The fractals. BR-Disk. Questions
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Thu Jul 20, 2017 18:34
Here is the questions/answers on the product
Has thanked: 112 times
Been thanked: 71 times
Re: Fractals. BR-Disk. Questions
Post by АндрейКо » Fri Jul 21, 2017 0:39
And perhaps a flash drive to use? (to format in NTFS for example and one file to write?)
Post by Шалтай Балтай » Fri Jul 21, 2017 10:15
АндрейКо wrote:And possibly the stick to use? (to format in NTFS for example and one file to write?)
Yes, of course I do, for pendants, for example. Then why BD? The case in technology as always. USB flash drive - pertubatively, Principle of operation, it is possible to find on legco wiki
Same with hard drives. They are also rewritable.
BR - another principle, the laser "burns" the track. Thus collecting information for BR - a "hard" or something.
Continuing the idea
And if you just print a fractal on paper? is also an option, BUT the A4 - 210×297 mm or 8 27х11,69 inches. If you vpechatenie 600 dpi, we get 34,803,468 points, i.e. 35 million, if it is borderless. And BD - 25 Millard points, i.e. almost 1000 times more. Ie, You need to print 1,000 pages on paper that would "catch up" with one BD disk. That is, if BR - in one track, i.e. 25 GB
Thus, BR - looks like the optimal media for this type of information on a neg day.
Hope replied.
Post by АндрейКо » Sun Jul 23, 2017 12:01
One more question - where to get this file (to generate mathematical programs or download?)
The flash realized that it is better to score almost at capacity.
The file - is it a fractal I wonder how much it will compress when you back up - the idea strongly.
That's easy and affordable https://infourok.ru/issledovatelskaya-r ... 09298.html
Post by Шалтай Балтай » Mon Jul 24, 2017 12:33
Good zdraveska, andreyko
АндрейКо wrote:where to get this file (to generate mathematical programs or download?)
If done independently, then I would recommend to go my way, ie -
about download - I did not post the file on the ball. And don't give the software that implements the growing of fractals. By the way, funny, fractals akin to crystal - grow them. :)
Will discuss one thing. The infa, which is, and which I gave more than enough to solve the problem on their own, unless, of course, is the understanding of the issue. If that is not - I'm not ready to talk about it. It's just a waste of time. Without understanding we can speak the year, and it will do nothing. Seek and ye shall find, shorter.
Post by Шалтай Балтай » Mon Jul 24, 2017 12:58
АндрейКо wrote:In the file - is it a fractal I wonder how much it will compress when you back up - the idea strongly.
in my time at six. But again, I'm not going to do that. It's just a waste of time. Can do to make - do. No - buy the disc.
Your pardon please if it looks harsh. :oops:
I must be cruel only to be kind
Pity I have to be cruel.
(C) WS
Post by АндрейКо » Tue Jul 25, 2017 14:16
Now it became clear. And even in the price of the disk is not visible, and download nothing - think about it :)
Post by Шалтай Балтай » Tue Jul 25, 2017 14:50
Шалтай Балтай wrote:by the Way, funny, fractals akin to crystal - grow them
just as an example. Here are the result of a program for growing fractal to 26th level.
