Yesterday the tongue was anointed with hydrogen peroxide,no cigarettes not smoked yet...didn't even want...listen to the suggestion sesiju min.), at this time, several carried the technique of "stroke" from the "submodalities",and in the evening the tongue and the mouth wiped with a cotton discommoding peroxide (I got the recipe from "the messengers HLS" she read,telling people cool helps)...that is not smoke,current is a little hunting...smoke is not drawn,thought one to smoke to poeksperimentirovat-I can't,it's disgusting to even think.Mental state is great,sleep is great (Smoking history of 14 years,an average of 15 cigarettes per day).Plus breathing through Frolov disalca-like very;)))))Джим wrote:Bought, making sure it's not quite quackery (convinced the program SBaGen, but in her kit was only preview'shnye scripts). There were specific motives -- to quit Smoking (not great by itself, the feat -- 27 years total) + in this case it's OK to sleep + save resposabilty (a lot harder than just not Smoking, I assure you). In General, after experience with Amateur I wanted something proprietary, proven and no fans. Especially with the glasses. In General, paid off. Now again creeping into SBaGen on the PDA (on the wrong version, cat. published). Points is not enough, and good sessions to find easy -- but possible.
How to get rid of bad habits
- Владимир Никонов 2
- Has thanked: 20 times
- Been thanked: 28 times
Better not to start Smoking. One thought: "Why should I spend money to ruin your health"? leads to a healthy lifestyle. Well, if you started, then read the book of Allen Carr "Easy way to stop Smoking" - http://www.koob.ru/karr/easy_way_to_stop_smoking
That's how many people have quit Smoking - http://www.koob.ru/reference/karr/
>and water drink a lot
you need to drink to be able to - as much as all there in the books of Dr. B.
http://watercure.narod.ru/nadoznat.html
Here are the symptoms that clearly indicate the deficiency of water in Your body:
FEELING TIRED, A RUSH OF BLOOD TO THE FACE, THE UNCONTROLLED ANGER, ANXIETY, WEAKENING OF LIBIDO, DEPRESSION, CRAVING FOR ALCOHOL, SMOKING AND DRUGS.
>there is only the craving...Paul,can you briefly write how and how much to drink???
here's three Golden rules
1. DAILY DRINK WATER, Your body needs 30 grams of water for every 1 kg of Your weight. It is about 3% of your body weight.
For example: if Your weight is 70 kg, then You have 70*30=2100 grams of water daily, that is, 2100/200=10.5 cups of water. THIS IS YOUR DAILY NORM!
(and if there are problems, like Smoking, at random is added a certain amount of water, up to double the norm)
2. Your daily diet MUST BE SALT!
Salt helps to retain water in the intercellular space of the body. Any energetic processes in the body occur in the aquatic environment. The salinity of interstitial water the same as sea water. Use in food sea salt (it contains about 80 minerals Your body) 1/4 teaspoon for every 1 litre of water you drink. NOT DISSOLVE SALT IN WATER (hypertonic salt solution is not absorbed from the gut). After drinking the volume of water it is necessary to take(sub) language of a grain(pinch) of sea salt and dissolve in your mouth.
(without salt you do not work)
3. ELIMINATE beverages and foods that lead Your body to dehydration is CAFFEINE, ALCOHOL, BLACK TEA, SODAS AND SUGAR.
For example: 100 grams of tea drinking leads to the release of 130 grams of urine.
(only a complete rejection of these products will remove the deadlock)
it is clear that from morning 2 glasses after waking up. 1-2 cups 30 minutes before any meal. Through 2-2,5 hours after any meal 1-2 cups. For the hour before bedtime 1 Cup. All the rest of the amount of water you drink regularly an hour and a half.
Here's the forums with real people and real experience.
http://vodalechit.forum24.ru/
http://progrev.com/forum/index.php?PHPS ... &board=6.0
"Q - to quit drinking harmful should immediately? Il still can be gradually reduced to a minimum?"
It's like watching - if you drink a beer, something to compensate will have 2 cans of water. If you drink a jar of vodka, something to compensate will have at least 10 banks of the water. This also applies to coffee and tea: what kind of fortress tea, coffee - this will be the ratio of the incremental water.
And it is better to start without the harmful and harmful to suppress thirst again the water with salt.
"Water, I understand, it is necessary to drink bottled, not tap."
No difference - the main number. And the quality can be from the tap.
Speranza,this is only the first time the idea that more will never have to drink alcohol inspires some fear...Then everything is fine,you just have to get used to
for example I'm very glad I don't drink alcohol at all...life has become much more interesting...
