Cleaning of premises from Entities
Purely by chance. Worked with a friend to get rid of fears. The process originated in the mind some scheme to use one of my existing products. Made preparations Sunday, may 13. On Monday, may 14, brought to him the product. Launched. Waited three hours. All say your Artifact is ready. We sat and talked for an hour. But something did not let me rest.
The question is, what we were doing him some sort of artifact worn in a special way. And here talking and wondering why I decided to wear this subject probably not necessary. But what to do, I don't know. Let's burn? Let's say, I have a lot of papers have accumulated, going to burn, let's go to the garage. I lit the paper and threw it in the manufactured Artifact. When the paper burned, I saw this. From the shot, saw this. Took the last 6 minutes.
Apparently it seems to the Entity. Yesterday showed a video of a strong clairvoyant. Confirmed they say Yes, the Essence was lost. As they say you get stuck/attached.
Thus,
1. By chance there was a real method of cleaning of premises from Entities.
2. It seems we cannot even imagine the world in which they live. Negative Entities far more than we imagine. And their impact on our lives, health, everyday life is much stronger than we think.
3. For help need not apply. Not because of my boorishness, but because of the nature of the method. This cleaning is only possible while living in the same city.
Thus,
Re: cleaning of premises from Entities
Today decided to repeat the cleaning. Carried out preparatory work. Produced Artifact/trap/subject/material carrier. Looks like this. However, this square. One was rectangular. But that does not matter. Now he is in the picture before sending him into the fire.
Simply dying the material object. No Energy. Call clairvoyant, explain.
Well said, great! Clean room. And the fact that now you is not seen nothing, so this means one thing. The essence of the left in that first process.
Here, here!
Here, here!
CodeLooked , I left. The firebrand was burning and it was visible two eyes one mouth and horns))). you mean this? Looked at the stop of the stop-frame moments, where after you transfer , as you write -the artifact is, and so is this art to Shine a green light, although the red flame. On this 4.00 minute to continue, and then began to change colors on the blue , and 5.25, and all the colors of the rainbow))). But it is viewed in Stopgate. What art was and what sarasalai? if not a secret certainly?.
About it! Myself was amazed.ЛИЛИЯ-Р wrote:Watched , I left. The firebrand was burning and it was visible two eyes one mouth and horns))). you mean this?
Charged activated Harmonizer radiant right Torsion Field. Laid inside the base. Now someone go and sucked. As there was can neither think nor imagine. But the Essence has stuck to this Artifact. Not destroyed flew up through the product.ЛИЛИЯ-Р wrote:what art was and what sarasalai? if not a secret certainly?.
That laid the Foundation? Silent. There is no point in telling because no Harmonizer all meaningless.
Well, Yes!ЛИЛИЯ-Р wrote:tried ....more powerful .
Right that which I have this week cleaned the room. And it was like enough to have coped with their duties.
On the left is made at the request of the workers. Even the picture shows that it is more powerful. He and the merc and the size is higher. But I didn't use them. Manufactured and given.
From the sensations. Not like out of hand even release.
Code You have three rings ? Question to you , you feel celebrated and flows, for example, when just like this is garmoshka and you use it, the direction of energy in the direction of the rings? As pipes with flow in different directions ? kuvak on the stand-okontsovka like , energy kuweka? And okontsovka this harmonizer not observed , which thread? Although you wrote that the ring gives the thread to the top, but it is provided that it lies horizontally. And if it is put vertikalno, or at Humpty in different directions, the flows are from the rings pipe in the direction of the ring sent? in the same way? Inspired that if threads are needed in the space of about...then there is no okoncovke ring need to put accordion. But if the direction of flow in the top, then you need okoncovke ring. You can just put an a inside an accordion. So? Observations and and so powerful, but flows have different directions. And if headphones or speakers to prematurity))) then do ...
No, I have five large rings.ЛИЛИЯ-Р wrote:Code you Have three rings ?
I already did not feel. The feeling is, when you get used to the new Energies. And when it flows to you freely, feeling no.ЛИЛИЯ-Р wrote: Question to you , you feel celebrated and flow
No. I have a Harmonizer is in a certain place, I its location does not correlate to the location of the rings. Worth and worth. I did not feel. Although the first day, I almost took it to the garage. So sausage. But suffered.ЛИЛИЯ-Р wrote:just like this is garmoshka and you use it, the direction of energy in the direction of the rings?
