It's a sign that if You sprayed...then your device will be wasted.. because You and Your device are.. inseparable whole..You betrayed your device is ignoring it this long(a year), it is a shame and He will do all.. to make You understand ..that He is alive..)) In such a situation it is better to ask forgiveness of the device, and say stabalise so nebudet, and will use the device regularly..)Игг wrote:are There any ideas about how to be in this situation?
Neponyatka with Dreamstalker
СтаниФилмТВ
- Has thanked: 24 times
- Been thanked: 63 times
Re: Neponyatka with Dreamstalker
СтаниФилмТВ wrote:It's a sign that if You sprayed...then your device will be wasted.. because You and Your device are.. inseparable whole..You betrayed your device is ignoring it this long(a year), it is a shame and He will do all.. to make You understand ..that He is alive..)) In such a situation it is better to ask forgiveness of the device, and say stabalise so nebudet, and will use the device regularly..)Игг wrote:are There any ideas about how to be in this situation?
Something more intelligible, ladies and gentlemen?
Александр (разработчик)
- Has thanked: 6 times
- Been thanked: 18 times
If you have enabled the standard settings or the duplex mode, the manual settings in the menu are not shown.Игг wrote:Hello! Used the device a few times and it was all fine , and then focused on techniques of self-exit to OS. And now a year later, triggers the device and detect evil miracle after paragraph settings menu
"9. On / off alarm [AL-0] (Alarm);"
Once the item
"16. Check of wakeup signals CHUP (Check of Wake Up
Signal);"
Are there any ideas about how to be in this situation?
Duplex mode is not enabled. Please tell me what the settings need to change to see the "manual settings"?
IgGextract from the manual:
setting the value to 0 disables the duplex mode. Thus in the device menu
becomes available select presets (UP-X). If
the selected UP mode-0 (i.e., manual configuration), then
be available to change the manual settings
light and sound signals.
