long polzoval Navigator
for all the time using mm Navigator only intensified the headache probably from the use of this svetosily mm the machines until this was inner pulse with the usual points - it wurde everything was fine - but after this headache postoyanno within a week after use!!! with enerpulse this was not!!! can't say what it involves but I think the fact!! was tested a few years since the creation of the Navigator
Re: long polzoval Navigator
Rostislav
Pressure was measured before and after?
What session use? Did you try to reduce the brightness?
So how?
a few days more practice on full low and still have a headache
I've left Navigator
I think we need other points to try plain - but damn buy not knowing will help or not reluctant
I've left Navigator
But why??? You can just put in the settings one color, then the Navigator will ignore the setup of the session and the entire session will be one color.Ростислав wrote:I think we need other points to try plain - but damn buy not knowing will help or not reluctant
And with the pressure, how?
Of course.Ростислав wrote:in the manual there are instructions?
