Свободное пьезоэлектричество из сетевого фильтра
Добавлено: Вс янв 27, 2013 16:59
Искатель-2
вброшу:
Re: Свободное пьезоэлектричество из сетевого фильтра
Добавлено: Вс янв 27, 2013 19:47
делать нефига? людям головы иметь первоапрельскими роликами - сейчас январь еще.
Добавлено: Вс янв 27, 2013 20:14
Искатель-2
Михаил_ :)
меня удивляет обилие этих роликов
а если посерьёзней - есть ролики с реальными генераторами которые можно home made сделать ?
Добавлено: Вс янв 27, 2013 20:47
Искатель-2
во
http://free-energi.com/index.php?a=1
Electric loop free energy generator
The electric loop free energy generator is one of the most simple free energy generator topologies. It works on a principle of an endless electric loop. Once the initial energy is applied, the electric power keeps circulating in the ring. The circulation also starts the process of harnesing the ubiquitous abundant energy, thus turning the device into an overunity. Overutiny state allows adding a load without draining the energy from the circle. This turns the ordinary energy circle into a free energy generator and generates some amount of the free electricity. Big advantage of this version of free energy generator is that it has no moving parts. It simple uses the circular coil made of a multi-conductor wire. The electricity is the only thing moving in the generator. The disadvantage is that the free energy device of this kind can't be simply started by spinning its rotor, unlike the rotation free energy generators. The source of an initial electric energy is necessary. The Electric loop free energy generator topology is suitable for building the low to medium power overunity device.
The practical model of this generator is easy to build using the ordinary power extension plug. In most cases, the cable length of at least 3 meters (10 feet) is enough to form its operating coil. I recommned the coil diameter to be at least 10cm (4 inch) and the turn count at least 8 turns. The complete circle is formed by putting the end of the cable into one of the sockets. The free energy device is ignited by using a source of initial electricity. The voltage has to be high enough to start the circulation at the overunity level. The best ignitor seems to be simply the piezo from the electric lighter. It allows the ignition witn ho battery (that can run empty), just by pressing the button of the piezo element. This element generates high voltage sparks of several kilovolts, but with a very short duration and very low current. The output wire shoud be put very close to a metal part of the extension cord. Best way is to use metal parts accessible from outside, eg. the ground contact. The electromagnetic pulse is then induced into the other wires of the extension socket, eg. the line and neutral. Before doing anything, read the Disclaimer first.
The ilustration how the power extension cord can look like. It has several sockets. Note the maximum power rating denoted on it. This power should never be exceeded. However, in some cases, the generated power limit of the free energy generator can be lower due to the coil dimensions.
Beside the power extension plug, another necessary part of the free energy generator is the lighter. The image shows the comparison of the good and wrong lighters. The blue one is the good one - the piezo can be salvaged from it. The orange one is the bad one - it is the mechanical lighter, not electrical, and contains no piezo. So remember, not every lighter is suitable as a source of an initial energy!
Those photos illustrate the overunity generator before and after the ignition. I strongly recommend you to use the power strip with the indicator light in its switch. The light helps you determine Whether the generator is in active mode or in idle mode. Also remember to turn on the switch before ignition. The ignition can take up to several cycles of the piezo pulse.
Those two pictures are showing the detail of the piezo and the free energy being started in dark. You can see the visible high voltage electric spark. Also note that the piezo, unlike the non-overutiny elements, has only a single wire and no return wire.
Last pair of the photos shows the electric loop free energy generator in loaded state. It can be loaded even with a 2 kW heating unit!
Добавлено: Вс янв 27, 2013 22:01
1. если удивляет - попробуйте повторить :) вот повторенный опыт, который могут повторить и другие - это ценно... а фейками весть интернет забит, на их создание работает армия флудеров на зарплатах.
2. есть, даже где-то тут обсуждалось. Но всегда этот хоум-мейд чем-то ограничен либо навыки и оборудование не для начинающего, либо будет шумно и тд.
В большинстве случаев реально чисто электрические схемы (без механики, электролизеров-генераторов и тд) не дадут никогда привычные 220 и вообще классический ток. Греть, светить и прочее - будет. Но это будет "холодное" и оно обладает рядом принципиальных особенностей.
Самый простой способ вернуть его к привычному нам, а на самом деле кривому 220 , это вертеть им мотор с генератором на валу- опять шум, дорого и не удобно.
Поэтому все эти дергания должны иметь веский смысл. Просто дешевой экономии так не получить. Сборка и отладка потребует денег и хлопот. Для большинства поэтому сие не целесообразно.
Кстати большинство современных электромобилей вроде ниссана и теслы содержат скрытый источник. Только у них маячок, двигательная установка и батарея покупателю не принадлежат, обслуживание пожизенно только в фирменно центре и тд.
А так там просто баланс не сходится входа и выхода.
Посчитайте сколько проедет хороший, специально облегченный гибрид вроде тойта-приус на одной батарее и сколько проедет та же тесла. А потом поинтересуйтесь сколько она скушает от зарядки киловатт часов и сколько весит (в сравнении с приусом, где все облегчено).
Теслы в живую не видел, а ниссан электрический на роснано в прошлом году видел - тяжелый полноценный седан. заряжается за 8 часов, потребляет 3квт (24 квт часа =полная зарядка).
пробег декларирован имхо около 300 или 250. Называется не смешите меня....
Так что вопрос не в том как, а в том выгодно ли, раньше многое было относительно просто делать на колене. Сейчас немного другое время - любое штучное производство по определению дорого...
Добавлено: Вс янв 27, 2013 23:21
Igor
Михаил_ писал(а):на их создание работает армия флудеров на зарплатах.
Есть мнение, что это делается для того чтобы спрятать крупицу действительно стоящих идей в громадных потоках фейков.
Это защита существующей системы от фактора "гениального одиночки" который у себя в подвале может сделать "вечный двигатель" и благородства ради выложит технологию на ютуб. А так как все поисковые запросы уже засраны фейками его гениальное изобретение так и уйдет в небытие.
По теме: все приведенные ролики - фейк, их распространение это ваш вклад в сокрытие действительно полезной информации...
...делайте выводы.
Добавлено: Вс янв 27, 2013 23:48
фейт тоже бывает разных типов. Один оринетирован на формирование мнения у неподготовленных читателей(это типа вышеприведенных). Другой - на технически грамотных и реально ищущих. Для них нужен более изощренный фейк. Недавно такой наблюдался в очередном обострении рунет-части :) и так красиво по классике соотв. курсов был отработан, что мне было искренне жаль тех, кто так держится за свое служебное жалование и берет на себя отвественность за дурение голов такими играми, аукнется ведь прямо на здоровье и всем остальном, поскольку время не то и связь тут сработает прямая...
Добавлено: Пн янв 28, 2013 18:07
Искатель-2
большое спасибо.
ещё больше узнал о технологиях манипуляции.
век живи век учись
