заметно. Я то думала , что это мои очередные глюки, дочь просила прислушаться, но она ничего не слышала и не реагировала , так как есть у нее некоторые вещи , которые помогают на это не реагировать , тем более сознательно это определять. Но у меня на это уже нюх)))). Это не только в супермаркетах, это и не только в частотах и текстах выражено. Это даже инфой накладывается на рекламные постеры . В метро это сильно заметно. Кстати в метро иногда тоже прослушивается кое что)))) Пока не пойму, но интересно , что сознание выдает интересные картинки , а ухо реагирует на звуки, которые напоминают те, что в супермаркетах. Только похоже не на покупки ....а скорее в метро , что то типа..." Все нормально.....все спокойно и нужно вести себя так то, и так то)))))))) Есть еще некоторые заметки но пока они проверяются.
Дмитрый
Re: "Голос Бога"
Сообщение Дмитрый »
Есть такие Ультразвуковые Технологий.Параметрические Спикеры и т.п особенно популярнный Audio Spotlight и HSS(Hyper Sonic System),но это всё Ультразвук....Который не может проходит сквозь матерялы..во всяком случае не может хорошо доставить аудио сигнал...Хотья есть одинь интересный патент "Acoustic Heterodyne" Изображение и как видите на картинке
использованно два трансдусера которые 200 KHZ излучают.
Один сигнал чистый 200 КГц, другой тоже 200 КГц,частотно модулированный голосом...на этом принципе сделаннй ультразвуковые динамики,только на более низких частотах чем 200 кгц...
А патент о котором я говорю выше,другая система и у него есть довольно неплохие опций так сказать.Уже То что сигнал хоть модулированный или обычный с помошью этого аппарата передаётся сквозь стены чего стоит. :)
Re: "Голос Бога"
Дмитрый писал(а):А патент о котором я говорю выше,другая система и у него есть довольно неплохие опций так сказать.Уже То что сигнал хоть модулированный или обычный с помошью этого аппарата передаётся сквозь стены чего стоит.
Мой шеф в самом конце "эпохи исторического материализма" предлагал МВД сделать такую систему, когда к зданию с засевшими террористами (с заложниками) подгоняются два излучателя (прям по Стругацким :)), которые под прямым углом друг к другу транслируют частоту, которая "проникает сквозь стены", модулированную дельта ритмом. В результате в здании все должны заснуть (вернее "отрубиться") и у спецназа в распоряжении окажется не менее минуты (после выключения излучателей), чтобы всех там повязать... МВД ответило, что нам такая "фигня" не нужна, а шефа вызвали в "органы" (совсем другие :wink: ) и, буквально, запретили заниматься исследованиями в этой области, и шефу пришлось менять тему уже почти готовой докторской диссертации...
Вадим Перелыгин
Re: "Голос Бога"
Сообщение Вадим Перелыгин »
"Представьте себе, когда звучащий в вашей голове голос регулярно угрожает навредить вам или вашим близким, или даже приказывает вам сделать это самостоятельно. Это было бы ужасно! Такие слуховые галлюцинации являются одним из наиболее распространенных симптомов шизофрении, причем примерно каждый четвертый страдает от этого, продолжая испытывать их даже принимая антипсихотические препараты.
К счастью, ученые недавно помогли шизофреникам получить контроль над их состоянием, превращая эти голоса в интерактивных аватаров. В исследовании, проведенном в Университетском колледже Лондона, 16 испытуемых шизофреников работали с терапевтом для подбора компьютерного лица и голоса, которые, по их мнению, наиболее близко соответствовали злой “сущности”, которая разговаривала с ними.
Кроме того, каждый субъект получил MP3-записи их сеансов, которые можно слушать всякий раз, когда они начинали слышать голоса снова. Как только все сеансы закончились, почти все участники сообщили об уменьшении как частоты, так и степени тяжести их галлюцинаций. Три человека, у которых были галлюцинации в течение 16, 13 и 3,5 лет, перестали слышать голоса полностью.
