What do you mean more than normal? It seems to me more, at least compared to other equipment where there is background. Here, it is too obvious. Not to fix? If we turn to those who know how to solder.
The guarantee will cease to exist.1Андрей1 wrote:not to fix? If we turn to those who know how to solder.
Did not hear, can not say anything. But some background is always almost any device. So I write about the level more than normal, although the concept of this provision is quite vague. Noticeable background should not be there, but very weak background will, of course, is the norm. The background, as usual, depends on volume: the more volume - more noise. At minimum volume, the background to audition not to be. If You notice, he seems to have more rules, since typically nobody complains.1Андрей1 wrote:What do you mean more than normal? It seems to me more, at least compared to other equipment where there is background. Here, it is too obvious.
If you will listen through headphones, then the stereo will have some meaning, as it will play two channel. If you listen through the speaker, then it plays only the left channel, that is, in the latter case, regardless of record type, it will be mono.1Андрей1 wrote:Another question. To record better in stereo or mono?
In the normal version of this device made all the more simply mute or change the volume voice button does not provided. It is clear, of course, that night, even a faint background noise can Wake anybody, but the voice buttons is still some information in addition to press confirmation. For example, when trying to set the value of any setting above the limit, an intermittent error signal, instead of the usual squeak, and setting of invalid values is not performed. Therefore, voice is desirable, especially at the beginning of use of the device, for a more confident and intuitive menu operation. There would be no voice acting, angry users that nothing is clear - whether clicked or not clicked.Винс wrote:Well I meant the regular version of DS, not PRO.
Before all tests, do a factory reset in paragraph Setd, removing the batteries does not reset settings. Is the check mode of the motion sensor eye CHdt - check it. On the forum there is a technique a full scan of the entire cycle of operation of the device: http://www.mindmachine.ru/viewtopic.php?t=2733.РоМиК wrote:Hello! I bought the Pro version... Well, maybe I'm stupid, but all I was able to get it a few beeps when the timer expires. And that's all. The alarm is off. Modes tried including duplex. Dropped settings. General hints after a timer and that he considers his duty fulfilled. How to be?
With a significant discharge of the batteries may decrease sensor sensitivity to eye movement that can be compensated for by reducing from 5 to 4, the sensitivity of the sensor. Or replace the batteries (they should be system ALKALINE).Винс wrote:Much do you mind the light work on the DS? In the last week during the night of 4-5 positives, although this was 10-15. Maybe it's the batteries? Mode CHUP all regularly monitored..
The duration of the series of light signals in this case will be determined by the length of the tip, and the vibrator will run as long as there is results tips. This can be seen in the verification regime of the issuance of tips. Use this mode to clearly imagine what and how the device You will awaken. If necessary, adjust vibration levels, brightness and volume, and then again check what happened in the check mode.Волк wrote:Tell me...the device has a vibrate function for clues,but the instructions do not say whether it is possible to regulate the duration and if not ,how much it will be included at the time when actuation of the device if simultaneously enabled, and the signal light?
It is possible that when checking the sensor device falls electric light that will cause constant operation of the device with a period of about 4-5 minutes. This testing process is described here: http://www.mindmachine.ru/viewtopic.php?t=2733. If you have a device lies in a completely dark room and spontaneously triggered, then it's obviously some rare and pretty interesting fault. Just change the device if it has not been filled with any liquids.Василий Горняков wrote:Good afternoon. Acquired ordinary and grimstalker such a problem: in the test mode of the CHdt tool reacts as described in the instructions, but when setting the timer UtSE for example a minimum delay of 10 min., the passage of time, the sensor does not respond to the motion, but simply with some sort of their period delivers the wakeup signals independent of the motion giving the label Ph-1,2,3 .
Settings are :
d-01
du-0
UP-0
AL-0
Fr-7
Od-4
br-4
LE-1
F-07
S-02
two times were reset to the default settings and pulled the battery - it is not treated.
I'm sorry, but, in my opinion, you contradict yourself. If the device is beeping and how to understand that it does not work on arm movement? From what he then beeping, if not from actuation of the electric light or movement? If you believe that the device should work immediately as soon as you waved to him before hand, that is a misconception. From simple waving hand he may not work at all, and if they work then two minutes later, not earlier, because there is a pause for the development of dreams. What this mode is enabled, in which he lies and beeping? If you want a normal response, fully describe the situation.Василий Горняков wrote:Tested with a lamp - not a response, the device lives his life. There's even a certain time period of operation, it may take like 5 minutes so 10 and 15 - and is beeping when I want to not react to the arm movement.
Live in Krasnoyarsk, respectively, in office You can not come.
