The device is light and sound stimulation. Design points
Эго
Post by Эго » Sat Feb 24, 2007 12:12
Puzzled the mind of the machine under the control of the computer. Spread version of the requirements specification for the engineer.
Owners (happy :) ) points pvstim and other open models. Please share the photo design of the inner part (interested in the location of the LEDs).
At the moment there are some doubts:
1. (?) LEDs in transparent housing or matte. Matt (to protect eyes)
2. (?) In clusters 2 and 3 to remove the middle led (too close to the eyes).
Actually TK:
Device light control.
Controls 12 svetodiody.
The LEDs are divided into 4 cluster (of 3 LEDs each).
Turns out 2 of the cluster (left and right) on each eye.
Cluster LEDs included parallenno.
Lower goes first, then top, then middle.
Accordingly, when blanking out the brightness first decreases the brightness of the middle, then top and bottom.
Used LEDs or RGB (4 pin) or monochrome (1 output).
The device is controlled by software via the COM port.
At each cluster are sent 3 bytes (data of the brightness of the colors R,G,B).
In the case of single-color LEDs important is the brightness of the color R.
On the block device (or glasses) = mechanical regulator to adjust brightness.
With best wishes, Pavel
Post by Андрей Патрушев » Tue Mar 13, 2007 19:25
Honestly grya - not very clear... :D
You are looking for, who will do, or what to do? 8)
Why on Bluetooth or the infrared port from any switch, and then wire these "pulled up" already... :wink:
Post by Dimas » Wed Mar 14, 2007 12:26
:shock: :shock: :shock: 8) :roll:
Жека
Re: Device light and sound stimulation. Design points
Post by Жека » Fri Jun 08, 2007 20:46
Эго wrote:was Concerned with creating a mind machine running with the company.
Here there is about glasses http://offline.computerra.ru/offline/20 ... page2.html
Post by Андрей Патрушев » Fri Jun 08, 2007 20:57
This material plus diagram of the decoder audiostrobe we have on the website: http://www.mindmachine.ru/download/scheme.rar
Локи
Post by Локи » Fri Dec 28, 2007 21:42
A small Preface.
This site came honestly by accident, carefully read the forum for a week now :ay inspired "the whole thing" :) ,
for starters ordered the discs of Andrey Patrushev, waiting for them with anticipation :)
(Must begin with "Conductor").
What is called "life" I I prof electronic with more than 30 years of experience.
Hands grow "where necessary" :) so to develop / to make any kind of scheme for me is not such a problem.
Of course, the idea to make audiostrobe decoder (along with points)
Imho
I looked at the pattern of the decoder (LM567 on) ....
Hmm... so not woodhouselee :shock: and that's very good. understatement :(
The apparent simplicity of this shemki what is called "worse than stealing" :evil:
Ie here the case of primitivism circuit regenia,
which will obviously work to put it mildly nasty
(just assume from your rich enough electronics experience).
So in my head there was an idea much more correct and a much better decoder.
- For myself, I'm going to do :)
As it will be purely Amateur, not commercial design,
if anyone is interested, I will share the schematic and PCB layout.
PS
All present best wishes for the new year :) az
Андрей Константинов
Post by Андрей Константинов » Thu Feb 28, 2008 13:56
Эго wrote:was Concerned with creating a mind machine running from a computer
I did this Pribluda 10 years ago, but, for simplicity, connect one led directly without a current limiting resistor, to the address bus LPT port. Everything worked, no LEDs, no ports - not burned out.
And the funny thing was, laid to soft, but has long since lost it. But, of course, if someone wants to increase the number of LEDs, or use more powerful, you will need to use foreign keys (Yes, even ULN2003) and Pitalovo.
Кузьма
Post by Кузьма » Mon Mar 17, 2008 23:43
Локи wrote: So in my head there was an idea much more correct and a much better decoder.
if anyone is interested, I will share the schematic and PCB layout.az
Interesting! Loki, please share.