No. All threads go straight up. Just different diameters of the pillars. Another thing is that the post Harmonizer overrides the pillars of Energy of all the rings together, and in an enabled state far beyond and flats and houses.ЛИЛИЯ-Р wrote:How to pipe with flow in different directions ?
No. And I and products Humpty, pillars of the Energy vertical. Only the right-hand product direct posts up, left hand down. Six months understand. Had also thought. If the ring is to direct parallel to the ground, and the Energy beam is parallel with the Ground. No, all products Torsion direction, to emit the field at an angle of 90 degrees to the Ground. Thus, the rings on the Harmonizer Humpty does not emit flows on different sides, as I previously thought. Only vertically. Another thing is that the ring used in the Harmonizer Humpty at an angle of 45 degrees, giving the post a vertical Energy of a smaller diameter than the ring located parallel to the Ground.ЛИЛИЯ-Р wrote:AND if it is put vertikalno, or at Humpty in different directions, the flows are from the rings pipe in the direction of the ring sent? in the same way?
I guess it is. But the fact that I'm making up my Harmonizer and brought it home, set it on the Desk in the office. Sausage. The gorge in the other room, next. The result is the same. Wearing restrictive ring. Useless. The whole evening suffered, wanted the garage to carry. So all night and procarbazine. Harmonizer in this performance very powerful. And my personal Energy at the time could not cope with such influx. Now I do not have a limiting ring. Used. Natural habitat. Neighbors, too, probably.ЛИЛИЯ-Р wrote:Inspired, what if the threads need in the space around...then there is no okoncovke ring need to put accordion. But if the direction of flow in the top, then you need okoncovke ring.
Only two directions. up or down.ЛИЛИЯ-Р wrote:but flows have different directions
Well, Yes. I now write, near the Harmonizer on my Desk, with speakers. Sound reproduction on a scale of laptop 24. Lively, feel good. Used.<ЛИЛИЯ-Р wrote:and if headphones or speakers to prematurity))) then do ...
When kuvake in essence stuck just burned the flame of the acetylene torch (pocket, 1200 deg.) But I'm not sure in the case of harmony it is also convenient and applicable... (Burned in the direction of suction.)
andreyko You can just it over the candle to put))) and beauty do not spoil and sumam spacing)))). Ie , sensing ... you will disappear , but will go to other place, but humanely)). But they can be accompanied, if they wish, from here and podalee))). With those who are working , who knows.
And what is the torsion field at Aku-Vaca? Right or left?АндрейКо wrote:When kuvake in essence stuck just burned the flame of the acetylene torch (pocket, 1200 deg.) But I'm not sure in the case of harmony it is also convenient and applicable... (Burned in the direction of suction.)
Clear! The answer will be. But judging by the photo Aku-Waka made their own and posted on the forum, we are talking about a left twist. That is, we are talking about Aku-waku inducing a Left Torsion Field.Код wrote:And what is the torsion field at Aku-Vaca? Right or left?АндрейКо wrote:When kuvake in essence stuck just burned the flame of the acetylene torch (pocket, 1200 deg.) But I'm not sure in the case of harmony it is also convenient and applicable... (Burned in the direction of suction.)
So. For Entities such CRA-Wack, like a home! They climb and nurtured and restored. What they rock residents that they began to radiate negativity. And climbed into the Ark VAK and zhiruy.
But I have something completely different. Harmonizer pravonarushenii. And they (the spirit)(or was she alone) is not reached in the Harmonizer for his pleasure. But I did absolutely nothing. I made an Artifact of a special kind! I tried this Artifact energize FOR CONTINUOUS WEAR PERSON!!!
And the fact that climbed and clung Essence I had no idea that it would be. Yes and no would know it if I suddenly got the idea of this Artifact is to burn.
The following happened. Artifact related Entity was filled with Energy and Essence, like a moth to a light dove into the Harmonizer. And to get out there are unable. Because the Harmonizer has been activated, and the circulating flows of transformed Energy. In the right. And Essence just weakened. In three hours or less. Stuck to the Artifact.
Consequently, the operation of the left Aku-Vaca to attract to themselves Entities for permanent residence and transforming Harmonizer left to right are two different things.
When will we learn all how to read and correctly understand - the mystery.
And again. This unique I received the result - not a sign of my great mind. All happened by chance. Did one thing, got another. And then only one conclusion. THIS UNIQUE METHOD of CLEANING of the ROOM BROUGHT TO ME from the OUTSIDE!<
Will not work. To accompany and so on. For this you need.ЛИЛИЯ-Р wrote:andreyko You can just it over the candle to put))) and beauty do not spoil and sumam spacing)))). Ie , sensing ... you will disappear , but will go to other place, but humanely)). But they can be accompanied, if they wish, from here and podalee))). With those who are working , who knows.
