Product ЛОМ1, a powerful modifier of the Operator and the reality :)
ЛОМ1
The product "local disconnection matrix", version1.
What is "the matrix" is a component of social gaming person, in many reports to have an artificial origin, creating the illusion instead of the real perception of the world.
The question may arise - "am I a different world will see? How so?" The best answer is the user reviews free handmade items, collected at the two forums showing the multifaceted aspects and manifestations of "disconnect" from the matrix (also called in another terminology system).
(reviews and instructions for making homemade look here:
viewtopic.php?f=31&t=6682
http://support.quantummagic.org/showthread.php?t=380
Reviews I recommend to read on their own, in short we can say that the result is:
- enhanced focus on their work processes
- burst of energy
- feeling "in the tank", the security (although the product does not provide protection, but in this mode a lot more protected from external influences of any kind by itself)
- a more clear consciousness, understanding of external processes, including manipulative in relation to the person
- a clearer understanding of their true desires
- strong increase of its influence on eventfulness, lightweight implementation of ideas and goals
- strengthening the work of all our and not only products
- changes up to the visual perception of the world and objects (some noted spontaneous vision of "aura" even homemade)
more
Separately it should be noted that state on ЛОМ1, is completely different while using ruler (or 3.0) and without it. For users of arbiter and 3.0 ЛОМ1 is a recommended product, significantly enhancing the efficiency of the operator of the status thereof.
For a number of people under the influence of the product is possible uncomfortable state associated with awareness or subconscious perception of the difference their everyday purposes from the inner true aims, the futility of current life trends. In such cases it is recommended to dose application of the product, or to weaken his mental capacity, at the same time working on long and/or short-term true purpose (to find an outlet for creative self-realization/Hobbies and so on).
I note that most of the first reviews (27 March 2018года) was written WITHOUT a description of the functionality of the handmade, so actually there is no "placebo" effect or, as some say, the modulation description of perception and the psyche testing. In fact, they didn't know what to expect and generally in what area and scope of works homemade "Scrap".
The commercial version of the product in view of its universality was the wide range of products
1) ЛОМ1 - base. This product, with Pandora black, more soft and comfortable, due to the internal regulation of the "capacity" of the product than homemade. Execution — a plastic card, the value 20t.
2) ЛОМ1 — Pro (professional). This product is in the form of a plastic card and bracelet, includes 3 cards of the same Лом1 base and bracelet made of black wood, with a similar program. The product is in Pro version allows you to increase the potential of impact both on the operator and extend it to its social environment (under the action of the product fall into the other people), focus is the mental control of the operator. The cost of 60t.
3) ЛОМ1 — stream. Stream functionality ЛОМ1 2 slot stream, the value of 2T may be combined with physical products or broadcasts (for lovers only use the event in your Arsenal). As always a possible connection to a group or object, which makes it at least funny.
4) ЛОМ1 version E++ includes 5 cards Лом1 and bracelet manufacturing technology is similar to other bracelets E-version (wide BJ and ebony with links containing Galiev insertion), the product of increased power. Other opportunities for operators and wider coverage area of others.
The basic cost of 120t.<
- burst of energy
more
- Has thanked: 1 time
- Been thanked: 182 times
Re: Product ЛОМ1, a powerful modifier of the Operator and reality
Yes, of course, like most products.
Of course, not only possible, but necessary.
I will try to explain figurative language. Equipment I know that the radio signal is the polarization of the waves, which is often linear, t/e located in the same plane, in technical practice (sending and receiving) uses horizontal or vertical polarization. In General that many do not understand the technical terms in practice, for example, antenna of television with a bunch of sticks cross-dipoles, placed horizontally and not sideways, I think everyone saw.
Imagine that the system is the transmitter common signal that causes a perception of reality (for clarity, you can see some video on optical illusions to understand how consciousness is dependent in your perception from what is in the signal, distorting the obvious in favor of one-the overall picture-the context.
The system sends a context in which there is interference, changing the perception of the overall picture of reality. It can be neutral/useful/harmful. But since historical processes are now the most common version is harmful.
People - the foster system.
If we as the antenna will rotate to another plane (relatively speaking) that the system signal will be extremely weak and noisy. And in view of the personal genetic characteristics of the people will quickly adapt to the perception of images of reality without interference.
In Лом1 lies in this "detuning" of the signal and this basic, the rest is implementation details, and indirect effects from hetsroni (own operator)
Is it outlined?
Is it outlined?
Here is an example of more or less "live" optical illusions....
so to speak, for clarity, the conventions of our perception.
SCRAP allows you to break away from the perception of a distorted frequency channel, disable this frequency, the question that people foster system, she begins to perceive a specific frequency range? Or gets the opportunity to re-tune at will to the desired perceived frequency? In the settings there is an option to exclude this confounding range to the perception of default?
Back into the system no no, learn to live a new way.Тимоша wrote: Or receives the opportunity to re-tune at will to the desired perceived frequency?
I mean, sending by the first specific frequency, perhaps we are talking about pure signal without distortion of the system, once referred to the antenna shift to another plane, this implies that the perceived, any specific frequency, it is possible so to say...Where rehabilitation has already been given the video and other contexts... And question the product is automated or you need to give the mental command to turn on and off. And regulators, too, have the mental power amplification?
You are trying to literally interpret what was said on the fingers. The top has a bunch of channels and "lost a few" who tried you in a certain way bureaucratise you a lot to lose. For example, becoming an atheist, all the doors are not closed, you do not lose touch with society. Pay attention to the pros, except voiced and very significant is the protection from ranged magical effects, administered via the system channels.
Funny, I was in the beginning, when something happened with vision, thought, that I began to see everything in polarized light. Felt, but incorrectly interpreted (with quite oppositeМихаил_ wrote:of Course, not only possible, but necessary.
