Discussion of InnerPulse sessions
Installation and discussion
Владимир Никонов 2
Has thanked: 20 times
Been thanked: 28 times
Post by Владимир Никонов 2 » Sat Feb 24, 2007 1:07
I suggest this topic to share their impressions of the session in mindmachine InnerPulse.
Влад Н.
Post by Влад Н. » Sat Feb 24, 2007 8:49
Hello!!!!
I have already raised this question in one of the forums.. No one yet did not answer ... Decided to repeat once again..
Tell me, has anyone tried to change the time (duration) of respiratory sessions in the InnerPulse?
I have no as it does not work..
The instructions stated that in order to enter this mode
Quote:
Click PLAY
When Cesia will begin, press Select until the mode oPL
Then press the PLAY
Press SELECT to BSd
The UP and DOWN buttons you can change the parameter from 1 to 4.
Press PLAY to save the parameter value...
But really, when you're in respiratory sesi mode, pressing the SELECT any mode oPL does not occur.
Which is very strange, in the rest of the sessions (relaxation, meditation, and training .t.d) you can easily change this setting and all functions are available. But the modified value is not in any way preserved. And when I start the session "square breathing" breathing is slowed
If anyone knew how to change InnerPulse time breathing sessions help...
Thanks in advance for the answer!!!!
Post by Dimas » Sat Feb 24, 2007 22:33
Vlad,how to get to your car,be sure to try and write...I think I changed the duration of the breathing session...
Pavel
Post by Pavel » Fri Mar 02, 2007 12:04
I liked the session "sports wave", however felt nothing after it (first time listening), but when he took off his glasses (glasses Coatrack - white filter - brightness high), I saw a small, bright, yellowish-white particles of energy/power/charge our space, evenly distributed and floating in my room.
I liked the session "sweet dreams" (first time listening) - the head indeed was a pleasant feeling, but the body is a spread head wanted to sleep, and the body is not.
Re: Discussion of InnerPulse sessions
Post by Андрей Патрушев » Fri Mar 02, 2007 21:55
Влад Н. wrote:Hello!!!!
Quote:
Click PLAY
Then press the PLAY
Press SELECT to BSd
Sorry, Vlad.
Somehow I missed Your question.
The duration of the sessions varies in the same way as others. What You tried to do is the retardation factor. For example, the first 6 breaths per minute at the end of - 5 (etc.)
Влад Н.
Post by Влад Н. » Sat Mar 03, 2007 8:51
I'm probably not quite correctly raised the question..
I'm trying to slow down the duration of breath.. Example: quadratic breathing 4S/4C/4C/4C.
But I this does not work...
No mode sesii such a function. The manual says, and the MSB really do not make..
Павел
Post by Павел » Wed Mar 21, 2007 0:02
Andrew! Vlad raises the question correctly. I also did not get shorter, longer time delays of breathing. I also chose options from 1 to 4, but nothing has changed.
The task does not choose the entire session, namely to adjust the elongation of the inhalation and exhalation-delay, that is just Tikal.
Павел
Post by Павел » Wed Mar 21, 2007 0:11
I'm working with intelligence trainer and before class began to use seiyu L-1. And very clearly felt the improvement of the exercise.
The workshop itself went more quickly. :D
I can still say that after much fatigue from the night shift, I'm in the lunchtime session include a NAP. Very effective and refreshing training.
Continue to work, as the Bud slept the night.
Post by Андрей Патрушев » Wed Mar 21, 2007 11:26
Влад Н. wrote:I'm probably not quite correctly raised the question..
It's even easier. At the moment the session, the first five cycles are in the setup mode. On the breath hold button, then let go, then paused also, etc.
Pavel
Post by Pavel » Mon Jun 04, 2007 10:42
A little scary story about how I listened to S04 of innerpulse. :wink:
To sleep at night as a little like: was the rise of energy, 2 nights, eyes felt heavy, but the desire to sleep was not.
Deciding to resolve the issue a mind-machine, chose S04 session and setting the session duration to the maximum brightness and the sound on low, began to listen.
