For what purpose do You need such tests? Wear the mask, go to sleep and all You will have to work. If you do not react to the clues in the dream, increase brightness, duration, add audio, etc.МЕГА-Д wrote:che then I do not understand
I put the timer on 10 minutes or no matter how, all other settings default
after 10 min, 2 flashes, and sensors BGT-phase are not included.
Although on checking everything is OK
Reviews about DreamStalker
Александр (разработчик)
- Has thanked: 6 times
- Been thanked: 18 times
strange question. To know that I did not simply put.For what purpose do You need such tests?
what is written in the instructions:
30 seconds to flash off between the expiration of the sleep timer, the device will give 2 flashes of light minimum brightness...
After the aging timer the device goes into monitoring eye movements to detect REM phase during sleep
I repeat the question:
so I put set timer for 10 minutes. After 10 minutes, 2 flashes, but I can't sleep, that's all. No further outbreaks of tips, etc. is not happening even if I move my eyes, Yes, even the hand in front of the sensor led.
Today I'll try again of course, but I think it will be all the same.
I tried - all the same
come try night
WMS sensors later included
but the criticism in this case will still ie, and it does not coincide with reality
again, let me remind you that the motion sensors capture the movement if you do check them
come try night
I think so too, because without accurate knowledge of the algorithm of the program You are unlikely to start issuing tips. At least no one before You, so it wanted to test the results of the tips, it was not possibleГость wrote:Today I'll try again of course, but I think it will be all the same.
All the same. Just not specified in the instructions the minimum time and the principle of monitoring the movement of the eyelids. And monitoring is implemented with protection against extraneous movement, non movement of eyelids during sleep. This is causing your problem. And then I will pause for two minutes or fifteen, depending on what to consider...МЕГА-Д wrote:but the complaint in this case will still ie, and it does not coincide with reality
gygy
wow what suspicions
I didn't even think about copy.
Here is an example:
Kada you buy a car, probably her first city break in before the ride from Moscow to Vladivostok.
I the results of the tips test to not think then, why the night I saw nothing. Maybe the brightness is too small, etc.
Okay, so the night can see how buit to work
wow what suspicions
Here is an example:
- Князевский
андрей788
lucid dreams
question Vasilisa, and where you can order music by date of birth and blood group. I'm from Nizhny Novgorod
андрей788
Just in case I will explain the purpose of the device. The task of the device primarily is to determine during human sleep phase REM (rapid eye movements), and then after a pause for development of dreams to give light tips. Moreover, the level (intensity) of these tips should be regulated, otherwise one person may fully Wake up, and the other will not even notice them in my sleep. Using the flashlight it's impossible.андрей788 wrote:why do we need this device? because as I understand it is reminiscent of O. C. light, so you can hang over your head is a simple flashlight with the timer on and will have the same effect. Or am I wrong?
Acquired this thing to work, in principle, no complaints, everything is clear. But the mask made lousy - full of smelly foam rubber, smells like grease... Sleep is not possible in General, and wash not because it is not sewn and glued, and glued badly - has already started to come off! Because this glue is not intended for bonding fabric with upholstery foam... but In komments
KUSTARSCHINA!
morphs
Stink will soon cease,exhale as adhesive material.Order masks in the company that makes the corporate special. clothing that is not sewn themselves and not on the knees...a nuance that except with glue to grab foam rubber material is not possible unfortunately...now looking for another way of connection of matter with paralona. my mask is held for the second year with no problems,although on the sides the same parole a little off..
But I'm not saying what you have there seamstress play, design is also good, but the materials let us down, and do not consider the possibility of washing... If the liner which is to face but can be removed, or directly with him to wash - all the questions would be. And so... One night is terribly hard, sometimes I have the feeling that the smell still in his nose left... And when pyaasi - nothing shakes like and comfortable, and the smell is relaxing does not...
Bought waste.Feelings are twofold.Enough complaints.
1.pocket for fees great.
Had to expand the holes for dutikov and invest in a foam rubber mask that would not cut foam rubber pad on the nose.And the fee falls to the right,to the left and to the bottom.
2.Board gets wet and even when touching the edges felt electric.level.
Poprobuite to sleep with the hat in the stuffy night and when your head will sweat,she gets what I mean.
3.To get constantly the cost is not practical and not comfortable.Digs in adhesions over matter.
I would like 1,2 and 3 point.
Cost firmly fixed and covered with insulation,at least varnish.The top and sides of pocket to make a sticky that would provide easy access to the Board.
4.Fee wide and when turning to the left or right side depends on the pillow.It turns out the lever(swing)through the nose,changing the distance to the eye, and as the legacy fixed REM.
Even funny.Turn to the side and in the dream comes the thought:"after 20 min. work..."Becomes a conditioned reflex.
5.The day is getting longer,the night shorter.The matter is well illuminated,the bottom points just do not prelegal tightly.The sensor is again conducted.Try to test them(!)
4 and 5 item.11стадий BDG in the morning,just endless BDG.Fabric NAT more dense.The bottom atrocitizer paralon with EXT.stor.(still already)
And so the gizmo is not bad.I hope that the criticism on the merits and will help to make it even better.
Civil.
Civil.
Thanks for the criticism. Now replies:
. Why would You want to sleep in the conditions of Finnish saunas? If you sleep in the steam room still need, that you can put under the charge strip of thin plastic or better thin rubber. You can, incidentally, do not sleep with the device all night, and to put some your alarm for 4 a.m., woke up to turn on the timer of the device for 30 minutes and quickly fall asleep again at the back.
If pocket to make smaller to put in and take out the cost will be very difficult. You further write that the charge clings to matter. In fact, the conclusions of parts after soldering which is a cone-shaped spikes for that and want to clinging to the fabric, to keep the cost of pocket mask.Гость wrote:1.pocket for fees great.
Electric shocks feel it is impossible, because the device is powered by batteries with a total voltage of just 3V. As for the salty perspiration soaked the PCB, it's just damaged the device it turns out. Work then the device may be arbitrarily complicated, including spontaneous activation in the absence of REM. If you don't believe me, try to pour a glass of mineral water at the TVГость wrote:2.Board gets wet and even when touching the edges felt electric.level. Poprobuite to sleep with the hat in the stuffy night and when your head will sweat,she gets what I mean.
But the fees and have to hold onto these spines. Otherwise it will not be fixed in the pocket.Гость wrote:3.To get constantly the cost is not practical and not comfortable.Digs in adhesions over matter.
But what do You want? Put on the device - used to sleep and not to spin. It is possible to sleep peacefully, You just need to bring the room temperature to normal sleep levels.Гость wrote:4.Fee wide and when turning to the left or right side depends on the pillow.It turns out the lever(swing)through the nose,changing the distance to the eye, and as the legacy fixed REM.
The device can be tested a day indefinitely. One condition - it should not get light from electric sources. Put his day on the Desk near the window, turn on the timer and see what positives will not. Another thing is that the device You may be triggered due to the fact that the fee was covered. Then it will only by a thorough rinsing. Rinse can with gasoline "Galosha" (sold in hardware stores and construction markets) using, for example, a toothbrush. No solvent flush is impossible. After that try to use it carefully. Good luck!<Гость wrote:5.The day is getting longer,the night shorter.The matter is well illuminated,the bottom points just do not prelegal tightly.The sensor is again conducted.Try to test them(!)