Code: Select all
r-seq.000000000000000001
r-seq.000000000000000002
r-seq.000000000000000003
r-seq.000000000000000005
r-seq.000000000000000008
r-seq.000000000000000013
r-seq.000000000000000021
r-seq.000000000000000034
r-seq.000000000000000055
r-seq.000000000000000089
r-seq.000000000000000144
r-seq.000000000000000233
r-seq.000000000000000377
r-seq.000000000000000610
r-seq.000000000000000987
r-seq.000000000000001597
r-seq.000000000000002584
r-seq.000000000000004181
r-seq.000000000000006765
r-seq.000000000000010946
r-seq.000000000000017711
r-seq.000000000000028657
r-seq.000000000000046368
r-seq.000000000000075025
r-seq.000000000000121393
r-seq.000000000000196418
the list of file names. Each - the result of the program with the previous one. Ie r-seq.000000000000000002 were grown from r-seq.000000000000000001. A crazy number, prefixgroupname zeros - the number of bits of the fractal (that's bits, not bytes). The number of bits - exactly the ACC. The Fibonacci Sequence
Code: Select all
Uro | Name Number Of Bits | Number Of
 Wen | File Fractal | Fibonacci
 1 | r-seq.000000000000000001 | 1
 2 | r-seq.000000000000000002 | 2
 3 | r-seq.000000000000000003 | 3
 4 | r-seq.000000000000000005 | 5
 5 | r-seq.000000000000000008 | 8
 6 | r-seq.000000000000000013 | 13
 7 | r-seq.000000000000000021 | 21
 8 | r-seq.000000000000000034 | 34
 9 | r-seq.000000000000000055 | 55
 10 | r-seq.000000000000000089 | 89
 11 | r-seq.000000000000000144 | 144
 12 | r-seq.000000000000000233 | 233
 13 | r-seq.000000000000000377 | 377
 14 | r-seq.000000000000000610 | 610
 15 | r-seq.000000000000000987 | 987
 16 | r-seq.000000000000001597 | 1597
 17 | r-seq.000000000000002584 | 2584
 18 | r-seq.000000000000004181 | 4181
 19 | r-seq.000000000000006765 | 6765
 20 | r-seq.000000000000010946 | 10946
 21 | r-seq.000000000000017711 | 17711
 22 | r-seq.000000000000028657 | 28657
 23 | r-seq.000000000000046368 | 46368
 24 | r-seq.000000000000075025 | 75025
 25 | r-seq.000000000000121393 | 121393
 26 | r-seq.000000000000196418 | 196418
The fractal that formed on the disk was cut from the original level 55 :)
if you look in the file, then you can see:
The first Bit of the Rabbit sequence, the first level:
Code: Select all
$ xxd-c 1-b ./r-seq/r-seq.000000000000000001
00000000: 10000000 .
Like a fractal, the 5th level:
Code: Select all
$ xxd-c 1-b ./r-seq/r-seq.000000000000000008
00000000: 10110101 .
00000001: 00000000 .
Twenty-one bit, the 7th level:
Code: Select all
$ xxd-c 1-b ./r-seq/r-seq.000000000000000021
00000001: 10110101 .
00000002: 10101000 .
Fractal 15th level:
Code: Select all
10110101101101011010110110101101101011010110110101101011011010110110101101011011
01011011010110101101101011010110110101101101011010110110101101011011010110110101
10101101101011011010110101101101011010110110101101101011010110110101101101011010
11011010110101101101011011010110101101101011010110110101101101011010110110101101
10101101011011010110101101101011011010110101101101011010110110101101101011010110
11010110110101101011011010110101101101011011010110101101101011011010110101101101
01101011011010110110101101011011010110101101101011011010110101101101011011010110
10110110101101011011010110110101101011011010110110101101011011010110101101101011
01101011010110110101101011011010110110101101011011010110110101101011011010110101
10110101101101011010110110101101011011010110110101101011011010110110101101011011
01011010110110101101101011010110110101101101011010110110101101011011010110110101
10101101101011010110110101101101011010110110101101101011010110110101101011011010
11011010110101101101011010100000
etc.<
Ольга К
Сотрудник mindmachine.ru
Been thanked: 17 times
Post by Ольга К » Tue Jul 25, 2017 15:29
АндрейКо wrote:Now it became clear. And even in the price of the disk is not visible, and download nothing - think about it :)
Фракталы (Blu-ray диск)
Русалка
Has thanked: 22 times
Been thanked: 18 times
Post by Русалка » Thu Jan 25, 2018 0:56
Шалтай Балтай wrote:Situation the intention, Commit and put in the fractal.
It's like the Wishmaster or something? Note "There was a suitcase with a million bucks in front of me" - put it on the fractal and the suitcase appears?
Post by Шалтай Балтай » Thu Jan 25, 2018 9:54
Русалка wrote:It's like the Wishmaster or something? Note "There was a suitcase with a million bucks in front of me" - put it on the fractal and the suitcase appears?
he smiled :)
better two! TWO million!
remember the classics:
- Hey, cousin, Gimme a ruble! I Afonya ruble should!
two.
two! two rubles!
