Exclusive mask DreamStalker Pro
Instrumentsthat will help you to get into a lucid dream
Владимир Никонов 2
Has thanked: 20 times
Been thanked: 28 times
Post by Владимир Никонов 2 » Mon May 21, 2012 18:34
Эргономичная маска для DreamStalker
Developed together with the creative Studio "paukste" the mask in DreamStalker Pro.
It has high comfort and ergonomic shape.
Each mask is hand made.
The mask is made of high quality Italian materials (exterior — satin, inner — breathable cotton, soft elastic band).
The inner part is removable and washable.
Made a total of 5 masks.
Cost: 5000 rubles + shipping.
PS
The device DreamStalker is not included. Only a mask.
Павлум
Re: Exclusive mask DreamStalker Pro
Post by Павлум » Wed May 30, 2012 17:27
Vladimir Nikonov
Vladimir, already wrote the PM (it seems not very working PM) - still have the mask and you can buy them? Preferably not by mail, unless of course you don't have to go very far for it ))
Владимир Никонов 2
Post by Владимир Никонов 2 » Wed May 30, 2012 19:48
Paulum, in the presence of 4 masks. They are now in Krasnodar. If you are in Moscow, you can send to the office and it would be delivered.
Владимир Никонов 2
Post by Владимир Никонов 2 » Tue Jun 12, 2012 17:43
There were 3 masks. All in stock in the office in Moscow. Now 5 more masks sewn. Will be within a month.
Владимир Никонов 2
Post by Владимир Никонов 2 » Wed Jun 13, 2012 18:49
Left 2 mask.
Павлум
Post by Павлум » Thu Jun 14, 2012 16:30
The mask and confirm. Advantages:
1. Easy
2. Not so warm as the original
3. Semi-transparent to light, which is important, as the look into the distance fokuserade
4. The motion sensors do not fidget, and therefore the reliability of the device increases (the sensors are not hidden under the fabric)
5. The sensitivity of the instrument is higher - probably due to the closer location of the sensor to the eyes.
6. It can be disassembled and washed, but I haven't tried to do.
Алтай
Post by Алтай » Sun Jun 24, 2012 8:35
You need to back recorded two rubber bands, is that you do not understand??? take compare with one band and with two!!!
Владимир Никонов 2
Post by Владимир Никонов 2 » Mon Aug 13, 2012 22:28
Altai, you have a new mask?
Владимир Никонов 2
Post by Владимир Никонов 2 » Mon Aug 13, 2012 22:30
How to create new masks for DreamStalker
Each mask will be unique.
solar_serfer
Post by solar_serfer » Mon Aug 20, 2012 14:07
cool mask!!
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Mon Sep 03, 2012 1:26
Vladimir, next time will be to develop, consider this option.
Image Image
Outer beauty, of course, no(half an hour of work from scrap materials - I have something its not to sell), but much more convenient to handle. In valve built-in magnet on cover for cell phone(Oh, how loudly rustling Velcro in the silence of the night when you need a reprieve redraw), the mask metal U-shaped plate to which it adheres, it at the same time and the button presses check - in-the-dark search just slightly press all five fingers on the lower part of the valve. Sitting fee is good
Though I first just case the Board wanted to do, so it was easier to pull out/insert it from the mask(aka legs soldered clings struggles, and the cloth should be easy to fly if the pocket to expand slightly), and then decided that the mask is easier to make than in the old pocket is fine to alter. With a cover, incidentally, is also not a bad idea if the plastic cover on the Board not to do so.
Владимир Никонов 2
Post by Владимир Никонов 2 » Fri Sep 07, 2012 17:32
Finished a new batch of masks (50 pieces)
илья л
Post by илья л » Fri Sep 21, 2012 9:22
And if that mask to normal DreamStalker ?
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri Sep 21, 2012 13:03
илья л wrote:And the suitability of this mask for normal DreamStalker ?
Suitable.
