Spirituality & The Brain
Александр_
And I would like to know have you used "Actor Brain" om ?
I'd love to buy it but the price .... so at least listen to what they say about him.
Whether or not this device cheaper counterparts ?
I met on the Internet mention about the Korean device Qjump.
To us Ukraine was introduced a little party for $ 600.
Can do the necessary thing to do is connect the headphone coil.Александр_ wrote:Thank you.
I'm specifically interested in your opinion about the device located at http://www.shaktitechnology.com/
Александр_
Wow !Андрей Патрушев wrote:Can do the necessary thing to do is connect the headphone coil.Александр_ wrote:Thank you.
With brain Hector I'm not familiar with Koganom too...
And it is possible from this place more in detail ?
Coil what type ?
What is the inductance ?
Can share how this works ?
Coil must be chosen such that the inductance does not exceed sanitary norms, and resistance, matched headphones. Works electromagnetic stimulation is exactly the opposite than light. In a healthy body is built a very powerful compensatory mechanisms for electromagnetic fields. So a healthy body the maximum suppressed frequency, the imposed electromagnetic field. Then, when the field is removed, the frequency of this according to the principle of the seesaw is pretty much increasing. In foreign literature there are mentions about the experiment, when the top filed of the electromagnetic pulses with a frequency 185Гц and, allegedly, people felt as similar to Satori...Александр_ wrote:Wow !Андрей Патрушев wrote:Can do the necessary thing to do is connect the headphone coil.Александр_ wrote:Thank you.
Coil what type ?
Александр_
Now everything is clearАндрей Патрушев wrote: Coil must be chosen such that the inductance does not exceed sanitary norms, and resistance, matched headphones. Works electromagnetic stimulation is exactly the opposite than light. In a healthy body is built a very powerful compensatory mechanisms for electromagnetic fields. So a healthy body the maximum suppressed frequency, the imposed electromagnetic field. Then, when the field is removed, the frequency of this according to the principle of the seesaw is pretty much increasing. In foreign literature there are mentions about the experiment, when the top filed of the electromagnetic pulses with a frequency 185Гц and, allegedly, people felt as similar to Satori...
Thank you.
Now you can chatuchack wind
Александр_
Nothing complicated.Dimas wrote:Eprst!!!!Wrap me one thread too please (essesno at a reasonable voznagrazhdenie)...And then I electronics forces are not strong...so Satori and all things...want to feel...! Huh?!
And I can imagine so wound as be found in "durke" unwinding!![]()
Formula the Internet is full of.
The algorithm is this.
Need to know the voltage at the output of the sound card.
Have someone there the line output of 250 mV, and I just cruise.
Of course a better amp.
Amplifier is the sound card of the old sample.
Need to dig the sanitary norms on permissible values of inductance.
And then on the basis of the voltage at the input coil and the permissible inductance, calculate the number of turns and wire diameter.
Formula the Internet is full of like and programok who do believe, but not harassed
In case of magnetic core, it is effective.
Wind the coil just like threads in the coil wound around.
Well, bring two wires to connect.
That's all.
And then I think you need to get the program to give the desired frequency.
I think Cubas fit.
And voila.
Александр_
Александр_
ЛИЛИТ
ЛИЛИТ
Not lost,Lilith,even I would say the opposite...I feel the taste of life...any "not that" the state may at any time to rectify..fortunately I have tools now full..now I can even without tools...And to buy a car at Moscow,Kola str., house 1 page 3...but You can see for yourself on this website in the contact section
Александр_
Александр_
I seen mention of Mitino, and Bird.Dimas wrote:yeah,from Maskall we...We have such have no market in my opinion...the Meadow is all in a civilian shopping centers dispersed...
So go for it.
Forums electronics poderzhi.
And by the way there are these kits - do it yourself, or how that on another is called, there generally is almost all assembled.
So if you want to tickle Sahasrara - look.
Александр_
okay.
you need to find a coil that would be issued inductance not higher sanitary standards (I don't know how many we need in the Internet to watch), and thus to the inductance issue when working from your sound card (what is the capacity of your zvukovoy - ask your local computer geeks).
zvukovojj there are several parameters - the voltage and current.
depends on which and power.
more accurate information can't give.
I have not yet dealt with this issue.
if you want, let's have a tandem.
are you looking for in Internet I need information, I process it and give you a turnkey solution.
Александр_
maybe tell Andrew.
the scheme is not needed.
we have computers for what you pay for.
the most important thing is the data on the inductance of the coil.
I found on the Internet so far nothing.
funny the fact that the request "sanitary norms inductance" Google gives mindmachine ru
we need to find the value of inductance in microhenry, or milihenry.
it looks like this : µh, mH or.
everything else I calculate.
Александр_
if English is good, then look here.
