Output in the astral.
I'm interested in whether you can use a mind-machine to facilitate astral?
I have a Inner Pulse.
Maybe there is a special session?
What frequency is preferable for this? The type of breathing?
If anyone has experience, please share.
Re: astral.
Yes, of course!Buster13 wrote:I'm interested in whether you can use a mind-machine to facilitate astral?
Session for deep relaxation give a good effect. For Innerpulse special sessions there (but relaxation), but You can do (though boring). For Photosonixов there is only close session "Body asleep, mind awake", but the people complaining - "does not stick". I'll probably do (while pressed for time) for Photosonixов a couple of sessions.
And the frequency - the low bearing make low-alpha (and sync with green, better than blue), and high beta (respectively red) if You have such glasses (Indigo, Spectrum Pro).
Good luck running!
What is low and high load-bearing ? in terms of range ?
Can do drop a few lines about the creation of sessions (recommendations) ?
I'm here today realized that my example is not satisfied with the built-in session when working with transparent glasses. There is a brightness floats. I put the minimum (to glasses almost invisible was not interfered with), and they go out completely and then light up brightly.
In General, I have this intensity adjustment zadolbali
I will make myself for pustim session without changing the brightness.
That's four sessions for the WTO, established on different grounds, but have approximately the same effect (the key to success is the ability to relax. The volume and brightness minimum).
1. a) Carrying 192Гц (both), beats from 15Hz to 3 Hz for 5 min at 3 Hz Playground 5min b) несущая1 192Гц, beats 3, несущая2 384, beats 10 in 30min) несущая1 192, beats 10, несущая2 384Гц, beats 10Hz, 5-8mins. (If too hard at the exit, instead of 10, use 15Hz) For all stages of the OLL phase duty cycle (duty cycle) 10, the ramp, crossings ~1min.
2. a) Carrying 64Гц (both), beats from 15Hz to 7Гц for 5min on 5min 7Гц area b) несущая1 64Гц, beats 7Гц, несущая2 240Гц, beats 14Гц in) несущая1 192Гц, beats 10Hz, несущая2 384Гц, beats 10Hz, 5-8mins. (If too hard at the exit, instead use 10Hz 15Hz) For all stages of the OLL phase duty cycle (duty cycle) 10, the ramp, crossings ~1min.
3. a) Carrying 213Гц (both), beating 15-7Гц for 5min on 5min 7Гц area b) несущая1 213Гц, beats 7Гц, несущая2 213Гц, beats 14Гц, 30min in) несущая1 192Гц, beats 10Hz, несущая2 384Гц, beats 10Hz, 5-8mins. (If too hard at the exit, instead use 10Hz 15Hz) For all stages of the OLL phase duty cycle (duty cycle) 10, the ramp, crossings ~1min.
4. a) Carrying 64Гц (both), Beats from 15Hz to 2 Hz for 5 min at 2 Hz Playground 5min b) несущая1 64Гц, beats of 2 Hz, несущая2 960Гц, beats 15Hz, 30 minutes in) bearing 341Гц (both), beats 11Гц, 5-8mins. For all stages of the OLL phase, duty cycle (duty cycle) 10, the ramp, crossings ~1min.
Andrew, thank you very much, but the question was about something else.
Some above mention the use of glasses, Indigo, You wrote
As I understand it in the described sessions, the effect of Indigo is not in use or I do not understand ?
That made me curious - what frequency to synchronize with a blue and which red. Ie what in Your words is low and that high, because the knowledge is still superficial, ask questions, not to be confused with the terminology...And the frequency - the low bearing make low-alpha (and sync with green, better than blue), and high beta (respectively red) if You have such glasses (Indigo, Spectrum Pro).
When You start programming and start doing what I wrote here, you will understand that in a session only two stimulation frequencies, so You have little choice - the frequency more high, the less is low.
As far as I understand, Potashnikov there is no possibility of programming different frequencies for different colors simultaneously on both eyes (is that accuhist there is such a switch). The descriptions on the website have Photosonics Indigo and Spectrum Pro have such switches, then the sessions with monaurally by beating one frequency to be controlled, for example, red, second green, but I have these points from Photosonics not (go). When I wrote it, it was based on the experience with Proteasome.
The session that I described, is designed for dual binaural beats.
And you can spread these sessions ready to download at InnerPulse?Андрей Патрушев wrote:That's four sessions for the WTO, established on different grounds, but have approximately the same effect (the key to success is the ability to relax. The volume and brightness minimum).