1. To see them
2. Know how they (each) to manage.
All Entities arise in different ways and in different situations and conditions. Unified team/mantras/prayers for all Entities does not exist.
And even for a while will be able the kind of mental where it to take, it will come back.
BECAUSE THIS is HER HOUSE!
And then it is only about destruction.
BECAUSE IT's a MATERIAL WORLD AND THIS ROOM IS MY HOME!
And Nature already in this situation, is faced with a choice. To die here, or you can blame and look for a new place to live.
For two years I have a Harmonizer. Worth standing in the corner.Код wrote:Because the Harmonizer has been activated, and the circulating flows of transformed Energy. In the right. And Essence just weakened.
But week he every day from morning to evening activated sounds. Moreover, with the selection of audio tracks do not bother. A bunch of clips in the library. Start it all on repeat. And so the whole day
And only now realized the value of pravonarushenii of the Harmonizer.
It seems that as the emery all energograd blows. And because nothing will make dirty the Subtle World. Rigidly welded piece of iron. No electronics. And most importantly. No programs!
By the way, I guess. Negative Entities can get into it, but they probably transformirovalsya and purified. This statement is controversial and based only on the principles of functioning of the product.
Therefore, to prove and to say nothing will. Only the assumption.
Need time, and probably decent, more thorough conclusions.
I'm sorry, Lily, that's right!Код wrote:LILIYA-R wrote(a):
Here is an excerpt from the letter W skatova, manufacturer Tensiometers.
for Example, a simple circle (even in a picture) allows the essential circulation of the azimuthal flow in both directions.
The choice of the nature of the external perturbation.
Essential azimuthal flow is a flow in the direction direction of the ring. Like Humpty in different directions looking ring, and flows in different directions. Not so simple, external influence is present, but in General.
I do not quite understand, to clean a person or area? He left there fears from a friend after the procedure?
I had the experience of handling estates, the truth had to enlist the help of a priest and fumigation of incense several times. there we fucked up, it got to the point that the doors inside were closed and things were missing, and some appear, I do this for the first time met.. So the effect was temporary. We moved out, and no one was there. But interestingly, those who lived there before us, they had problems even bigger than the door closed(found out after) , at us too not all right, and after us residents have noted nothing unusual. How is this interaction and living as entering into the apartment building to check on the compatibility of housing?
Originally intended cleaning person. Through wearing yourself in a special way charged Artifact. The artifact is charged in the room. And then for some reason I felt that this Artifact must be burned. The wearing of when does not a fact (wasn't sure) will benefit.Аине wrote: I do not quite understand, to clean a person or area?
The result is cleaning of the room.
Were not the original goal to remove all fears. Just to make life easier in the material sense. But yeah, as something better has now become, as he explains. A few orders for work came up. Sleep was better.Аине wrote:Left whether fears of a comrade after the procedure?
I do not know. But there are unique/universal Board.Аине wrote: How is this interaction and living as entering into the apartment building to check on the compatibility of housing?
Before you move into an apartment used, to find out where he moved the old tenants.
If they moved to something better,closer to new, more interesting and more profitable work, and the like, in General, improved - feel free to come and see me in this apartment.
If the case of tenants who lived before You in this apartment has deteriorated - look for another option.
Continued experiments with the Harmonizer.
What came.
1. Harmonizer generating a Right Torsion Field, you need to keep as low as possible. In this case, on the floor. Due to the fact that the generated Field is directed from the bottom up, so you need that he would have captured all the space from the bottom.
2. On this picture you can see that the Harmonizer being on the floor and when activated sounds, irradiates attached at the top of the pouch with something inside. Many of the members of the forum know what the transfer pair. This is a pair of objects with identical, related properties. Including in terms of Energy. And if one of the objects of this pair changes the energy, changes it and the second object, at whatever distance from each other, they were not. To create transfer pair, we took the crystal "Tiger eye," smashed him with a hammer. Great piece and crumbs of the crystal was placed here in this blue sack and tied the top. And 6 small pieces, placed in a specially made 6 little bags, and sewed them. These little baggies, comrade fastened by pins at the bottom of the leg and travels with them all day. At night Harmonizer puts it under a bed somewhere in the region of the feet. The effect is magnificent. There was a lightness in his movements, walking. Very greatly increased personal Energy. The conclusion follows. But first, another excerpt from my correspondence with T by Sitovym, developer devices Tensiometers. About it, at least here. http://www.trinitas.ru/rus/doc/0231/004a/02311037.htm
In the opinion, not just my opinion, right rotation is somehow the backbone, and the left be randomized, or the backbone, but for some other structures, for us negative.