Post by Guest » Sun May 04, 2008 2:59
Hello,
I have a ColorTrack Glasses , that's just not figured out how to adjust the color, except for white, nothing....and glasses only connection with the car,what to do?
Post by Dimas » Sun May 04, 2008 11:41
So You don't color the track!
Post by Guest » Tue May 06, 2008 23:29
No, just color trek, from this site and ordered,
and the unfortunate buttons to change colors!
Post by Dimas » Wed May 07, 2008 12:23
Anonymous wrote:no, just color trek, from this site and ordered,
Well,side two black buttons there??the upper switching colors,lower brightness.And what color are they You Shine at work?
Post by Андрей Патрушев » Wed May 07, 2008 13:01
In Colortech white light there. Probably there was an error in the configuration or order.
Князевский
Post by Князевский » Thu May 08, 2008 15:24
Hey! All here!
anyone expected from this store NEPA and all that - see IT here!
happy now?!
Post by Guest » Fri May 09, 2008 22:38
I do not agree, there is no "NEPA" can not be a mistake rather
you evil knyazivs'ke
Post by Guest » Fri May 09, 2008 23:22
or am I stupid because I have a ColorTrack glasses in appearance coincide exactly with the picture on the website, mirror glass, adjustable lugs
and when the LEDs 4 on each eyes glow white :roll:
Post by Андрей Патрушев » Sat May 10, 2008 15:47
Anonymous wrote:or am I stupid because I have a ColorTrack glasses in appearance coincide exactly with the picture on the website, mirror glass, adjustable lugs
Of course, this is a mistake.
Have Colortrack for each eye only one led, or rather matrix, but it looks like one.
Post by Dimas » Mon May 12, 2008 12:51
Please write to us a letter of how much You paid for what you ordered.A copy of the warranty.Send us the erroneous points and we will send You Colortree.Yes it is a bug in the color only one diode on the eyes,You probably sent Premium white.
Князевский
Post by Князевский » Mon May 12, 2008 21:34
Anonymous wrote:don't agree, no "NEPA" can not be a mistake rather
I'm not angry :oops:
is this sarcasm :evil:
just some people on this forum need such messages.
And the problem will soon correct local :)
so uzho was service full.
Ростислав
Has thanked: 35 times
Been thanked: 28 times
Post by Ростислав » Wed Dec 03, 2008 0:33
Someone here shemku promised to lay out? Really looking forward to the ATO that here shemka work absolutely correctly! The LEDs only light up on the voice no audiostrobe!
Звяга
Post by Звяга » Wed Dec 29, 2010 12:21
Rostislav
if the topic is interesting, I can upload my prog and the scheme of three harness, 2 resistor and 2 LEDs to create points from the COM port of the computer. And then I'm in the "hands" unsubscribed, but the reaction is zero, all sort of nonsense on more than 70 pages mold with epoxy and other...
Preferably, unsubscribe or ICQ, or email, to be able to test the program, not only me.
Ростислав
Post by Ростислав » Thu Dec 30, 2010 15:39
Swaga write here now I have your pattern!!!
Экко
Has thanked: 2 times
Been thanked: 4 times
Post by Экко » Sat Jan 01, 2011 20:09
This is so?? I konesh have a reaction to other frequencies, but the gate reacts completely
Звяга
Post by Звяга » Sun Jan 02, 2011 9:25
The scheme is points- Image
http://ifolder.ru/21118638 - a link to the program.
Now a little need to explain, the program catches the sound from stereomixer. How do I enable it including the seven written here - http://bascom.at.ua/publ/cvetomuzykalny ... e/1-1-0-40,
the setup program saves in the folder from which you are running. If you have any more questions - ask, do not hesitate.
the resistors are chosen in case on com-port you have +12 and -12. If the voltages differ, then you need to recalculate the resistors - here's a calculator http://www.casemods.ru/services/raschet_rezistora.html
Ростислав
Post by Ростислав » Sun Jan 02, 2011 17:50
but what if there is no Comporta on the computer?