Научно-исследовательская группа получила награду в 1,3 млн. фунтов стерлингов (1980000 $) от британской благотворительной организации «Wellcome Trust» для проведения более крупного терапевтического испытания. Это испытание будет включать 142 испытуемых человека и планируется его начать в июле в Королевском колледже Лондона. Первые результаты ожидаются на конец 2015 года".
Источник: wordscience.org
Дмитрый
Re: "Голос Бога"
Сообщение Дмитрый »
Мой шеф в самом конце "эпохи исторического материализма" предлагал МВД сделать такую систему, когда к сданию с засевшими террористами (с заложниками) подгоняются два излучателя (прям по Стругацким :)), которые под прямым углом друг к другу транслируют частоту, которая "проникает сквозь стены", модулированную дельта ритмом. В результате в здании все должны заснуть (вернее "отрубиться") и у спецназа в распоряжении окажется не менее минуты (после выключения излучателей), чтобы всех там повязать... МВД ответило, что нам такая "фигня" не нужна, а шефа вызвали в "органы" (совсем другие :wink: ) и, буквально, запретили заниматься исследованиями в этой области, и шефу пришлось менять тему уже почти готовой докторской диссертации...
Т.е. Вы говорите уважаемый Андрей,что интерес к схожим темам чревато интересом с соответственных "органов"....может быть,допускаю Но,здесь же речь не а сверхсекретном проекте по управлению разумом.Вся эта информация и аппаратура схожая давно продаётся и гуляет в сети,так что...хотья чем чёрт не шутит как говорится))
Re: "Голос Бога"
Вадим Перелыгин писал(а):"Представьте себе, когда звучащий в вашей голове голос регулярно угрожает навредить вам или вашим близким, или даже приказывает вам сделать это самостоятельно. Это было бы ужасно! Такие слуховые галлюцинации являются одним из наиболее распространенных симптомов шизофрении, причем примерно каждый четвертый страдает от этого, продолжая испытывать их даже принимая антипсихотические препараты.
И вы поверили в их эффективность? )))))Ню-ню....Кто не знает что это такое , называя как угодно-шизофринией или еще чем.... Надо сначала понять что это? Что за голоса, откуда слышимость. Извне или внутри. Как человек сам позиционирует их. Как свои сущности, подселенцы, или это типы характера, или это персонаж из другой реальности(внутреннего мира, миров) или это то , что свыше( руководство , которое тобой правит свыше) Или все же реально обрабатывают нас. Потом рассуждать , что помогло. Я думаю, и никому не навязываю свою точку зрения. Что просто сущностям или еще кому там надоели эксперименты. Потому на сознательном уровне, на "хозяйстве "остался один адекватный. Отмел сомнения и сказал -Все супер просто и вы правильно и хорошо поработали. Все -МНЕ ПОМОГЛО!!!!!!!!!!!! Аха. .....
Вадим Перелыгин
Re: "Голос Бога"
Дмитрый
Вы и в самом деле не понимаете моральное уродство людей мечтающих при помощи подобных штучек управлять себе подобными?
Может хватит плодить шизофреников?
Лилия, я и говорю, что количество желающих влезть к нам в голову уже зашкаливает. И кого только там нет. И вот еще только осталось привлечь сюда самодельщиков и недоразвитых шутников!
Я бы за такие шутки... :evil:
Дмитрый
Re: "Голос Бога"
Сообщение Дмитрый »
Вадим Перелыгин
во вред можно использовать и кухонный нож и обычный молоток...я пытаюсь взглянуть на эти веши с точки зрения науки и будущих улучшенных технологий.При чёи тут управление кем то,тем более что кто ишет такие "лазейки" как выше говорил без проблем найдут их в сегодняшней сетке...
Вадим Перелыгин
Re: "Голос Бога"
Кухонный нож и молоток Вы сравниваете с психотронными технологиями!
Что это - злонамеренная слепота? Или ПРОВОКАЦИЯ?
Свинья грязи всегда найдет, но это не значит, что грязь нужно специально разбрасывать!
