Well! New art project :)
Post by Михаил_ » Tue Mar 13, 2018 6:31
16,18,6,10,41,6,48,50,8,4,43,32,
1,14,38,27,0,26,50 ,50,48,11,13,59,
43,60,38,4,25,14,42,50,39,50,40,20
0,9,41,36,19,56,8,0,44,2,55,56,
37,52,50,2,38,21,27,44,53,5,16,47,
23,53,5,51,29,55,2,27,3,42,22,22
2,22,56,30,54,3,11,55,59,25,2,53,
3,37,5,34,18,44,54,17,38,54,44,8,
55,47,57,8,16,25,33,32,11,55,21,51
27,8,11,0,10,59,56,46,14,54,13,41,
38,12,14,3,46,51,8,43,18,49,15,20,
55,35,28,55,42,55,55,34,14,39,5,59
Take 12 numbers from the first row, then 12 from the second and so is the 12x12 matrix is not formed.
Then it is applied to P-black. (I think it is clear that those who have no thereof, to easily make her home-made)
And then... a bonus for those who will tell you most accurately what it is and how it works and what I contests guessing new products has you covered ?
Расторгуев
Has thanked: 6 times
Re: Well! New art project :)
Post by Расторгуев » Tue Mar 13, 2018 11:08
Michael there 8строк on 17-19 of numbers and another string with the same number. If to take from each row of the first 12чисел, and ignore the rest, you get 12×8
Патрик
Has thanked: 2 times
Been thanked: 5 times
Post by Патрик » Tue Mar 13, 2018 11:29
Pandora Anachron light :) Working with time :?
Post by Михаил_ » Tue Mar 13, 2018 11:59
Расторгуев wrote:Michael 8строк there on 17-19 of numbers and another string with the same number. If to take from each row of the first 12чисел, and ignore the rest, you get 12×8
Recorded so that there were no issues (there all as is necessary, a separator comma, for technical reasons, the extra spaces got)
Андрей Ермаков
Has thanked: 3 times
Been thanked: 15 times
Post by Андрей Ермаков » Tue Mar 13, 2018 15:24
Included detachment, and how that here and now intensified, strongly do not care for the past and the future , although in the top three too. However, not three, not kills :) . Shear and washing in the treble there is, somewhere in the area of the conventional visuddhi, throat...ears. The above is not drawn to the bottom also gives. I.e. the lyrics and romance the same care. And work is possible, even comfortable, because I also do not care. IMHO detachment decent. After a day of use I noticed that some people at me kind of strange look (earlier it was noticed that when using the BZ 2.71), so like or anything special for a not noticed. Only here once got on the Elevator (inside all mirrors) and saw the corner of his eye, as if my picture twitches, like I'm a hologram :) . Maybe some people (who look weird) also that it is seen...
Мартин
Been thanked: 58 times
Post by Мартин » Tue Mar 13, 2018 17:33
The impression is that the "magic pendel". I mean like on a Billboard, the power of positive change.
Post by Михаил_ » Wed Mar 14, 2018 3:11
Бисо wrote:Almost immediately causes the ISS. A very powerful flow of energy. The product can be put on a pause or to send the energy somewhere. You can mentally adjust the flow of energy that was not overweight. The space around is somehow more viscous, reminds on a PC (or a well-done buffer). The arbiter somehow smooths out the impact. Without arbiter the effect is felt more harshly begins to ache problem areas in the body. Can't say for sure, but I think that if command can affect the speed of flow of time - especially this aspect we need to see more.
While writing the text I noticed that the energy flow adjusts to the operator.
If I'm wrong, that this product can affect the speed of the flow of time, then the main purpose is a very powerful source of energy. To come the idea that Coco extent Michael made this product in conjunction with source.
I think something like that.
And the first question that arises is, that Pandora-black-for which we put this product remains Pandora black and you can work as usual and this time she was in completely working for the security of this product? I see that it is largely, if not completely works for providing this product.
Мартин
Post by Мартин » Wed Mar 14, 2018 12:27
I also think that is the module to Pandora. The diagnosis turned out Eyvaz+Uruz, the actual force of change and Dagaz+Algiz+of Hagalaz, some powerful high-frequency adjustment, there are runescript is very similar to "Ragnarok" is called irreversible changes there, a strong impetus to the development. I think that Andrew is the job of these energies is felt as detachment. While in meditation, saw the tiger General is playful as luck, through the restructuring in the HF of course, fairly rapid results. I was just confused by what you already have leopard mode, so netrestore some. Pandora itself is multi-faceted, this is not just it.
Post by Михаил_ » Wed Mar 14, 2018 18:49
It is certainly not the module to Pandora, but you can say so, because he is using PB as a working material for the activation itself. This is an independent product.
In General, most of the thoughts in the right direction, but before giving the description I think I'll wait.
So, actually even better than the description forward, because there is no modulation description :) Pure test is relatively speaking.
Мартин
Post by Мартин » Wed Mar 14, 2018 21:39
And let the whole world wait.