These sessions I do not have - they need to do. While there is no time.Pavel wrote:"And you can spread these sessions ready to download at InnerPulse?"
I understand that using Lslib, you can edit session, but to write recipes for the WTO Patrushev is unlikely to succeed?!
No, the library can only view the session, nothing can be edited. This requires a special program.
Lord, no session may not give You the guarantee of access to the Astral.
If not ordered Tonal, says Castaneda, and not built alphacentauri (imho) that will get dirtiest - war, persecution, pork snout, etc. For each individual, to know if the leading frequency in each range on the EEG, you can still make a more or less effective session. If you use a "General" session, the probability that it will "stick", IMHO, about 20% of the total.
Good Luck Running!
Good Luck Running!
Dirtiest will still take place. The question is: do not add cleaning accumulated previously. That is one war or muzzle coped okay, but if tomorrow + war 2 and 3 of the muzzle to the residue, then the situation is bad.
I agree with Andreea, because I think that "to organize the Tonal" this is from some time not to add stuff on the Way.
Andrew, see my last topic in "where to start?"
I recently found a torrent with English CDs Monroe. In this regard, some questions have been raised.
There are two varinta these discs:
1. In mp3
2. In flac format.
First torrent 1,57 Gb weighs, but it cropped tops-bottoms(mp3 in fact).
The Second Of 5.22 Gb. In the second, judging by the size, nothing is cropped, but it is unknown how such a wonderful format to read. (This is just my opinion.. and I would like to hear the opinion of Andrey Patrushev - about this format and what happens to useful content, if the music is converted into this format.)
I hope to help.
There is still however a third option is to buy the original discs in the store gataway-sound.com but scares me why their cost.
1. In mp3
2. In flac format.
I hope to help.
Andrei Patrushev:
"For each individual, to know if the leading frequency in each range on the EEG, you can still make a more or less effective session."
To him the same question: Where can I make this EGG to determine the leading frequencies in each range?
You can come to a good clinic? And what to say to doctors, in terms of what they need to? Or is it not from the medical field?
And to say - "Do me please EEG and request the doctor to show the leading frequency in each band in conclusion, the EEG"(seriously)...И-Ван wrote:Andrei Patrushev:
If the doctor ask "Why?"the honest answer,say so and so, you need to develop individual alpha session for the publication of the "astral plane" to streamline Tonal, that climbs pig's snout and war...and...to follow closely the facial expression of the doctor...(just kidding)
Monroe drives do not lose in quality from the conversion to mp3 (of course, if certain rules are followed in coding)- there's the whole "kitchen" on the mid-frequency welded.Шум wrote:I Recently found a torrent with English CDs Monroe. In this regard, some questions have been raised.
1. In mp3
2. In flac format.
I hope to help.![]()
With flac I don't know.
A long time ago I did it, "an acquaintance". I was given a long "pants" and had to master the technique of deciphering EEG and ruler to count these frequencies. If we find such a case, it is necessary to search for computer processing of the results, since crawling through those tapes with a line of very tedious exercise.И-Ван wrote:Andrei Patrushev:
Or pay rubles five hundred (500) doctors are (best friend),so I decrypted everything and wrote the conclusion...Андрей Патрушев wrote:A long time ago I did it, "an acquaintance". I was given a long "pants" and had to master the technique of deciphering EEG and ruler to count these frequencies. If we find such a case, it is necessary to search for computer processing of the results, since crawling through those tapes with a line of very tedious exercise.И-Ван wrote:Andrei Patrushev:
Yes, on the website dreamhackers there is a response...Шум wrote:sometime, somewhere in the network, briefly, I read that astral travel to bring the practitioner or their relatives misfortune. Practitioner kindly share your views regarding this. Please.
PS Yesterday night, fell out of the body. For the first time. Here, now worried.
But take, for example, Robert Monroe. He, on the contrary, life in all respects has better.
Максимус
I think.."A knowledge increaseth sorrow." it's All about HOW you feel about this...has set the task to "temnye attacked - so be it..But Monroe not heard about Hackers Here...it was all wonderful...Андрей Патрушев wrote:Yes, on the website dreamhackers there is a response...Шум wrote:sometime, somewhere in the network, briefly, I read that astral travel to bring the practitioner or their relatives misfortune. Practitioner kindly share your views regarding this. Please.
Максимус
