Candle series "Metamorphosis"
- Has thanked: 1 time
- Been thanked: 182 times
Re: Spark series "Metamorphosis"
I understand that pictures are uploaded without a description, in order to prepare the forum to a new product, you can meditate on it and write who it was namedetails.
My understanding of it is very imaginative, interpret your images so opposites exist, but not the important opposites, and what connects them. Communication...communication...communication...to establish relations... "Communication decide everything."
донна Лилия
- Has thanked: 7 times
- Been thanked: 21 times
Miracles happen all the time...the sun is shining, the frost krasnic cheeks, the children make a snowman...but can really happen Christmas miracle?Россомаха wrote:In the process of combustion of a candle will be miracles.
Yes, I now know what to give for the new year!
Was namedetails prism, rainbow...ball of light, disintegrating into many sparks. The photo is very warm, like your hand over a burning candle hold.Милая wrote:you can meditate on it and write who it was namedetails.
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
New to this online product, although the patterns are the theme of us mastered long ago.
The product is very versatile. Candle series Metamorphosis with self-rays work “by themselves”, can work with the programs of the operator, as well as in a series of candles with the programmed technology SEM crystals (carrier - tourmaline).
the Main purpose of the product – the entry in ISS and work with information flows through the structure of the candle.
The information structure of multi-component products, created in cooperation of 4 basic elements. Depending on the task and with the help of directed attention can include one or more elements. For this there are a number of techniques for working with candle Metamorphosis.
The artifact is very sensitive to the state of the operator, allows to obtain almost instantaneous responses to altered States, mental promises, intentions, thus, can also be used as a research tool itself and its finer States.
Basic elements: Wax (space Giparksis), Tourmaline (working area of the candle), air Wick (the Axis), Time (space Rhythms). You can allocate a Helix element geometry Axis and a Plasma element of a Field of candles.
Is activated by the axle, filled with spiral and actively interacts with Tourmaline. Crystal wax cell is a hexagon. In the process of making the artifact, the wax undergoes a phase transformation, in which the hexagon is set in the line, then re-kristallizuetsya in hexagon, turning into energostroytrans substance that is able to store, release and redistribute energy within a certain range. This defines the main properties of the space Giparksis: structuring of information flow and purification.
1. Work with information flows.
Running spark essentially gives intended the opportunity to be, makes the intention of the operator. After lighting the candles, you start a process similar to the process of crystal growth. Each space has its own language, system of signs and symbols and syntax, which determine this space. To give an illustration: a person is faced with another life form and tries to establish contact. This requires the translator to understand both languages (a good example is the recently released movie “the Arrival”). The man has verbal consciousness, i.e., thinking with words, and the wax is transformed in such a decoder, a kind of guide, making the program operator in the structure of the energy-field. Melted wax solidifies intention. It determines and a share of responsibility in working with the artifact. It is necessary to be extremely attentive to your thoughts and your state with the running candle.
2. Cleansing properties
At the same time space Giparksis is a universal frequency filter. Working candle absorbs all vibrations that are heavy in to the structure of the wax. The versatility of the cleaning properties that the wax works as a pollution of the space with the entire range of destructive programs that are in the candles. Candle Metamorphosis is perfectly located for negative psycho-emotional States of the operator, and to clean the space. Some areas of the cleaning properties: generic programs, the purification of the creative of the channel, bringing thought-forms, etc.
Tourmaline (the candles)
1. Energy-properties
Box of candles produced is heated in the wax crystals of tourmaline, is the main working field for the operator. The use of tourmaline in the candle Metamorphosis due to the pyroelectric properties crystal. In the process of heating tourmaline crystals begin to radiate, releasing energy and creating around itself an electric field that can interact with the field operator (read more about Tourmaline crystals can be found in the section BRM Tourmaline code).
The programmable element. In the candlelight Metamorphosis with programmed crystals, tourmaline crystals, radiating, capable of sending complex wave forms (programs) to any point within the field of candles.
This element can purify the subtle body to promote the opening of the chakras, to develop eurovidenie and other superpowers to do the vehicle of perception more active and to make easier the entry into the ISS, to develop the flexibility and mobility of consciousness, to develop the second attention and to train the transitions from first to second attention.
Field characteristics fields of the candle will depend on the state of the operator, although the candles and also what program was laid. Many light candles for decorative purposes, in varying degrees, unconsciously carry out the work with a plasma field the candles. It is constantly changing and if you are working with a candle, it is desirable to register these changes. In the initial stages this can be done by hand by detecting changes in thermal field. Field candles multi-level, and contains, including ...even diamond nanoparticles. Depending on sensitivity and level of work with a candle, you can allocate up to 7 fields candle: 3 basic and 4 additional. Each level is able to power something or other subtle field of a person, and most importantly, set brain.
2. Physiological properties
Tourmaline is one of the versatile and powerful crystals with unique properties.
When heated, tourmaline emits infrared rays in the range of 6-14 µm, enhancing the energy potential of the organism. Infrared rays can penetrate deep into the body, activating metabolism, promoting the elimination of toxins, promote muscle relaxation and healing of chronic of the clamps, restoring blood flow and normalizes the biological functions of cells.
