My second youth with disks of Andrey Patrushev
Ольга См
Been thanked: 2 times
Post by Ольга См » Fri Dec 08, 2017 13:56
Andrew, thank You so much for Your work, for Your knowledge and experience! :o Little more than a month has passed since the day when I 1st time listened to disc Healing, and now I'm a completely different person! :D :D :D
I started with November 4 — Healing at the 1 time, 6 th — Healing in the morning+evening. Seeing information about Healing-2 immediately bought it and listened to the 7th in the morning and in the evening again, Healing 1. After the 1st listen to the same discs I was very happy with the effect!!! Much left fog out of the head, reduced the ringing (which affects for many years), and I became a much better to navigate in space. Feet become light. Improved mood, strength came. Better to sleep, to dream, and often in the morning even remember what it dreamed of! Redid a bunch of things around the house! 8th in the morning after listening to the Healing-2 realized that I'm falling asleep, and instead of going to the store, laid down and slept for 2.5 hours!!! I barely slept, and those rare occasions in my life when I was able to sleep in the afternoon, you can count on your fingers! The 2.5 hour sleep was not very deep, and at times I almost woke up from a very pleasant relaxing waves passing through the body from head to feet. It is interesting to observe how the body started to react and to rebuild, even began to normalize weight, although the food has not changed.
After a week of listening to the disc even Healed my long-standing and very serious problem (called diabetes insipidus) began to recede and I began to sleep at night 4 to 6 hours in a row!!!
After listening, slowly began the promised acute: sore joints, broken back, and for some reason much started to ache the calf muscles. Then hurts the liver. With a week highly "twisted" and then began to wane, and slowly, almost passed. Only the severity of the liver is felt to this day. The ringing remained (especially in the evening), though I must admit that he was not so arrogant :roll: strong and annoying :roll: .
After reading information on the forum, was going to buy Innerpulse, but read the contraindications and upset.... Drew I have another diagnosis: :cry: photoepilepsy. Here http://www.neuronet.ru/bibliot/b002/fotosens.html I found the description of MY reaction to the flashing (particularly when traveling in public transport). Quoting the piece: "it was noted that there was a reaction to photic stimulation at 3-4% of healthy study in the form of dizziness or nausea, and in some cases numbness or a short disturbance of consciousness". From the same article.... it turns out:" Even in Ancient Rome, the slave market used the rotation of the Potter's wheel, rhythmically reflecting the sunlight, for revealing they have epilepsy. Well voooot(((( in Ancient Rome knew, and I just recently learned, thanks to Andrew. Not fatal of course, but VERY, VERY nasty :cry: . Probably because I was born in Leningrad, where the sun almost does not happen!
On 25 November I graduated from the 15-day course listening to disc Healing. And from November 17, on the advice Andrew, I alternated through the day drive Healing, and Massage of the brain.
In the evenings, listened to mostly Guide.
Yesterday was the 15th day of the audition disc the Massage of the brain.
Tonight is the 13th day of listening to disk Explorer. From the 11th of December in principle, you can resume Healing. I REALLY like disc Healing right miss him)))) Considering that I am 65 years old and health problems are many - I decided to listen to courses 15/15/15.
Given that and the noise/ringing in my head, but other problems still remain — some questions for Andrew:
1. which drive instead of a Massage the brain will recommend you to listen the next 15 days?
2. to resume Healing 11 Dec or maybe some other?
3. tomorrow, December 9 will have to fly the plane (first 3.5 hours), and I'm nauseous.... Especially when landing. What the disc can be listen to on the plane? But I would not want to disconnect, and could fall asleep somewhere on a bench in Domodedovo :oops: because I need to fly (1,5 hours)
4. machine Navigator there is a switch on the blue light. Does this mean that in the presence of photoepilation I still be able to use this mashinoy?
