FREE HOMEMADE BJ 2.51/2.61/2.71/2.81/2.91
Post by Михаил_ » Fri Jan 06, 2017 10:10
As promised, I publish information on making a Lite version of these BJ.
Here they are, the promised
https://drive.google.com/drive/folders/ ... VU2LUhITHc
The use of the following: take BJ panacea or the other 2.x for example (which is TO short and basic treatment before the BJ) and are projecting consciousness to it a symbol (call it conditionally a personal rune of the BZ) for some time. Not bad for this coating bracelet solid something, for example in the industrial production 2.x1 is a special composition containing an epoxy resin, a bit of copper, some magnesium powders, but (for example) just nail Polish or wood varnish or something that can linger on your bracelet for some time. It is clear that easier to handle flat parts with a surface having good adhesion to the covering composition.
Character it is desirable to project a separately for each part of the bracelet (link or whatever that in your case). Do it as if the symbol burned there by the light of your eyes. As an already existing whole.
Successful experiments
Re: FREE HOMEMADE BJ 2.51/2.61/2.71/2.81/2.91
Post by Михаил_ » Fri Jan 06, 2017 10:12
The topic of discussion on my forum: http://support.quantummagic.org/showthread.php?t=283 (there is, as always, there are some questions and answers that don't have full duplicates here).
Post by Михаил_ » Fri Jan 06, 2017 10:14
2.51
Post by Михаил_ » Fri Jan 06, 2017 10:17
2.61
2.71
Post by Михаил_ » Fri Jan 06, 2017 10:18
2.81
Post by Михаил_ » Fri Jan 06, 2017 10:19
2.91
Post by Михаил_ » Fri Jan 06, 2017 10:20
Pleasant experiences and holidays ! :)
Тимоша
Has thanked: 21 times
Been thanked: 5 times
Post by Тимоша » Fri Jan 06, 2017 12:58
Thank you))) From pictures has slightly shakes his head and takes it ISS kind called)
Post by Михаил_ » Sat Jan 07, 2017 1:16
Yeah, and the manufacturing process itself is also, so to say ISS :) because we have through itself to broadcast this.
Owners of I2 is advisable to carry out the curing of the composition in the inclusion bonsoir + small Mr on the program streams of the world max power....
Аиша
Has thanked: 56 times
Been thanked: 14 times
Post by Аиша » Sat Jan 07, 2017 2:01
Is it possible to print out pictures and stick on the bracelet links?
Post by Михаил_ » Sat Jan 07, 2017 2:13
It's a bad method. A good way described in the instructions. But you can compare experimentalno. In addition to the experience that will give experience ?
Тимоша
Post by Тимоша » Sun Jan 08, 2017 15:25
I have a homemade BJ 1.0 a couple left, can the matrix into a self-made panacea, TO appear, and then from the resulting Solution in a homemade BJ 2.x???
Владимир Ш.
Has thanked: 19 times
Been thanked: 34 times
Post by Владимир Ш. » Sun Jan 08, 2017 18:56
Yes, absolutely normal course of action.
Post by Михаил_ » Mon Jan 09, 2017 4:14
In this example, it turns out that no matter what they handmade 1.0, a simple way - panacea->BJ 2.x1 (panacea 1.0 is still overlap).
Тимоша
Post by Тимоша » Mon Jan 09, 2017 23:14
Made a homemade BJ 2.51, and made a large pendant of Shungite. Improved tactile sensitivity, periodically began to feel the movement of energies, changes in temperature, periodic squeezing in the head, which is constant movement in the etheric plane. While the first day, see what happens.
Тимоша
Post by Тимоша » Tue Jan 10, 2017 18:26
Continue the review on handmade shungite BJ 2.51. Home-made, as shows the status, it turned out hard and strong, I didn't think so, perhaps this is due to the material (shungite, after all is considered a meteorite, a fragment of the destroyed planet Phaeton), possibly with non-standard approach to its manufacture. All night I couldn't sleep, feeling as if someone runs through the body touching, there's nobody half the night in a state of near sleep, micro-dreams, and in 5 minutes fit long scenarios. There is increased temperature, pulse on ISS, stuck, the feeling of increased energy, is replaced by weakness and sudden disconnections in sleep, the moments there was a whistle in my ears. There is a tendency to improve the General condition and complete adaptation to the home-made, a gradual harmonization.
Post by Михаил_ » Thu Jan 12, 2017 0:21
Well, Yes, shungite certainly could affect how the material is constructive. On the other hand if it is a pendant, the mounting area and the way of influencing the cocoon is not like the bracelet on the hand. The frequencies above (well, depending on how low hanging pendant) entry point + otherwise smeared on the cocoon.
Post by Михаил_ » Sun Jan 15, 2017 22:34
Кошка wrote:Made a bracelet and pendant 2.51 2.81. The pendant rests under my pillow, carry it permanently impossible - overload.
With bracelet all at all interesting. Did, since they are at the zero point and main issue of recent months - "where now?". In the first dream I had vividly and clearly shows where I am now and what should be next. When I woke up, I fell on so MANY new options moving forward that third day, the brain swells and hardly time to digest the incoming information. When it fell off a few blocks, I slowed down with the phrase "and why do I need all this?". Now I know why. Energy so much that you have to slow down a little and try to persuade that everything should be done consistently, and not at all at once
In General, if all previous items for me were the delicate tools to bring yourself to sense P-black and 2.x1 is a HAMMER for a breakthrough of incredible power.
Thanks to heaven, Michael! You are a magician!!!
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Thu Jan 19, 2017 23:22
I tried to make a 2.51 from a wide Panacea of BH. Each link 3 times. Powerfully it turned out. But how back this bracelet is wide BH Panacea to return I don't know...
P. S - should probably have been better for the AMB mode a Panacea to try.
(and how else to gain experience :) the more I 2.51 necessary to remove certain aspects of existence from a state of stagnation :wiz
Thank Michael_ !!!
Тимоша
Post by Тимоша » Fri Jan 20, 2017 11:30
АндрейКо wrote:Tried to make a 2.51 from a wide Panacea of BH. Each link 3 times. Powerfully it turned out. But how back this bracelet is wide BH Panacea to return I don't know...
Thank Michael_ !!!
Why? Panacea and so the mental switches to BJ 2.5, I'd be sorry commercial Panacea BH to spoil. Simply take an ordinary wooden bracelet, to put on links of the matrix a Panacea, a bit of a wait, Cell cloud appeared. Then a transparent varnish applied to each link separately on each link separately to cause mental need a personal rune, you can just spend more time on each link, the stronger the bracelet turned out. IMHO this option suggests itself immediately.
Тимоша
Post by Тимоша » Fri Jan 20, 2017 18:37
Question. Made a homemade. If after a while, once again, apply a new coat of varnish and again mental to burn runes on the contrary, will strengthen the bracelet?
Арнольд
Has thanked: 44 times
Post by Арнольд » Fri Jan 20, 2017 20:38
By the way, if you listen to audio with headphones introducing the alpha rhythm, visualization of burning is given a lot easier..
Post by Михаил_ » Sat Jan 21, 2017 6:54
Thank Michael_ !!!
switching back is not provided :) so I do not recommend to spoil AMB :)
Post by Михаил_ » Sat Jan 21, 2017 6:55
Тимоша wrote:Question. Made a homemade. If after a while, once again, apply a new coat of varnish and again mental to burn runes on the contrary, will strengthen the bracelet?
Options. Check :) There is a ceiling above which they cannot jump, and in one step or in several.
