Short tones - when moving eyes, long melodic signal when the three-time rhythmic movement of the eyes. In the same way in the "duplex" device is turned off directly from the lucid dream (rhythmic movement of the gaze). You can work out.Дмитрий Денисов wrote:During testing, the sensor device generates short beeps and a long one. As I understand it, short indicate the detection of movement, and the long of operation of the device at the selected sensitivity level. I correctly understood, as the beeps occur even when turning the head, and long with intense eye movements?
Questions Dream Stalker Pro
Александр (разработчик)
- Has thanked: 6 times
- Been thanked: 18 times
Re: Questions Dream Stalker Pro
Alexander (developer)
Continuing the theme of instrument-cuff thought about the one amazing advantage:
The device could have a "Day", which meant that when you change the emotional background or just on a timer, such a device would give out tips a day to be able to check the reality. This would greatly increase the efficiency of the device at night!
The device itself can be configured at design time:
To wear a mask in DreamStalker and to connect the data logger pulse. Going to bed and waking up to compare the operation of the device at the time and the picture pulse. In the end, it is possible to develop an algorithm for triggering the device to change the pulse.
But really, the idea of a device that would have a day trained, I definitely like it!
Totally agree. Almost the same thoughts. I was going to make a chaotic operation in the afternoon for training.Павлум wrote:the Device could have a "Day", which meant that when you change the emotional background or just on a timer, such a device would give out tips a day to be able to check the reality. This would greatly increase the efficiency of the device at night!
And what about the pulse of the situation. There are foreign study on this subject, which was made continuous measurements of heart rate during sleep. There are minor, but obviously eye-catching changes of heart rate during REM. The study was conducted with the aim of clarifying the dependence of the pulse phase of sleep. To capture this change with a finger on the wrist is impossible, but accurate software analysis will enable you to make the right decision.
A device that generates chaotic signals by means of vibration exists. This Is The MotivAider. Hung on the belt, you only hear you. Exhibiting a timer for periodic triggering or chaotic within a specified time period. Exhibiting the intensity and time of vibration. I have this thing were. It helped to remember the day that everything is a dream, but not tied to this Vospominanie when I went to bed. In principle, and works by itself, but if the night will remind...
We need to consider if the device can signal the day in connection with the acceleration, for example, pulse - changes psihoemotsyonalnoe background, it would be cool. Ie, get angry, and you - Bang - and not a dream? It is our thoughts and emotions take us away from awareness.
Yes, in principle it is possible. You need to mark in case I decide to do this business.Павлум wrote:we Need to consider if the device can signal the day in connection with the acceleration, for example, pulse - changes psihoemotsyonalnoe background, it would be cool. Ie, get angry, and you - Bang - and not a dream? It is our thoughts and emotions take us away from awareness.
Paulum
I am very interested, but have not tried whether You are aware of only vibration or only to sound the buzzer? Not to a voice file, namely, the beeping of the tip of the device. Please describe the results more if they were. Really need these statistics for decision-making on the new device.
No, have not tried, but since me and this theme is great fun - try a series of experiments. Here I will post a report about what happened. Let's start with vibrations, moreover, it is the most promising subject - and not Wake anyone, if anyone in the room is sleeping and the effect, I suspect, should be interesting. Put on the minimum of the response time of the light signals, and brightness.
If you have any suggestions for experiment - write!
Generally you can connect the rest of the people to this subject. It would be a full investigation
The LEDs should have a good idea to seal with electrical tape in several layers, to avoid the light hints perfectly.Павлум wrote:No, have not tried, but since I have this theme is great fun - try a series of experiments. Here I will post a report about what happened. Let's start with vibrations, moreover, it is the most promising subject - and not Wake anyone, if anyone in the room is sleeping and the effect, I suspect, should be interesting. Put on the minimum of the response time of the light signals, and brightness.
Thank you for your help.
I also agree that if the audio signals were replaced by "vibration" it would be much better. Including as a way to workout in the day time for a reality check. I think the effect would be steeper.