Post by Андрей Патрушев » Fri Sep 21, 2012 13:33
к-13 wrote:(aka legs soldered clings struggles, and the cloth should be easy to fly if the pocket a little to expand)
So, after all this is done, so she fidgeted and "solar cells" does not shift... 8) :)
Post by к-13 » Fri Sep 21, 2012 14:15
Andrei Patrushev, :lol: say, after dinner harmful much to laugh - can be a volvulus to obtain :roll:
I solved this problem the valve and access the buttons with the screen easier, and nothing is loose. Now device new mask actively uses sister said, which is very convenient(the original used only three times, did not like). Only magnet double hook changed(a couple of times a night magnetic valve opened) and the hole in the valve under the headphone Jack cut out. To pull the Board do not need(except for washing) - a memory card you could get all the buttons available, the screen can be seen, the batteries are changed without any problems - she sits very tightly, and holes in fabric not in principle shift from light bulbs and motion detector. Most importantly, it on the face comfortably and tight - no pressure anywhere, light on the eyes... Maybe you can make a batch of these masks - nice and neat(and that at me hands under a sewing machine are not sharpened, I'm just a needle deftly wielded after two five-year plans to sew undercollar to the jacket), you can even "source", to provide first acasia to Krasnodar to zero-not to develop - they really are easier to handle are...
Post by Андрей Патрушев » Fri Sep 21, 2012 14:23
K-13
Yeah, I'm not arguing, I like Your idea. :) Just th-that because of this, solder swear, and in this design is, in my opinion, is a simple and elegant solution...
Post by Андрей Патрушев » Fri Sep 21, 2012 14:28
By the way, if Volodin mask (well, maybe it is necessary to elaborate just a little bit) to not insert Grimstalker and work items from bandages "Obviously", it is possible to obtain interesting trainer for meditation in total darkness with your eyes open and exercise alternative vision...
Post by к-13 » Fri Sep 21, 2012 14:33
Don't know, I for more than two years ago had a regular DS, I was quite content with the standard mask - I have trouble sleeping I can and standing with a bucket on his head to sleep. And many are not satisfied with it... So, I think we need more in the way of ergonomics to look at, and not the external gloss.
by the Way, if Volodin mask (well, maybe it is necessary to elaborate just a little bit) to not insert Grimstalker and work items from bandages "Obviously", it is possible to obtain interesting trainer for meditation in total darkness with your eyes open and exercise alternative vision...
It "palming" or something? The best option for this - your own palm, there is still something of the natural abilities and capabilities of man is mixed and always with you)))
Post by Андрей Патрушев » Fri Sep 21, 2012 14:34
к-13 wrote:Is "palming" or something? The best option for this - your own palm, there is still something of the natural abilities and capabilities of man is mixed and always with you)))
Yes, of course, but I'm more than 15 minutes che can't sit (hands are pretty much numb), and 15 minutes is hard... :?
Post by к-13 » Fri Sep 21, 2012 16:18
But more is needed - better three times more likely to practice in five minutes than 15, but rarely get time before the start of images to reduce, then easier over the quality of the work. By the way, seeing through eyes pressed to the palm of your hand - a great way to reality check.
Владимир Никонов 2
Post by Владимир Никонов 2 » Mon Sep 24, 2012 23:41
к-13 wrote:I can even "source", to provide first acasia to Krasnodar to zero-not to develop - they really are easier to handle are..
Take a picture and put it on the forum. Will pass to the development Studio.
Post by к-13 » Tue Sep 25, 2012 1:34
Here are two pictures - viewtopic.php?p=91773#p91773. Any other angles needed? This is the basic idea, the rest not so much on the inside it is not very different from yours - not so gently and the foam a little smaller. Initially made all pocket hinged down to access the memory card, then decided through the hole in the bottom of the mask it is easier to stretch, this fabric stretches well.
Been thanked: 182 times
Post by Андрей Кабанков » Mon Nov 09, 2015 23:20
Хабаровскийжитель
Has thanked: 4 times
Post by Хабаровскийжитель » Fri Dec 25, 2015 12:22
Hello! Please tell me whether there is currently an exclusive mask? I would like to write