ММ
Has thanked: 185 times
Been thanked: 40 times
Post by ММ » Wed Mar 14, 2018 22:53
Well made. Nothing. Why? :wink:
Терве
Has thanked: 72 times
Been thanked: 22 times
Post by Терве » Wed Mar 14, 2018 23:50
Gentlemen, comrades, please share how you do this thing. Carry it around during the day or leave the house? Than its staple - clip? Or, on the contrary, she for a brief time influence and should soon unstick? I've put 3 hours in the morning, and then taken apart before leaving for work just in case.
Post by Михаил_ » Thu Mar 15, 2018 2:47
ММ wrote:Well made. Nothing. Why? :wink:
Duck like must be clear, here is the chain regularly reviews practitioner audience
http://support.quantummagic.org/showthr ... #post26159
(part moved in here when I have time).
As you can see, they are approximately similar (like here).
morality - the degree of preparedness is different, as the touch sensitivity (to see how it works and feel aspects).
I hope P-black connect remember ?
Post by Михаил_ » Thu Mar 15, 2018 2:49
Терве wrote:gentlemen, comrades, please share how you do this thing. Carry it around during the day or leave the house? Than its staple - clip? Or, on the contrary, she for a brief time influence and should soon unstick? I've put 3 hours in the morning, and then taken apart before leaving for work just in case.
well they do if I just published ? :)
you can and so and so.... (in the sense of continuously on and off).
The commercial version will be for continuous use. One of the problems, doesn't clean to start :) well, it is to use.
ММ
Post by ММ » Thu Mar 15, 2018 6:33
Someone throw a photo of how it looks like your homemade. :o :o :o :o I think in the morning I have strongly changed voice. He was a sharp, masculine, hard. Is this possible? :shock:
Ллерон
Been thanked: 4 times
Post by Ллерон » Thu Mar 15, 2018 9:41
Everything is possible :)
Бисо
Has thanked: 49 times
Been thanked: 38 times
Post by Бисо » Thu Mar 15, 2018 14:45
Бисо wrote:Today I looked a little deeper. The product is tied to kako-istocnik, looks like a big sphere. Around her there is something like that in the corridors, spatial corridors. This whole structure is very similar to the flower, and constantly moving toli toli pulses.
I tried to change the speed of the flow of time, but it did not. Or I can't see clear signs that something is fluctuation. With Pandora Anachron this process more visible, noticeable.
How has this energy has some sort of component of creativity. The question of how you can apply this product, the product has shown that it is possible to influence reality.
Yesterday commercial PB+"well" after 20-25 minutes of work was terribly overcharged me for the whole day until late at night. On hand was wearing two bracelets of E-executor. Today, I am afraid to touch this product, but I guess I'll have to try to feel something else.
Андрей Ермаков
Post by Андрей Ермаков » Thu Mar 15, 2018 19:31
Funny, for a second day snot from the nose flow :) already do not remember when was the last time that happened. And occasionally chaotic feeling of hunger, then suddenly there is a want very much, then let go. Looks like something metabolic going on. I made a sandwich of three Pandor black and two "well" between them. And Yes, awake, but if asleep, can sleep through anything. Never have dreams at all. Well weekend soon :) though get some sleep.
Вагнер
Post by Вагнер » Thu Mar 15, 2018 20:42
Good afternoon, dear friends! Today did "Well", combined with Pandora-black (commercial). On the hand, the ruler (always wear C New year). Immediately there was a noise in the head. After 5 minutes of euphoria, lightness in the body, my head cleared was great. Having the same changes as in the mental activation of the arbiter (who long can not hold). In this case, the condition arose and held constantly. I called it product Activator arbiter. Michael, thank you so much for Your products!
ММ
Post by ММ » Fri Mar 16, 2018 1:20
Gentlemen, someone throw a look at your homemade. :o :o :o
Ллерон
Post by Ллерон » Fri Mar 16, 2018 2:07
And you why?
Вагнер
Post by Вагнер » Fri Mar 16, 2018 10:29
The decider is not disabled. The state of the drive is kept constant. My opinion- "Well, here" together with the Pandora-black is an energy source (power plants).
Бисо
Post by Бисо » Fri Mar 16, 2018 15:23
I see that with this product it is possible to create a long lasting structure and each structure can be set the program. These structures are separate entities and only the one who created the object has operator rights. Each structure can be sent somewhere, depending on the goals and objectives.
The question arises on account of the environmental performance of these tasks. Or it all depends on the operator and the responsibility falls on him?
Андрей Ермаков
Post by Андрей Ермаков » Sat Mar 17, 2018 9:35
It seems "well" really activates the three-ruble bills, I forgot that the chain is loaded (still in 2010) :). It seems that my review is lubricated by the action of this three-pointers, because without it, everything is different.
Мартин
Post by Мартин » Sat Mar 17, 2018 12:29
Hehe... Not an easy diagnosis, I immediately said. All on top of each other superimposed, pokachivaetsya, then the whole ecosystem and not left a subject. It is necessary to remove all cut off and look carefully (I did). Another question, and will all be cut off? As an option, to enhance, to try to emulate this thing with all available means, and where there is no opportunity to emulate, to take on and off (I have not tried).