Axis (the space of the Monad)
The physical aspect of the axis, or center in the structure of the candle is a cotton wick. Axis is activated by Fire, filled with spiral interacts with Giparksis and Time-dependent. The quality of the axis – of the centrality, integrity, harmony, unity. Space Monad allows you to build a unity of self, to find the center of peace and balance in the chaos of the internal energies, to find I-real, who wants something... or wants, just watching.
Space Monad allows you to get into a meditative state (and other States, wide range of ISS), dive and watch yourself, find a state of equilibrium (a state of harmony of internal energy), to streamline the mental process to work with the Central energy axis.
From the position of the spark programming operator axis has a distribution from the center to the periphery of the property and also has a helical character.
Time (space Rhythm)
Cylindrical candle burns evenly. In other words, set their own natural rhythm changes. Earlier candles were used as the chronometer, was a measure of time. Meditation on the rhythm of the candle's burning like a meditation on flowing water, movement of air, and represents the attunement to the rhythms of nature. Is calm heart rhythms, slowing down personal time, normalization of the psychoemotional state. Going on vacation and qualitative recharge of the body, similar to the effects from exposure to nature.
The basic description that further reviews of the work with a candle will be added to, because it's very versatile. For example, to work with the axial element easier than with helical, which is not shown visually more subtle and requires concentration and self-explanatory. Equipment and working conditions with the candle will be described later. In this case the technique are not so much a strict sequence of actions as the main grid, which can be changed by inner feelings and tips of the artifact, and you can also weave your own tech (who worked with candles before). Candle Metamorphosis has activating elements and does not require additional activation.<
Time (space Rhythm)
Aura
Structure for configuration. Talk about the meaning of not quite right...it is not the language encoding. Encoding is ourselves, our preferences, our blocks, filters and circuits, which transmit structure. Maybe You will be interested in this aspect of three-dimensional structures
(The Merkaba, the vertical (crown-Hui Yin, etc.), horizontal (palm with the palm as to catch the energy balls), diagonal (left shoulder-right hip, etc.) due, I think, obviously, the man in this picture is not quite correctly seated, for example)
But as with the structures all work described in the subject Architecture GAIP.
What is important is not the value of the character to understand, and to see the amount that is recommended in this case, when a burning candle. Structure is the key to the condition.
Aura
The photo is a candle for programming by the operator (the principle of programming is similar to the work with BRM, the setting is in the field of candles).ЛанаМайнд wrote:I understand - it's a candle, one of a series of "Metamorphoses"?
Price 3300 RUB candle without the program.
Price 4300 RUB the candle with the program Oracle
In fact the whole tsimes
You do not understand the genius ideas - consumable artifacts vs eternal.
This price is due to expensive raw material of the tourmaline.
Аура wrote:Candle Metamorphosis is perfectly located for negative psycho-emotional States of the operator, and to clean the space. Some areas of the cleaning properties: generic programs, the purification of the creative of the channel, bringing thought-forms, etc.
And where to esteem about the program Oracle can?Андрей Кабанков wrote:Price 4300 RUB the candle with the program Oracle
Aura
The proportions of the elements designed for prolonged burning. For a full day the candle burned out about halfway, and then was not detected.Россомаха wrote:And how long the candle burns?
Is it possible then to use for different purposes. As I understand it the wax takes a specific form that will be some kind of access code. After some time, then you can start again to use it.?Аура wrote:the Man has verbal consciousness, i.e., thinking with words, and the wax is transformed in such a decoder, a kind of guide, making the program operator in the structure of the energy-field. Melted wax solidifies intention.
Maybe this habit, but to me that's just not enough in technoitalia of something living, warm and cozy., giving a candle as a native it seems
And new year's discounts are expected?
Know that the wax is a pure substance, and while working with the candle all problems that torment the person moving into the wax. And because of this are displayed in the information field! or on the energy body! And...if you're lucky, you can just on the physical plane to leave. I had that when I've identified people who pumps out good luck...
With proper operation with a special candle is the ritual cleansing and to identify the causes of illness, failure, damage. Know that the wax assumes cristalizare negative. Such rituals often spend itself.
The stones also have the ability to give the person some sort of properties, to complement the missing, give him your energy. Have long felt that stone is a living substance, and treat them with respect.
I want to know if in this case this candle to use in the healing purposes for themselves and their families, at the same time for purification and activation of energy, of giving and acquiring?
Know that healing and magic are widely used special candles with a combination of wax, special herbs and spices.
But with the stones???!!!
this has not yet met, although I know that working with stones is an ancient technology of treatment of body and soul, work with the space and desires. I think this is a very good combination, the qualities of the wax flexible, plastic, soft, current, and the stone for me has always been associated with samodostatochnost, center, density, consistency, form, possession . Really want to try magic candles in the new year holidays and Christmastime!!! Although magic candles and stone - a combination of bold and might result in unusual results , the main thing to help)))
A description of the programs Oracle is? Or is there already somewhere? Then maybe a link who will?
Aura
Tourmaline field candle - approx. 2,5 m (the boundary is not clear, with a smooth decay characteristics). To hold can.ММ wrote:How far is the candle? You can hold in your hands?
