Here are ideas for using DreamStalker'a need to dream, but I don't see them. Rather dream about all, but I just don't remember.
So there is no reason to buy this device, if I don't remember dreams and don't have the ability to watch?
Is there any sense in buying if ...
- Has thanked: 6 times
- Been thanked: 18 times
Re: is There any sense in buying if ...
Lord Cerberus
So just for this device has alarm clock that can Wake You up during sleep in the REM phase, not even matter if You managed to enter a lucid dream or not. Waking up, you can absolutely not straining to write down the dream built-in recorder device. He will offer You to do with the help of voice prompts. You don't even have to remove the mask for this. Just tap the hand button, CHECK, hidden under the mask (it is available to press through the mask), and say everything was a dream. Then click the - dream recorded. Morning can listen to the recording. For this you have to buy the PRO version. Good luck!
Well, if I don't remember what I dream that it will change?Александр (разработчик) wrote:Lord Cerberus
You don't remember, most likely from the fact that after a phase of REM, which is sleep, sleep for quite a long time and forget your dream. The device will Wake You up in REM, after some time, from the beginning, when the dream will evolve. At this point, and he will Wake up. How can you forget what was before her eyes? The picture will stand still in front of You, actually. Immediately record on the recorder and go back to sleep, in the morning will understand that there had, according to the records.
Alexander (developer)
Sometimes dream hot dream and the alarm rings in the most interesting moment ![Embarassed :oops:](./images/smilies/icon_redface.gif)
(perhaps because I did not read the instructions to the end)
The device determines the beginning of REM sleep. And if he could determine the end of this phase? To finish the dream until the end, and then Wake up and record itАлександр (разработчик) wrote:You don't remember, most likely from the fact that after a phase of REM, which is sleep, sleep for quite a long time and forget your dream. The device will Wake You up in REM, after some time, from the beginning, when the dream will evolve. At this point, and he will Wake up. How can you forget what was before her eyes? The picture will stand still in front of You, actually. Immediately record on the recorder and go back to sleep, in the morning will understand that there had, according to the records.
Neopian
The device is primarily focused on lucid dreaming. For many people that is difficult enough overly long keeping itself in the lucid dream state. They after some time simply fall asleep and look ordinary dreams. Therefore, the alarm rings through a relatively short period of time that people have not had time to get out of the OS and forget what he saw there. But You can increase this time using the MP3 files of the desired length in the folder AFTER. The file should be with zero volume, if You don't want to hear anything after the prompt (during OS). He'll just add his play to a minute long exposure of the clock. That is, when using the file with a duration of 3 minutes, the alarm clock rang after 1+3=4 minutes. Of course in the settings of the device it is necessary to enable playback of the file AFTER.