Costaba
But in Dreamstalker Pro has vibrate
In advanced settings you have to put FL-1
Sorry, the mask is not going to wear
Started last night to experiment. Vibrate duration to be 4 seconds steadily wakes me up. Put today 2 seconds.
Paulum
Thank you for the test. Remember that the power of vibration is regulated? Given Your awakening, it is better to choose 1 is the weakest.
Here You could have not prevented the daily workout even in a small amount to get used to this sensation of vibration, and that night, all of a sudden, a sudden vibration of some kind- of course sleep immediately fly away...
Report of utilization of vibration hints 02/07/12
Went to bed late around 03:00, so I wore a mask with exposed timer for 30 minutes. Installation:
Vibration - FL-1
Exposure time - 2 seconds
The device gives an account of the four positives
04:12
04:30
05:47
06:06
Remember 2 operation - the last one (for some reason it seems that the first).
At last I have not slept, and woke up a second before it starts.
On the positive, I remember while sleeping I had a dream that I was flying on a motor-hang-glider over the beach. Vibration was felt as the wind and the roar of the engine. I basically realized that the device worked, but did not attain lucidity too fond of sleep.
Today I will try to put 3 seconds duration and like a evening mask, to poobshatsa and get used to the signal for a reality check.
Vibration - FL-1
04:12
04:30
05:47
06:06
Very interesting - the wind and the sound of the engine. Then in the afternoon, probably, it is necessary to check the reality (for training), he heard the sound of a passing car, the sound of the wind outside the window, etc.
Maybe I'll try to snap attention to these points.
To be honest, really rely on exercise before bed, although I know that in momem case, the effect is not instantaneous, but should accumulate, so you'll have to be patient
And that you can adjust the vibration intensity and duration?
Yes, you can. Setup FL-X, where X is from 1 to 9 corresponds to the power variation of the vibrator from the minimum to the maximum, 0 - off. If this menu item press the button Enter, then the vibrator turns on for a short time so that you can evaluate how it works at the selected power. The duration of the vibration coincides with the duration of the light or audio cues, vibration as it complements them. Therefore, the duration of the vibration is changed, for example, installation in manual mode, the desired duration of light cues (the length of the audio hints can be reset to 0 so as not squeaking).Костямба wrote:And that you can adjust the vibration intensity and duration?
Report of utilization of vibration of the tip 02/07-03/07
The evening
Went in the evening from 19:00 to sleep in the mask, the device worked 26 times. When triggered, the device threw any thing of what was doing, knew that sleep, looked on his hands, read the inscription, figure, time on the clock.
Night
Same settings, vibration level 1, duration - 2 sec.
The device is triggered 15 times a night, remember 3 I think, positives.
Dreams almost never remembered. When triggered, the instrument (all three times) dreamed another dream in which the world became black and white from color and began to tremble. I said to myself this phenomenon, but was not aware of it.
It is necessary to increase apparently, the exposure time to 4 seconds, perhaps there is addictive.
The evening
Night
Really strange situation with the off color sleep, and shake - generally cool. Perhaps there is another criterion for awareness, quite original hint - in real life, so it's not shaking the picture.Павлум wrote:activation device (all three times) dreamed another dream in which the world became black and white from color and began to tremble. I said to myself this phenomenon, but was not aware of it.
It seems to be in FL-1 there is vibration-it is purely symbolic, barely perceptible. What You have vibrator diameter 6mm or 4mm?
I have an old device, one of the first, there seems only two options -FL-1 and 2
On the deuce just head detaches
And You when you start, when you insert the batteries, see what happens on the indicator. Must be - F1.05.Павлум wrote:Alexander (developer)
OK. I will unsubscribe in the evening
Version F1-05. And the truth is 9 levels, hell no! On the 9th the device in hand can not even hold )) it Tickles!
Paulum
You seem to have the vibrator 6mm - they are more powerful. There were other options 4mm vibrators - are much quieter, the vibration is small. He looked at himself, seems to be gone such. And vibrators 6mm at full power is really cool to get a relatively lightweight device on the table already a little Bouncing, if without a mask. The dead will awaken, if not subtract
