NAVIGATOR-2. The new firmware 3.12 (December 2018)
Алексей Крячко__
Been thanked: 17 times
Post by Алексей Крячко__ » Sun Dec 23, 2018 7:01
Good day to all !
For Navigator 2 was released new firmware, which were fixed some bugs in firmware 3.10. It is recommended to use.
Also in this firmware playback session is displayed at the beginning of the run. Otherwise on functionality, it is similar to 3.10, the statement would still.
This link is the archive which houses the new firmware and the file of programmer navprog3.exe service f_write.txt.
https://yadi.sk/d/w-EsTinOBGiSbA
Navigator-2 is stitched with the help of the program navprog3.exe
To write new firmware, do the following :
1. translate the device into the programming mode. From the menu "service" -> "replacement program".
Then to turn it off.
2. Connect to USB and switch the unit on. The screen should be black and should illuminate a white led.
3. The device should be detected by Windows.
4. Follow the programming instructions (link below) to install the driver.
Specify to install the driver link below.
5. To unzip the program for the firmware archive navprog3.zip (link below)
6. To copy one folder to the program contents of the archive with the firmware, including file f_write.txt. link to this archive is the first in the message.
7. start navprog3.exe
Driver resetter
https://yadi.sk/d/WPUrhYON3U4wjG
unzip and specify the contents of this folder during the installation !
The file is a new program for firmware Navigator 2 (referred to as navprog3.exe archived zip) :
https://yadi.sk/d/wiMGZE6d3UhFBs
Description programming. It is made even for the first program that is designed for the Navigator-1.
But its essence remains the same, except the check code of the firmware of the Navigator-2. If it is not - will not work.
https://yadi.sk/i/qNad1QPM3LBaPr<
Владимир Никонов 2
Has thanked: 20 times
Been thanked: 28 times
Post by Владимир Никонов 2 » Thu Apr 11, 2019 13:28
Updated one minute(!) in Windows 10.
Have prepared a complete set to update the link:
For all the updates in one file to:
http://mindmachine.ru/download/navigato ... er312).zip
update:
1) Download the archive and unpack it.
2) Put the Navigator in the programming mode. Depending on your firmware version 'Navigator' this menu is located, or in 'settings' -> 'Replacement program' or 'Service' -> 'Replacement program'. Click on the menu and turn off the instrument.
3) Turn on the device. The screen should be black and should illuminate a white led.
4) Connect via USB the Navigator to the computer. Windows 10 detects the device and no drivers no need to install. For other versions of Windows, it is possible that you will need to specify manually the driver from the DRIVER folder (is in the archive).
5) From the folder "navig2_v312" start file "navprog3.exe".
The firmware file (binary) should also be in the folder "navprog3.exe" (by default it is there).
To enjoy the process. Your device updated!
