Reviews about DreamStalker
Павел Чита
Hi all. A week ago, also received a long-awaited Stalker, this is what happens when "trust and wait".
Maybe you have had a similar case?
So is it addictive. He has not yet received good results that can boast of, but we will continue. First, I learned to get used to the mask, when he dressed for the morning after 2,3 full sleep cycles, relatively well-slept and couldn't sleep. Then I decided once to wear in the evening for the night, holding a delay of 3 30 min. And such good timing that when the device is submitted 2 Segal 30 seconds to start tracking, I was on the move in the 3rd cycle, i.e., the awakening here is very likely - as they say Wake up between cycles and just fall asleep. And I recognized the flash of understanding that almost awake. But for the 3 30 managed to see just a dream, sorry Stalker didn't work. A conclusion that did not need to put restraint on the borders of cycles.practicing on the weekends (when I don't need to get up).
The problem is that the brain is "accustomed" to the device, it flashes so unpleasant that he wakes up for a couple of seconds TO two pre-flashes (which appear for half a minute to reset the timer)
Brightness at minimum.
Павел100
Please tell me, and inwhat is the difference DreamStalkerа the machine "SLEEP 5", the site http://www.morfey.ru/. At first I wanted to buy a "sleep-5", but then found your website and now a little confused. Hoteles to know about the different and preimushestvo your trainer. Thank you, sincerely, Paul
Александр (разработчик)
- Has thanked: 6 times
- Been thanked: 18 times
At the request of the buyer - a brief comparative analysis of the devices DreamStalker and SLEEP-5.Павел100 wrote:please Tell me, and inwhat is the difference DreamStalkerа the machine "SLEEP 5", the site http://www.morfey.ru/. At first I wanted to buy a "sleep-5", but then found your website and now a little confused. Hoteles to know about the different and preimushestvo your trainer. Thank you, sincerely, Paul
1. To power DreamStalker'a requires only two AAA batteries, to a DREAM-5 four battery.
2. Sleep timer in DreamStalker'e can be set from 10 minutes to 24 hours, there are two modes of instantaneous setup (one pressing a special combination of buttons) preset time delay, and in a DREAM-5 maximum timer time is 2 hours, which is clearly insufficient in order for normal sleep to lucid dream.
3. Select the level aktivnosti eye movements in DreamStalker'e adjusted very accurately in the range from 1 to 20, and in device SLEEP 5 this parameter can take only 2 values.
4. DreamStalker remembers not only the number of positives for the night, but also a specific time each operation, which is not in the device SLEEP-5.
5. DREAM-5 not very easy to use due to the fact that its control unit You should have somewhere near, and from him to the mask, wearing on Your face will stretch the wire, sleep will be difficult - he turned to the side, tore all these delays. DreamStalker fully assembled in the mask is a compact, modern device.
6. DreamStalker has a normal display which displays a variety of menu items to established settings, and other relevant information. For example, to find out what time worked a DREAM-5 You can't, but how do You know how many times it worked? Read the quote from the user of the device SLEEP-5: "To determine the number of past tips, you need to enable the "Test" button the input mode delay, and add the numbers corresponding to the lit-up LEDs. The number of tips was found to be equal to the sum of". Convenience, as they say, leaves much to be desired.
And so on...<
Павел100
And how, exactly, to tune?
1st experience -- sensitivity above average (of max. brightness no sound), everything else default.
I razbudili 6:20 - intelligently and gradually. Any dreams I (think == true) not seen. The "Reality Check" - press. Really. Surprisingly easy to sleep on. Before the "real" alarm clock (bedside standing mobile) had a dream (I have it down to a half-day even remember, Yes, I know, henceforth it is necessary to record). But it was not positives!
The mask is checked before the final rising - sensors are open, OK.
Of course, I'll be using next, but am feeling something wrong with the sensitivity of the device.
[in General, the device is worth to buy even if only to marvel at the triumph of engineering, chained in the development budget. However, I would like to start right positives.]
What about readings in the menu item "Cotr" (Counter of Triggering), were there any positives? Often write that signals in the dream are not seen as positives recorded. That is, the clues are so well woven into a vivid dream that people simply do not recognize, such as tips device. This is a normal situation.Гость wrote:But it was not positives!
The sensitivity of the instrument to the eye movement can be checked in a dark room using mode "CHdt (Check of Detector)".
Павлум
Alexander (developer)
In addition to "Sleep-5" - there is one huge flaw in this simulator - IT does NOT WORK IN the daytime! The device open the mask and the sensors cease to respond to light. Ie in the summer it can not be used at all after 4 am. I was confronted with this and therefore don't use more.
Oh Yes, the trigger was one. About.Александр (разработчик) wrote:Guest wrote(a):
On the trail. the night was still fun. I increased d to 7. No one ienya sleep, and dreams like there was, but I woke up some reason about an hour before the alarm. Checked the reality. Reason (freak
And then decided to take a NAP before the cell phone. And - I dreamed a dream (I mostly still remember) - the dream that the neighbors upstairs are so well drilled (which, by the way, sometimes really love drilling in 6 Ustra), which drilled the overlap. But the hole thus formed in the floor. While I was thinking, what will it cost me for repair of parquet, in walked a young man with the words (approximately) "Boy, they drill into the ceiling, and the hole in the floor. What are you, stupid?". At this point, I realized that sleep, and for better or worse, instantly awake. Then I got up, turned off and prassonissi alarm clock, checked again - 0 positives and went through the usual morning.
