Fear is natural. Because more and return the same way then it is worse) And gain the ability amount of attention as the wasp develops awareness and the ability to enter a dream within a dream is accumulating a volume of wakeful attention. I max out to reach the 6 levels of sleep. Maybe someone found the value of the experience of the dream within a dream, I then just bored: every subsequent level of quality is not much different from the previous one. Little practical value except "uhh, how deep was able to get up!" was found.Гуфест wrote:Novot as Vosne else to sleep,it is not clear,there is no fear.
About the results (you have vivid dreams, Osov)
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Aura
Re: about the results (you have vivid dreams, Osov)
At any enough to hold the setting. Most often, the sense of reality contact is an indicator that you are at this moment dreams of man, though not all can remember.
Wake up like this... And you didn't Wake up. Wake up... And you didn't Wake up. I Wake up and then starts to panic "what if lost and not coming back" - here and finally Wake up )) sometimes Fear is even useful ))Because it is still and to come back this way then it is worse)
Though... Who knows, and suddenly woke up...
Aura
How do you usually control the dream. Thought = action.
Aura
And then half a day awareness practice, "feeling" reality and suddenly all the same not awake?.по. wrote:Wake up like this... And you didn't Wake up. Wake up... And you didn't Wake up. I Wake up and then starts to panic "what if lost and not coming back" - then and up ))
p.s. pinching myself - a dubious criterion
But, in General, and there is no particular criteria... Given the same level of direct perception, as in a dream... And, at times, very awesome event, "like a dream".
Aura
Theoretically no, practically Yes, of course. Point awake the attention of such a hole eaten, not to be confused with anything else..по. wrote:But, in General, and there is no particular criteria...
I've had like in the movie Matrix,when a foot pressed to the ground and at the same time the body from the lying position taking a vertical position . when I stood thus,I even of something ridiculous.))
Do I understand correctly?This is when the all-day tyrants remembers fragments of the dream?ie they come to mind without asking for them.wasps are developing awareness day
Aura
Not really, the awareness day means that you are aware of yourself throughout the day.Гуфест wrote: Do I understand correctly?This is when the all-day tyrants remembers fragments of the dream?ie they come to mind without asking for them.
By the way, I remembered... to sleep on the second level of sleep enough to go down, for example the stairs or under the ground or on the lift, it doesn't matter... You will be asleep and the picture changes. All pictures drawing of the brain, but he knows that "down" is deep in the subconscious.
Likewise, climb the stairs to the attic, for example - "pop up" in layers of dream, all to higher consciousness. Naturally, the picture should switch and the switch is not detected, drops out, but the dream continues quite logical.
Not enough. It is a technique of deeper perception in one level. And only the first one. Even the bubble of perception does not change during the descent/ascent..по. wrote:By the way, I remembered... to sleep on the second level of sleep enough to go down, for example the stairs or under the ground or on the lift, it doesn't matter... You will be asleep and the picture changes. All pictures drawing of the brain, but he knows that "down" is deep in the subconscious.
remember Monroe go to another level, shrinking and twisting in a spiral But it was not a dream. He's kind of channeling involved.
It may be that I dream very rarely controlled, rarely spontaneously was only, including dive under the ground and then rise. Where one dream was replaced by another completely new scenery, but not in the story. The story passed from one dream into another (this is a dream that is not associated with multiple wakings, namely the continuity of the plot and the descent/ascent at altitude.not Enough. It is a technique of deeper perception in one level.
For example, a zero floor is the ground level. Minus the first underground, the camera archological excavations. Minus the second mine from this chamber down into the unknown. At each descent you lose focus and find ourselves in a new place even deeper. Similarly, the rise of, for example, one on the stairs in the underground room, then you lose focus and end up on the lawn, but the plot continues the same and so many times).
You can say this is a journey through 4-5 completely different dreams with different sets and logic, but with one outline of the plot and with the same "partner" running ahead (deep down there was awakened the monster, which had to run, literally, physically feeling its presence behind in all my dreams)
The funny thing about this dream was that with "partner", or rather companion - agreed on a joint sleep on the day before a dream ))) And she for the first time in 20 years had a horror movie, only slightly different story, well, I was there ))
With sense understand that being in a dream,control,change of scenery ,it's probably very difficult,we need to know the techniques,equipment, and all whose dreams are..seriously?
for
Being in the multi-storey house from which I want to get out of than expected? preference is given to Windows ,not the doors.to sleep on the second level of sleep enough to come down
