Succor punch 2 is incarnated project Succor Punch: viewforum.php?f=34
nothing new, just the years pereplonennyh, upgraded version
To read:
viewtopic.php?f=34&t=3462
viewtopic.php?f=34&t=3317
The session will be posted here
The theme will be fairly tightly moderated.
All the best of luck!
SP2. Support
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
- Шалтай Балтай
Re: SP2. Support
reserve 1
- Шалтай Балтай
Re: SP2. Support
Good zdraveska, ArnoldАрнольд wrote:Interested in the question, instead of crystal, it is possible to use the classical SP (quartz with Mobius in orgonite).?
Yes, it is possible and even necessary. That's the beauty of the product. This approach (SP2) is flexible. The unit Mobius can be placed:
- Crystal
- Crystal orgonite
- Crystal sousuke (same organic)
- Crystal in the Potala
- Crystal melted silver/gold or other orgonite medium high density
- If you have JS1 (kulich) it is possible to put on SP2
- Paver Wendy, All kinds of izgotovitelej
- Orgonite pendants,
- Orgonite pyramid
- etc. etc.
- Instead of crystal you can use stones, Jasper, malachite, Charoite, someone like that
- You can use the water, and any object can be activated with SP2
For example, if you are using the jewelry, pendants, rings, they can charge/activate using SP2. - You can use SP2 without the crystal. The use of Torsonce as the transfer of thought forms. This is normal.
- The use of nodes, lenses, rings as well will increase the effectiveness of the product
As I said in the video presentations I recommend to have a set of crystals, each under its task. Argenitna environment can be shared, as well as Moebius, but the crystals it is better to have several.<
- Шалтай Балтай
Re: SP2. Support
Somewhere in April last year, the ride in this mode.Арнольд wrote:has there been such an experience.?
viewtopic.php?p=152592#p152592
Moebius - removable, crystal in orgonite.