5. and perhaps I will finally be able to get an answer to my question, which hangs in two years. The fact that I bought my grandson glasses with special lenses that reduce the harm from exposure to blue light. Here's a typical article on this subject http://www.ochki.net/articles/article-1460/#Vozdeistvie. I do not exclude that this is another Scam and deceive, but I believe it. I recently bought these lenses in the medium price range, because the use of these glasses we could NOT(((( I wore them only once. At first it was very nice, clearly visible on the laptop screen, and then, after 40 minutes, I realized that I was getting sicker. Headache, muddied, I turned pale. The head was very heavy and as if its badly squeezed by the wrap.... Grandson saw that I was sick, and in response to his questions I replied: "I rocked those glasses like I'm 4 hours was driving along a forest road on a Sunny day". Hmm...how do I then accurately described the circumstances under which made me sicker. Grandson several days trying to get used to, and wore my glasses, but every time he started to ache((( Yes, the grandson glasses with no lenses, I have prescription lenses, but I tested them in other workshops. All was right: and diopters, and the distance. And no one, not in one workshop could not understand WHY we are so bad in those glasses! By the way, after those 40 minutes with glasses - I finally came to somewhere in the 3-4 day (finally completely gone nausea and heaviness in the head). Does this mean that blue light is not so harmful as paint manufacturers lenses? Or is it merely MY problem? TBI I had 2. The first concussion a year old, and then when I was 40. I was driving, stopped at a traffic light, and behind me got rear-ended. From strong blow I have even shifted the cervical vertebrae (whiplash Tr), but a good chiropractor the next day everything was put in place and the neck pain gone, and my head aches, but even to lie down at home failed, it was necessary to work (dashing 90-e...). My grandson (he is now 14 years old) - also 2 TBL. At the age of 3.5 years has been in a serious accident by car and 5 years of age ran down the stairs, slipped and fell back, cut off the head, sewed... Very glad that it is NOT a fracture of the skull base, because the wound was very close.<
Re: My second youth with disks of Andrey Patrushev
Post by Андрей Патрушев » Fri Dec 08, 2017 15:16
Thanks for the feedback!
Ольга См wrote:1. which drive instead of a Massage the brain will recommend you to listen the next 15 days?
Just take a break. Bigotry in this case can only hurt.
Ольга См wrote:2. to resume Healing 11 Dec or maybe some other?
As you wish.
Ольга См wrote:3. tomorrow, December 9 will have to fly the plane (first 3.5 hours), and I'm nauseous.... Especially when landing.
If You listened to 15 days of Healing, especially Massage of the Brain, it is unlikely that You'll get carsick.
Ольга См wrote:4. machine Navigator there is a switch on the blue light. Does this mean that in the presence of photoepilation I still be able to use this mashinoy?
On the basis of literature data we can assume that you can. But the reality is usually much more difficult, so do not try - do not know.
Ольга См wrote:5. and perhaps I will finally be able to get an answer to my question, which hangs in two years. The fact that I bought my grandson glasses with special lenses that reduce the harm from exposure to blue light.
Something I had not seen... on the Contrary, now abroad in commercially available fluorescent lamps "full solar spectrum", where not only the blue color is present, but also near ultraviolet. Constant presence at the exposure of any monochromatic radiation is, of course, will move the physiological parameters of the organism. But except from points in everyday life now it is difficult to "catch". For example, screens of TVs and monitors already 10 years as nothing emit.<
Ольга См
Post by Ольга См » Sat Dec 16, 2017 14:42
Hello, Andrey! Thanks for the quick and clear answers to my questions. To read through it all at the last minute before departure, I had but to write to thank time is not enough :oops:
You were totally right: I was NOT sick on the plane!!! Not a bit!!! :D
But in response to the flight of PLUS 18 degrees to MINUS 2, the body rebelled, and the next day I have a sore throat, had a terrible cough+runny nose and I fell. Although apparently - perhaps even the flu in the city.
So from the 13th I resumed listening to Healing to support the body in a difficult moment.
Already I feel much better today, although I was treated only with home remedies and drops carmolis.
Interestingly, usually when colds, parallel always aggravates herpes (well, that life is too sweet not seemed). So I always have in my purse is a small tube of Acyclovir, so that when the first symptoms spread lips, not waiting until everything is swollen half face. So this time on the lips was powerule, I smeared a couple of times, and herpes, as they say, grignols and died :D !!!!!!!!!! So that immunity has indeed become stronger!
Once again, THANK You :o