Thoughts were running around - did not want to sleep. Suddenly the sound began to pressure me, but to rise could not, like the shot glasses, I opened my eyes and I see flashes of light around me and can't move - and the subconscious mind played a cruel joke with me :? from a fit of fright/surprise, I realized that I was the little green men/UFO :roll: - instantly and immediately realized that the glasses still on his eyes threw glasses, the headphones are taken off. :P And all has disappeared :P
And that brought the Golden rule of hardcorse machines: "If you think that you - first check whether you are wearing sunglasses and headphones".
Post by Андрей Патрушев » Mon Jun 04, 2007 10:53
Yes, it is...
Correctly say: "the Only thing necessary in life to fear is your own fear." :wink:
Влад
Post by Влад » Mon Jun 25, 2007 0:38
R05 listened to before bed, on high volume and brightness. I felt the movement of the phantom body, the body was held vibration. Why is it considered that the sessions relaxes gradually, but somewhere in the 15th minute felt a sharp relaxation. :)
Влад
Post by Влад » Mon Jun 25, 2007 1:19
A question about P4( frequency range of 30-40).
I understand, it's almost not a beta and the beginning of the range. As far as I remember gamma is observed when solving problems that require maximum concentration of attention. Why not ispolzuetsa in the sessions on training? :o
Why no sessions above 40?
Post by Андрей Патрушев » Mon Jun 25, 2007 9:03
Влад wrote:a Question about P4( frequency range of 30-40).
Because the range of brain reactions to sound and light stimuli 8-25Hz. Everything else - "Zmeinoe oil"... :D
Александр_
Post by Александр_ » Tue Jul 10, 2007 14:20
Guys, who tested additional sessions are posted on the website of photosonics ?
I'm at work with alpha and other session never tried.
Post by Dimas » Wed Jul 11, 2007 13:12
I tested almost all..(since purchase)...but mainly for relaxation and sessions Andrew (like that no more)...alpha IMHO the best on me are..rarely listen to theta,sleep 2-3 hours a day and crap just any dream...But all in different ways...
Сперанца
Post by Сперанца » Sat Jul 14, 2007 12:44
Wow..
While the experience is not forgotten, share.
Just listening to your favorite seciu r07 and light music.
Time was 22 minutes.
Again, in the beginning pink :)
Tingling limbs, stronger legs.
Pressure on the chest, shallow dignie as impossible.
At the end of pink again. Was not there before. Then a bright flash, glasses went out, the sound died away slowly, almost a minute. Dark and dark, swaying as the night air over the fire.
Horoshooooo :roll:
And at the end of the session, the sour-metal taste in my mouth.
Swallowed a glass of water.
Развивающийся
Post by Развивающийся » Sat Jul 14, 2007 19:08
Guys, why do we need session Hut Ten Hut (P03) of section special offer?
Post by Андрей Патрушев » Sat Jul 14, 2007 21:59
Развивающийся wrote:Guys, why do we need session Hut Ten Hut (P03) of section special offer?
So because it says... :P
But in fact the usual alpha-beta session, which slightly cheerful (due to beta) and makes a good mood (due to alpha).
Развивающийся
Post by Развивающийся » Sun Jul 15, 2007 10:50
Андрей Патрушев wrote:because it says So... Razz
Yes I read, but not understood "Sound session for assistance in reducing distractions" :oops: what kind of distraction???
Turns out, it's much simpler, i.e. to generate a good mood.... the title of the session would have guessed ever :lol:
Post by Андрей Патрушев » Sun Jul 15, 2007 13:59
Reducing distractions is to increase the concentration. :D
Развивающийся
Post by Развивающийся » Wed Jul 18, 2007 21:41
Andrew, thank you!
Now I know, and beginners to use it (listen while only the alpha)?
Post by Андрей Патрушев » Thu Jul 19, 2007 2:51
Yes because everything is possible. Work with alpha frequencies for 3 weeks is only a recommendation, the implementation of which will help you to zanchitelno to move faster on the path of self-regulation and improve the quality of life... :D
Александр_
Post by Александр_ » Thu Jul 19, 2007 3:15
but I have finished the alpha 3 week.
now on the crossroads.
I think now to try all the sessions and look at the result, and yet consistently do on improv theta.
the training methods there.
here in mentalgaming very sensibly described.
and here how to be ?
Post by Dimas » Thu Jul 19, 2007 12:41
And here the feelings,Alexander! :) Hmm..Theta..?!Brave You...
