In order not to zaplivatj theme discounts, open theme crest.
The new product, which is really old
So, a new product, extensive functionality, the Magic Comb.
Detailed description a little later.
The comb Assembly facilitates you into a state when you are split apart, often conflicting with each other, and work together, synchronously and harmoniously as a single unit, while maintaining awareness of the current itself. Of course, from this state any of your actions will be more effective than the usual state. The comb is compatible with all products, including not only mine, it's such a versatile tool that cannot interfere with anything because try pokeflute with you when you REALLY are in this as a Whole itselfРусалка wrote:I'm interested in sharing with pantomime products. Be correct to go the programming of Pandora and configure the modules WOH? Strengthen the work of ACS and whether all QC maps can be combined comb?
Is it worth it to start making homemade products after scratching ( for example to the manufacture and activator) or it does not affect at all?
Are there warnings like "behind the wheel after combing sits", "not compatible with alcohol" and .t.p?
is Likely to be myself /putting a paw on the DNA key/ to activate the product.
While large lot of combs made exactly as in the photo at the top of the branches. In the future it is theoretically possible, of course, order from a supplier of another type of comb type of however, while this is not an option. Besides, the shape of the crest was not chosen by chance, including from the point of view of placing it on the pattern. When you comb your hair with it, then somehow hold on to the handle, i.e., thumb hits the key that smoothly parakeet in the future pattern. On the comb, which is on your photo, the pattern will be applied only on the back, or you will have to compress it. Besides, there is another equally important point. Comb it is impossible to forget to comb my hair when it is used not only as a comb, namely as a tool to work on oneself, that is, it is not created for passive mechanical brushing, for conscious inner work. The first option, of course, also possible (i.e. you can use it just in order to passively combing), but it is much more efficient when man consciously takes it and treats it as a tool to work on oneself. Therefore, "I forgot to comb my hair" in this case sounds not very seriousДмитрий Т wrote:And is there a option massage comb?
Just from her effect can be significantly larger due to the larger number of teeth.
For example, the wife a massage to comb it and that's fine, that crest will have specifically to do it, forget will and
massage in any case hair several times a day to comb
Directly it does not work, however, such possible side effects in improving the quality of hair and reduce the amount of hair loss. Hair is a natural antenna and instrument interaction with the outside world, therefore, we can say that hair loss shows to what extent the loss of contact with the world, and also about the internal conflict and dissonance, the failure of the circulation of energy and information. The comb serves to ease internal contradictions, restoring the integrity of the person and returning him to his stable center, so as this process may be physiological effects as a reflection of internal changes. Also do not forget about purely biological parasitic component. It is recommended to switch to a more easy (raw) food. Also, if I am not mistaken, on a physical level from hair loss, I use oil of usmi.Мила wrote:Ordered.
He was still the same help from hair loss?
Indeed, there are similar resonances and intersections, see paragraph 5here I keep this comb in my hands and think why it was I simonesque the track reminds
this is actually the first Association that came to mind
in fact, a curious toy, yet understand that where
here I think, I hair specially eh under the crest has grown