Re: "Голос Бога"
Вадим , Словом и мыслью можно тоже убить -НАСМЕРТЬ!!!!))))))Что теперь не говорить , не мыслить? Ну деградация полная! Хотя научимся тогда ментально друг-друга понимать)))Тоже польза , тишина будет........Но ведь и мысль и слово имеет свою и частотную волну(тембр голоса) и энергетичесскую и световую так что голосом даже можно убить. Или пригасить)))) Нужно только им уметь пользоваться)))))Короче жить вредно, думать вредно и мыслить тоже. Песни не поем , сказки не рассказываем, и даже тихо про себя не думаем. Переходим на новый уровень сознания!!!!!!!!!!!!!!!!!!! az :ap
Вадим Перелыгин
Re: "Голос Бога"
Лилия, Вы что нарочно? Я не верю, что Вы не понимаете разницы межде кухонным ножом и гранатой!
Словом и мыслью можно навредить конкретному человеку, да и то он вам ответит "сам дурак", а психотронные технологии в руках безнравственного
умельца, не видящего разницы между человеком и лягушкой...
Вообщем у меня вызывают подозрения люди с акцентом... 8)
Re: "Голос Бога"
Вадим Перелыгин писал(а):Вообщем у меня вызывают подозрения люди с акцентом...
А это можно расшифровать? Я бы например на границе , вместо солдатиков , как раз таку хреньку и поставила, особенно на Китайской и Афганской)))))Чтобы ни китайцев перебежчиков через Казахстан и Дальний Восток , ни наркотрафика через Афган. Чем плохо то? А вот в чьих руках, это вопрос другой. И очень важный. Вы правы.
Последний раз редактировалось ЛИЛИЯ-Р Ср ноя 29, 2017 10:24, всего редактировалось 1 раз.
Вадим Перелыгин
Re: "Голос Бога"
ЛИЛИЯ-Р писал(а):А это можно расшифровать?
Провокаторы могут втянуть Вас в игры за которые например сидит Бут.
Они же подстрекают к мыслям передать ядерную кнопочку в их "надежные" руки.
Существует ОПАСНАЯ информация и технологии (способы изготовления наркотиков, ядов, взрывчатых веществ, вооружений, суицида,...) за распространение которой НАДО сажать! :evil:
Дмитрый
Re: "Голос Бога"
Сообщение Дмитрый »
Вадим Перелыгин
Молоток и нож ни в тех руках более опасное оружие чем этот прибор.Ну понятно,понятно о чём вы толкуете,но не всё так трагично и никакого заговора или провокацию я не устраиваю.Просто хочу пообщатся с интересующимися людьми на эту тему с чисто научной точки зрения....про сам эффект фрея и т.д. Причём тут психотронная война и т.п. херня?(извините за выражение).В остальном согласен с ЛИЛИЯ-Р
Re: "Голос Бога"
Дмитрый писал(а):Просто хочу пообщатся с интересующимися людьми на эту тему с чисто научной точки зрения....про сам эффект фрея и т.д.
Возможно, Вам будет это интересно...
Идущая вперед
Re: "Голос Бога"
Сообщение Идущая вперед »
я поддерживаю Лилю... тоже слышу этот высокочастотный писк... сигнал идет в ухо, в основном в правое... в метро особенно... и от мобильника - когда он произвольно включается просто так иногда... и голоса тоже слышу...
вселенцев определяю по своему состоянию - если вдруг внезапно начинает накрывать депресняк и в голове что нить крутится типа - зачем я живу на этом свете? надоело все... не хочу жить - начинаю отчитку и чувствую как сущность через левую ногу уходит в землю... или раздражение и злость может внезапно подкатить - значит нахваталась от окружающих... и вот здесь основное и самое правильное - это осознанность и безупречность.. только осознанность а не витание в облаках или нахождение в прошлом и хрень с кашей в голове - могут избавить от бесов подселенцев чужих сущностей и навязываемых социумом программ... и когда выходишь из социума и смотришь на все это как наблюдатель - удивляешься чукотской наивности наших граждан...
чутким надо быть когда в тебя пытаются напихать всякую фигню со стороны... ЧУТКОСТЬ ОСОЗНАННОСТЬ И ЧИСТОТА
