Винс wrote:No, glue does not need to log in to the OS
Just from the mask slowly began to peel off the foam gasket. There are traces of some light glue, reminiscent of PVA, but not really studied the issue in detail. What's the use glue or at least how you can return the mask to normal?
Thanks in advance.
Foam glued together and glued to various products (fabrics) glue BF-6, as well as glue marks 88 and 88-N, prepared on the basis savaneta and Nairit.
To glue foam to fabric, foam and cloth slightly moistened with water and smeared with glue BF-6. After 5— 8 min on the surface of the foam and fabric of a sticky film which dried in air until, until it no longer sticks to dry hands (about 8-10 min). After that, the foam and the fabric is applied a second layer of glue and after 5— 8 minutes both surfaces join together. The connection of the foam with fabric iron through a damp cloth with a warm iron.
Work with adhesives stamps 88, and 88-N is simpler, since both surfaces is applied only one layer of glue and place bonding iron using a dry cloth.