I often return to these words. Especially that left rotation is the system for negative human bodies!
And only recently realized that the NEGATIVE HUMAN STRUCTURE - THIS is the essence of PARASITIC ON the ENERGY of the MAN!
So!!!! This means that the Entities generated by the Left Torsion Field. And if placed in the Right-hand Torsion Field, they will either be destroyed, or flee or die. The man without a difference, as there will be a purification, if only his personal power has increased. So, simply, gradually, not Intrusive come to strikingly useful things.
My guess. Entities are attached to us from the bottom, overlapping the lower root Chakra - Muladhara. In the end, the person is not having the right amount of vital Energy, eats more. Food is processed and digested worse (again due to lack of energy) and the man gets fatter. That is, Essence and stick at the bottom. That's why the Harmonizer for the night under the bed in the area of the feet, and pieces of crystal down there pants. That would be radiated and generate the Right Torsion Field. What will happen with the Essence - it's her problem. No it is not called.<
What came.
Thank You, that's very interesting!
It seemed to me that people get fat due to the fact that on the contrary there is no escape energy. And she materializes in sediments. And there is no escape, maybe the upper connection scored all sorts of life stuff or personal characteristics. And the hypertension often. And the lower connection does not work for example, because there is someone who as acquired valve type things. Eats overabundance of energy. That's cats for example, often choose places according to your some thoughts. I had a cat that slept exclusively on my head. I have the top connection is blown, if I may say so. And the bottom does not work. The weight gain is generally not obtained.Someone cats sleep downstairs on the contrary, in the legs. Can they regulate somehow thereby flows and podlucky?
We can assume so!Аине wrote:it seemed to Me that people get fat due to the fact that on the contrary there is no escape energy.
But it is correct to assume that people get fat because they do not have INPUT the right amount of energy. This is especially evident on the mid-level entrepreneurs. If you know him, slender and clear, and now I see a thick or full, you can be sure that their business stopped, or his deeds become worse and the problems of succession.
Everything on Earth grows out of the Ground. Plants, herbs, algae and so on. People, animals including, grow up. Consequently, the life Energy we receive from the bottom. Activation and development of the lower Chakra, the Muladhara, in that case, a priority! That is why now the Harmonizer is used as such. Is under the bed in the center of the feet. And shards of crystal are attached at the bottom of the legs. It's summer, we need to walk barefoot on the open ground. To break/to activate the energy channels of the feet.
Entities/parasites fasten from below and devour our energy, swollen creatures and get fat. And man there is eventually enough energy and strength to active actions.
And so it is for world peace, friendship between peoples and universal love! It had a justification for his involuntary weakness and weakness of character.
Stress. INVOLUNTARY AND UNCONSCIOUS EXCUSE!
And not the recognition of necessity!
Oh, and can I then my two cents....?)))))Код wrote:ainé wrote(a):
We can assume so!
And I have other observations there too . And those that you have that get fat from the fact that all I am sick and Nikes personal life is no business...)) And others..on the contrary. When I was working in the lab , trained new technicians not sure how much)), they after or during studying at the Institute came to us to work or earn money. So, when I teach on the spices)), and he immediately to engineer or above at the office)), and then begins......Were all slender , slender and then the "armor" on her stomach, and then across the body ,over time. I think it's the responsibility of such protection works. As in women during pregnancy, immediately carries)). The stock has never stopped anyone moderate. But ,if in time not to stop such a margin, the disease is imminent. About energy, I think ,as one is not enough , replenish food, do supply the body itself is able on occasion :"Suddenly the war , and you're tired ,we are hungry..." )) Like in the cartoon.
And Vice versa is losing weight , not from nerves , but just from joy , from raising ...and other delights with this.
There is likely a fear -reason. Who's afraid of that weight being added, who on the contrary has thrown off why such protection if it was already super...))
Yes!Нездешний wrote:it Turns out that Your harmonizer destroys the entity
But about the fact that the harmonizer Humpty breeds of Entities, I wouldn't make such conclusions.
My Harmonizer spins Back to the right and it is disastrous for the Entities. But essentially, it's some Energy-organisms, their programs/settings. Harmonizer Humpty no settings does not. Turns Back to the left and just. Rather, it can give them nourishment, but produce no fruit.
