The novelty of 2017! Massage of the brain 2
Владимир Никонов 2
Has thanked: 20 times
Been thanked: 28 times
Post by Владимир Никонов 2 » Thu Jun 01, 2017 3:16
The audio program, "Massage of the Brain 2" stimulates the brain in the alpha-beta range and has a slight antidepressant effect.
Compared with the audio program, "Brain Massage" in the audio program is "Massage of the Brain 2" is applied to a more progressive method of stimulating the hemispheres of different frequencies, and the impact is focused mainly on cognitive functions. It is possible to increase the efficiency and reduce the duration to 27 minutes.
Узнать подробнее
the audio program, "Massage is Brain 2" is created according to the method golovonogogo autofocus, allowing you to strengthen your own brain frequency, unlike the method of audiovisual stimulation (AVS), where there is the imposition of extraneous rhythms.
As a result, this program is more soft and, at least, no less effective than the AVS. This provides an excellent opportunity for rehabilitation from injury people who do not have devices, sound and light brain stimulation.
the audio program, "Massage of the Brain 2" is designed for:
— recovery of alpha activity in the brain after a traumatic brain injury and diseases with high fever (prolonged exposure to low-grade temperatures);
— for rehabilitation after left-sided strokes,
— for the rehabilitation of adults suffering from add (ADHD).
Many therapists working with the FAA noted that some of their clients during the sessions of the beta-stimulation (on active) paradoxical sleep. If we exclude the few cases with big debts the body to sleep and rest, for the majority of clients main theoretical explanations of these cases was absent.
Gradually, with the production of statistics, began to pick out certain patterns. It turned out that falling asleep among customers is dominated by people with diagnoses of attention deficit disorder (add, ADHD) and diffuse axonal injury of the brain — the consequences of traumatic brain injury (TBI), concussions, high accelerations, illnesses with high temperatures (or prolonged low grade fever), strokes. When electroencephalographic investigations, it was determined that all of these people, in one degree or another, there was a suppression, or a significant weakening of the alpha rhythm, leading to depression and chronic anxiety, sleep disturbances, and cognitive dysfunction (memory, attention, analysis and synthesis).
To restore the alpha activity of the brain clinicians have undertaken numerous attempts to apply ABC. Unfortunately, in most cases, conventional tuning of the brain, the frequency of flashes in the range of the alpha rhythm, does not happen. This bleak situation persisted until, until Dave Seiver nor developed a method of audiovisual stimulation, when the right hemisphere is stimulated by the frequency two times lower than the left. It has enabled people suffering from various consequences of injuries to significantly improve the quality of life by the end of the second week of regular classes according to the method of Dave Savera.
Thus, if you have the following symptoms:
— you always fall asleep when using beta sessions (category "E");
— you have a diagnosis of add or ADHD;
— you have anorexia;
— you quickly get tired at the slightest effort;
— you regularly run into furniture and other people;
— you regularly drop things from his hands;
— after the incident (head injury, accident, illness with high fever) had problems with reading and clear expression of ideas in communication;
— after the incident (head injury, accident, illness with high fever) had problems with memory and attention, and learning something new;
then you have every reason to practice with the audio program, "Massage of the Brain 2".
For healthy people regular exercise with this program to provide the following positive changes:
getting rid of "mental smog";
activation of logical thinking;
improvement in short-term and long-term memory;
improving ability to focus;
the extension of the range of sound perception;
freedom from hypersensitivity to sounds;
improving confidence, reducing anxiety and freedom from unreasonable fears;
improving fine motor skills and General coordination;
improving the ability to understanding (with hearing) foreign languages;
improvement of musical ear;
the disappearance of ringing in the ears;
Recommendations:
To do:
— not more often 2 times a day, with a break of not less than 3 hours;
— not less than every two days;
— not later than 4 hours before a night's sleep;
it is advisable to drink a glass (at least half) of pure water before and after listening;
— healthy people over two days — 21 days. Further, according to need, but it is desirable (otherwise the efficiency is reduced) to make a break not less than 21 days;
— for the rehabilitation of cycles to optimally choose the following: 15 days to listen to 15 days to rest, etc. — up to 3 months.
The greatest effect is evident when using stereo headphones, to ensure the playback range of not less than 20Hz-20kHz.
Side effects:
In the initial stages of the program (up to weeks) may be a slight deterioration. If it lasts more than a week to change places headphones.
Reducing craving for alcohol.
STAY HEALTHY AND HAPPY!
Note: This program is not intended to replace any treatment. The program can cause unpredictable effects on a background of reception of alcohol, drugs and psychotropic drugs. In any case, do not listen to this program while driving and while operating other potentially dangerous machinery.
The program lasts 27 minutes.
Format: wav.
Audiostrobe (for mind machines) is no.
You can listen to on any device (player, computer, tablet).
The greatest effect is evident when using stereo headphones, to ensure the playback range of not less than 20Hz-20kHz (headphones fit).