Ie work book attached to the device, which I have read before. weekend.
In fact, the plans for the dreams I have several other - maybe the OS-s is cool, but the reason for the purchase was basically their own investigation of memories of what Laberge nazyvetsya "unconscious dreams", and some related moments.
Ie, I'm not complaining, just at the device quite a lot of settings, and, generally speaking, several different modes of operation - in General, I don't think you will not understand, but if you have additional ideas in terms of device within the underlined text, I would be grateful.
Sorry for dlinnoju.<
Regarding the sensitivity of the instrument. Here is a quote from the manual, which is equipped with Your device: "the Minimum value for this parameterГость wrote:I increased d to 7. No one ienya sleep, and dreams like there was, but I woke up some reason about an hour before the alarm.
corresponds to the maximum sensitivity of the instrument". Thus, when You increased this value to 7, then simply lowered the sensitivity which You and so, apparently, was not enough for some reason. I recommend to do factory reset (SEtd), to test the sensor "CHdt". If you need to increase sensor sensitivity it is necessary to change the value of the d-05 to 1-2 units down.
Thank you!!!!!!! Well, I told you I'm a fool, and characters from the dream agrees with me.Александр (разработчик) wrote:So, when You increased this value to 7, then simply lowered the sensitivity which You and so, apparently, was not enough for some reason
In General, something turns out - for starters, it seems good. Thanks for the tool... and philosophical treatise of Laberge in the kit, too.
Six months record in the morning key words of dreams. Dreams are to be remembered (the last ten years, it was sooooo rare).
Dreamstalker received as a gift from his wife. I tried to use still twice. Vavo was not, signals in the dream, did not notice, although the trigger was. The first night sleeping. In the second sleep for four hours. Prefer to sleep on my stomach head to the side, and this mask is not very comfortable. I do not want to set the alarm clock to in the morning to wear a mask, because then hardly fall asleep. I'll try again to wear a mask tonight.
Such a device produces American firm Brainmaster from Cleveland. The device is called Atlantis and is in its simplest version (2 channel) about $ 3,000, including software. As I understand it, there is important and the most difficult - it's the software. The topic of EEG, I wrote extensively about my experience with this machine. Thing powerful, but not for everyone - you need to firmly understand the technique and in the brain. Requires highly sensitive electrodes of silver/silver chloride, plus all sorts of the contact of the ointment.Карил wrote:And maybe this is the Fourier transform let the computer thinks? If Andrew will explain what the Fourier decomposition, and why it is needed, it may be me that is also interesting.Александр (разработчик) wrote:Like it was about 20 thousand rubles., which is today much closer to $1000 than $500. For the case of Fourier expansion and the LCD screen will not say anything about the cost of $500, but it can be done, of course. For example, on a powerful 32-bit microcontroller with ARM core.
Without the LCD screen, I would have done, of course if you have a computer.
So the question is how much approximately could cost two-and four-channel versions of the device, without LCD screen? In Fourier seems to me possible in any mathcad th to decompose and schedule to build.
This only need if you want to have a house full of "laboratory of dreams". And, of course, are not afraid, that itself I think will equal... you know what (see resp. topics).Триалект wrote:Such a device produces American firm Brainmaster from Cleveland. The device is called Atlantis and is in its simplest version (2 channel) about $ 3,000, including software. As I understand it, there is important and the most difficult - it's the software. The topic of EEG, I wrote extensively about my experience with this machine. Thing powerful, but not for everyone - you need to firmly understand the technique and in the brain. Requires highly sensitive electrodes of silver/silver chloride, plus all sorts of the contact of the ointment.
Devices such as "DreamStalker", by the way, is not interchangeable with EEG devices - they are provided under a much more straightforward goal is probujdenie of consciousness in active sleep, by itself, EEG is nothing will not help, it is necessary only if you want detailed control of the process, and make certain your profound insights...
Ie if your target OS, all Atlantis devices 2-3-th order, DreamStalker - thing 1-th order, well, and most importantly - your own work on yourself.
Alas, as always. [in a sense, the need to "work on yourself" for my taste is a guarantee of security apply a lot of different devices.]
Tonight for the third time tried to work with Dreamstalker'ohms. Slept better than the previous two times. Went to bed at 1.30, set a timer for half an hour. Woke up to two warning flares, clicked on Check five or six times to give yourself time to go back to sleep. Spivshiesya unconsciously remembered a dream, recorded it. After this long - subjectively an hour and a half, that is until about half past four - I couldn't sleep, but flashes not seen. Woke up at eight, looked at the number of incidents was three, 7.16, 7.32 and 7.43. I remembered one of unconscious sleep, but there flares not seen.
When all three attempts were put UP in the standard minimum brightness (1st mode) - feared that the device will awaken, because sleep is very sensitive. In the next attempt will put the 2nd mode.