Pavel,I am here today to 2500 liters of water were ususal,but she came out of me very fast..the night thinking about this trip in General,4 times woke up in the toilet (well that woke up
)...I understand she needs to stay in the body...What do I do wrong???Today I got the idea that salt I didn't eat...maybe due to this???But if water is trapped in the body,the morning person I can my in the mirror to see,or at least the eyes?
You are swollen from the night of water you drink???How much time You practice this water therapy?What do You give it???
"4 times woke up in the toilet (well that woke up"
drink 1 Cup an hour before bedtime
True...
take 4 litres of water and stir 1 teaspoon of sea salt without a hump.
"But if the water will stay in the body,the morning person I can my in the mirror to see,or at least the eyes?"
Depends on how long dabbled in coffee and tea. In the worst cases, the swelling will last a week.
"You don't swell at night, drinking of water???"
no
"How much time You practice this water therapy?What do You give it???"
3 weeks. Since I am coffee and tea has long been not dabble, the changes are barely noticeable.
Visual effects that can already be seen?
Skin fungus disappears. In the winter I froze my cheek, a dark spot had appeared on it too begins to fade. The skin begins in the sun Shine. Like a bald spot on his head began to disappear. Skin on the hands become soft, used to be very solid.
Subjective.
It seems to have lost much weight from the ass. After training is absolutely nothing aches the next day. Eat twice less than before. Energy two times more than it was before.
True...
no
Subjective.
>if not a secret (sorry for the tactless question for God's sake),how old are You??
as already mentioned, even less than that of demAs years of 1.5-2.
>About the cheek impressed me...what do You ugarazdilo???In Latvia...
And remember all winter it was autumn, and then gave over -30 degrees.
As we all know, people say, if I froze my cheeks, then all life will remain spots. As it turned out everything is a myth. Water is simply not enough for heavy and full restore/update of dead cells.
By the way is me, young, such subtle changes. And check out the forums (link already given) the reviews of those who have had heartburn, allergies, asthma, obesity, joint pain, and other unpleasant "illness", and who already uses water for a few months and years. Some of them are already under 50 years. Or read books of Dr. Batman, there's a lot of positive feedback on the treatment of water of different diseases.
Decided to drink the entire coffee, tea, alcohol that is purchased
And start a new life.
Pavel
Will bring the salt to work in a jar.
Question. I was 3 months ago was on a Diet Protasov. There was the obligatory drinking 2 litres of water a day. I have however, kidney is sick, the sand on the ultrasound. As with the kidneys have Vodopivec?
Pavel
On the previous page wrote that salt water does not dissolve, it is dissolved is not absorbed.Pavel wrote:take 4 litres of water and stir 1 teaspoon of sea salt without a hump.
There is a limit of 0.85%. This solution put the sick in hospitals - it's called physical. All that is more - 'll carry you to the toilet. Anything less will be absorbed into the body. Who wants to dissolve in water. Who wants puts on the language. Who wants to dissolve in water and puts on the language. Just always have different ways to calculate the amount of salt.Сперанца wrote:On the previous page wrote that salt water does not dissolve, it is dissolved is not absorbed.
the water is good. Themselves calculate the amount of water on the rate of the body and at random add another if sick or something. The main thing is to take water in the morning, before meals, after meals, before bedtime, and all the rest drank regularly after equal intervals of time: in an average hour.Сперанца wrote:Question. I was 3 months ago was on a Diet Protasov. There was the obligatory drinking 2 litres of water a day.
Yes, it's trouble. And here's her reason:Сперанца wrote:I Have however, kidney is sick, the sand on the ultrasound. Cool
Easier all the coffee, tea and alcohol to pour out and to pour into the bowl and press down.Сперанца wrote:Decided to drink the entire coffee, tea, alcohol that is purchased Laughing
Subject plaguing bytya the Golden rules of Dr. B. the buds are washed and become crystal clear. As the sand is formed by the concentration of waste products of the body, if the body enough water.Сперанца wrote:As with the kidneys have Vodopivec?
There is an objective indicator of the health of the body. If your urine is yellow, then you have trouble with dehydration (you already are sick, even if you consider yourself healthy). If your urine is dark yellow/orange color, then you have trouble with dehydration and a very strong imbalance of substances in the body (you already are sick, and then follows death).
The only true color of the urine of a healthy person - in the middle between transparent and light light yellow. If the color of urine you every day from morning to evening, before dinner, after dinner, before bedtime - your body is completely filled with water to the very last cell. This means that every cell in your body receives all the nutrient elements and substances, to live and perform its functions further. And no diseases.
Hmm..
On a diet it was
I would think. Quickly.
I usually have it. But every year I go through all the doctors. Special deviations. Not only can increase the white blood cell count to normal. Say lowered immunity.Pavel wrote:If your urine is dark yellow/orange color
On a diet it was
Pavel wrote:the middle ground between transparent and light-light yellow