Pay and download
Андрейлевченко
Has thanked: 4 times
Been thanked: 10 times
Re: New 2017! Massage of the brain 2
Post by Андрейлевченко » Fri Jun 16, 2017 18:04
Hello!my question is,is it is,I've finished listening to disc 2 Endorphins, and now want to start listening to this CD brain massage 2, but I read about it and saw that it is made of alpha and beta waves, but endorphins 2 is also made of beta waves, so it turns out that I can't listen to the brain massage 2 because there beta wave and turn so that the brain doesn't rest from them-beta waves, if I understand correctly? Or you can listen to brain massage 2? Or stay for 15 days?
Post by Андрей Патрушев » Sun Jun 18, 2017 9:21
Andreichenko
Yeah, need to rest.
Ростислав
Has thanked: 35 times
Post by Ростислав » Tue Jun 20, 2017 8:37
Interesting applet - paid but still does not download - Internet we have now is weak :cry:
Post by Андрей Патрушев » Tue Jun 20, 2017 9:09
Rostislav
You guys seem to have a navigation system: viewtopic.php?f=48&t=4695&view=unread#unread
Ростислав
Post by Ростислав » Tue Jun 20, 2017 9:15
Yes there is , but with the light I don't want to work hard to bear recently light stimulation
Дмитрий Никитин
Has thanked: 10 times
Post by Дмитрий Никитин » Tue Jun 20, 2017 11:05
The drive comes with a strobe?
Post by Андрей Патрушев » Tue Jun 20, 2017 12:36
Dmitry Nikitin
No. In addition to other HemiStim glasses of Photosonics it will not be adequately reproduced.
Дмитрий Никитин
Post by Дмитрий Никитин » Tue Jun 20, 2017 14:15
That is on the Navigator points it is better not to listen?
Андрейлевченко
Post by Андрейлевченко » Tue Jun 20, 2017 14:17
Андрей Патрушев wrote:Andreichenko
Yeah, need to rest.
Hello Vadim! 1 more question, Massage Brain 2 you need to listen to or fully for 5-10 minutes?
Post by Андрей Патрушев » Tue Jun 20, 2017 14:23
Дмитрий Никитин wrote:That is on the Navigator points it is better not to listen?
For the Navigator there is a corresponding session: viewtopic.php?f=48&t=4695&view=unread#unread
And audio program should be to listen to without glasses.
Post by Андрей Патрушев » Tue Jun 20, 2017 14:24
Андрейлевченко wrote:1 question, Massage Brain 2 you need to listen to or fully for 5-10 minutes?
For 5-10 minutes.
Дмитрий Никитин
Post by Дмитрий Никитин » Tue Jun 20, 2017 15:26
approx. Thank you for the wonderful program! :o
Has thanked: 5 times
Been thanked: 16 times
Post by Вячеслав. » Thu Jul 13, 2017 14:41
Massage of the brain 2) the healers nervously Smoking in aside... Though,probably in my ignorance. :)
Андрейлевченко
Post by Андрейлевченко » Wed Aug 02, 2017 20:07
Hi Andrew! please tell me,after listening to the course massage of the brain 1,is it possible without making a break to start a course of massage of the brain 2? or is it better to pause?
Post by Андрей Патрушев » Wed Aug 02, 2017 21:10
Andreichenko
Hello.
You can not do.
Иулия
Has thanked: 8 times
Post by Иулия » Wed Aug 09, 2017 16:54
Hello! Started listening to "massage brain" , and realized that it is very difficult 40 minutes given ( due to the fact that the evening before bedtime it is difficult to stand 4 hours listening to in the morning, but usually get up at 6, so you have to listen to allocate 40 minutes to 6 am), and then came audioprogram massage of the brain 2 and 20 minutes, tell me if I start to listen to "massage of the brain 2" is considered to be a continuation of just "massage brain" or need to re-count or 15-15-15 21 days?
Post by Андрей Патрушев » Wed Aug 09, 2017 17:16
Julius
You can continue
Флетч
Post by Флетч » Thu Aug 10, 2017 19:02
Good afternoon, Andrey! Prompt, please, the doctors diagnosed me with "sensorineural hearing loss". Which of your programs is it possible to restore hearing or keep it at current level?
Post by Андрей Патрушев » Thu Aug 10, 2017 20:43
Fletch
Massage of the brain 1, in General, helps in the initial stages. Only a loud to do.
Андрейлевченко
Post by Андрейлевченко » Sat Aug 26, 2017 10:54
Hello! I listened to a course of 15 days,the disc massage the brain 2,thanks to him,and to be more precise,its Creator,I'm over the 15 days became a supervisor,foreman,General in chief at work))appointed! And all of that brain working perfectly))a lot of energy,a step ahead from the rest (at work) it was incredible what they do these drives(Patrushev) and thanks again for this ROM
Post by Андрей Патрушев » Sat Aug 26, 2017 13:41
Andreichenko
Nadda not to be confused with the warm soft.... :) All this happened because of yourself, dear, and the disks are only "magic pendal". :wink:
Андрейлевченко
Post by Андрейлевченко » Sun Aug 27, 2017 11:32
Thanks for the kick up the backside)
Евгений Борисович
Been thanked: 3 times
Post by Евгений Борисович » Wed Aug 30, 2017 14:44
Andrew say : teen 12 years old with memory problems. You can listen to the disc?
Post by Андрей Патрушев » Wed Aug 30, 2017 16:58
Eugene B.
No.