The product is of course automated, but can be controlled mentally (as a projection on the other, and the power and other parameters), there is still delicious stuff .... Which will be told separately.
On my forum asked a sea of questions, I will gradually respond (I received today) and answers will be moved too.
Can the SCRAP enhanced capacity to drive the human brain into the state of Samadhi? Samadhi is when the human brain is disabled at 100% of the thoughts for from 3-24 hours or 5-10 days. In this state, the brain works at the level of the Delta rhythm, as in deep sleep, this person is not sleeping, and meditating. After Samadhi begin to ispolnyatsya a desire and healing.
Владимир Ш.
- Has thanked: 19 times
- Been thanked: 34 times
This is standard practice, the price of the product, separated by about a year.
Vladimir in fact answered correctly, all 4 of item prices ЛОМ1 put on the bottom face, in functionality it can be assessed in the articles and broadcasts at the level of the actor. Just wish it was as accessible as possible (although for this there are homemade).ММ wrote:Stream SCRAP costs for 1 month is 2000 rubles? Not too expensive?
Stream in this case extends the functionality of the product, t/e it may be the first case where the stream and the product - not the same thing.
PS why do You ask ? then again, you write that "ahhh-did-not-working-enough-powerful-Torquay" and so on - or use homemade, it's free, and the "expensive" Express use of those who understand why.
"He is told before beautiful" (C) Vladimir VysotskyММ wrote:Can SCRAP the enhanced power to drive the human brain into the state of Samadhi? Samadhi is when the human brain is disabled at 100% of the thoughts for from 3-24 hours or 5-10 days. In this state, the brain works at the level of the Delta rhythm, as in deep sleep, this person is not sleeping, and meditating. After Samadhi begin to ispolnyatsya a desire and healing.
ЛОМ1 nowhere nothing drives. It helps to ensure that the person is disconnected from spurious signal and creates conditions for it. All further changes - it is the operator himself.
I pretty pins, when people write about what they heard somewhere or read it and accept it as it is written here.
In addition to my own experience there is no other criterion.
Many times and in different themes written that stopping the internal dialogue, the essence of the trip as a time system and internal parasite (which is also borotalco consciousness and integrated with the system). Stop VD among many is not through diligent practice all sorts of crap (as recommended by izoterika, although this does not mean that all their recommendations are complete nonsense), and often effectively mean cleaning the body using different methods (for example, people have written many times about stopping VD as a result of the course of treatment of ASD or other means of cleaning the body), and use of products and/or practices improve the energy of the cocoon. It is a complex work.
There is no doubt ЛОМ1 one of the most effective means for this. But is in the stopped state VD for a long time or not - this is the solution to/the desire/the need of an operator.
Of course there is state influence, says Goltis, the "eventfulness" (for example he is noted as the result of long-term treatment of fasting), but you have to understand that the operator needs to grow not only on the fact of switching it to the "special regime" but also on the internal state, the system of desires and values, otherwise it is primarily dangerous for the operator.
Know there is a Gypsy curse - to make all your wishes come true... it is very chernushny and evil, like one of the worst. I'm serious. We must first be able to desire creative and harmonious.
Fortunately usually the operator has auto-protect and it "picks" from the state of which you such terms mentioned due piles internal not social gorgalok with which it is not yet clear. If not break - Yes, it will. But I would not call it Samadhi, but not the essence.
Read the reviews - SCRAP (homemade) affects the eventfulness of its many uses. But not all. And that's GOOD.
You can not and will not be some "perfect" means that anyone brings up "embody what you want", otherwise reality will be bad. And, fortunately, this fuse - the internal state of each.
As people were writing about after using homemade ЛОМ1 "today while cleaning in the LM, it seemed to me that the product turns a cocoon... the deeper layers to the surface and with them a lot of dirt straight) tired of cleaning" does not cite the author of the quote, because it is not from another forum and private chat with practitioners.<
My job as a VIP client to write truthful reports on the work of certain products. But if the artifact does not work, then it's not my problem. For example, I wear 3 years in a woman's map, ask the modules, the result is zero. So what to write? Not working and not necessary. To hell with it.Михаил_ wrote:Vladimir in fact answered correctly, all 4 of item prices ЛОМ1 put on the bottom face, in functionality it can be assessed in the articles and broadcasts at the level of the actor. Just wish it was as accessible as possible (although for this there are homemade).ММ wrote:Stream SCRAP costs for 1 month is 2000 rubles? Not too expensive?
Products work with everyone, but not everyone is able to work with products. Possible to be covered by them in connection with their internal problems and unwillingness to change to zero results, in spite of the work products.
It would be VERY BAD if in such a situation (not your specifically, but in a situation when a person doesn't change) products would result.
It would be unnatural and bad for the individual and for the world, and gave rise would result in negative environmental reality.
We do not, that is definitely everything some sort of candy doing that, and what helps people to recover themselves I. your skills and reveal their best side. So personally I recommend You not to buy more products Quantummagic
Don't agree - then not guys then whine that something You personally are not working. I, unfortunately, can't control who will sell You something or not. From another dealer I just banned You to serve. Women's cards work fine about sea reviews. So look first in the mirror, and then blame the product.
I think all the options are SCRAP (and stream and the product) will be personally useless to You. For the above reasons.
To begin to benefit from the available products, learn to look at yourself and your interaction with the world critically and to see that in them and in themselves can and must be changed. Then there will be the potential to work products. According to the principle "I want to make it so" it doesn't work, which is obvious from the description. It works on the principle that it is possible to develop and improve in the man, and on this basis to change its interaction with the world.
Well, this is just a temporary version, then Andrew usually makes your photo art, but yet to get the underlying ideas go well.
Products basic and Pro version in stock at the office.
Version E++ under the order.
