Remember that read (MTK)
Remember that read - download.
Are you familiar with this situation where you spend days and even weeks reading some books or other printed materials, and then discover that almost none of it can't remember?
Of course, note-taking read may carry some benefits, but in this case, you must rely on your notes and not memory. In addition, the notes may not give you the full picture. Because, when you access notes that you created during training, you may find that they do not make sense, as merely representing a photographic snapshot of what you were thinking.
So, of course, the notes you can do, but if you manage to boost the memory, so that all you want from reading reliable remember, you don't even have to think about the notes.
Memory is a whole set of complex processes of your brain. Basically, in order to reliably remember to put it in memory first. When you feel or learn something new, the "impression" first enters into short-term memory. This process takes place in the hippocampus. So when someone tells you their phone number, you retain it in your short term memory, it remains there for as long as you didn't write it down and not forgotten (erased from short term memory). If you use it often that in the end, it is recorded into long term memory.
From this example you can see that the repetition and concentration on something are the basis of learning. But how to use it when reading? One way is to read educational material several times. But sometimes you just don't have time for this. Another way is to place new information into long term memory more quickly.
There are a few practical recommendations on improving your memory. For example, trying to read and learn anything when you're hungry, thirsty, tired or worried about other issues that will block you from getting information stored even in the short term not to mention long term memory. This way, when you read is as important as what you read, if you want to remember it later.
It is important to remember and use the fact that Your memory works through your senses. For example, consider a party with your friends what you saw, heard, smelled, felt and experienced. The more senses you remember, the brighter Your memory about the event. People with excellent memory read, tend to really see and even feel or hear the material as if they actually experienced it, not just read. Thus, their memory works more like the actual memory of the event.
You can get multi-touch response, even at the technical information if while reading you have a good idea of what you're reading. Another way to remember what you read – to explain important ideas from the reading to someone else. In other words, the more you get used to the information, the better it is remembered.
Even the great Russian physiologist Ivan Mikhailovich Sechenov, at the time claimed that between real experience and imagined experience for the brain, in essence, no difference.
This session helps you master the skills of ultrafast absorption and of easy recollection read by multiple repetition of an imaginary experience on the background of hypnotic trance.
Around hypnosis and the hypnotic trance, currently, stranded a lot of different myths. In fact, a hypnotic trance, by definition is "only" focused attention, directed inward.
In a hypnotic trance, everything happens very fast and even too fast, so your mind can not catch, something to see and feel, as your subconscious mind works millions of times faster than we used to think your mind. Therefore, your main and only job during the session is to relax well on both physical and on the mental level, to ensure that your subconscious ideal conditions for work. The easiest way to do this is to focus on your breathing – just watch and observe the sensations in the body during the normal breaths, not trying to manage anything.
Thus, the posture for listening, you are free to choose any where you prefer to relax and unwind. Headphones are not required (without them even easier to relax), but the use of stereo is highly recommended. Rule 2-glasses of regular clean water (before and after the session) is very welcome, as it enables normal hypnotic work and absorption skills.
Standard cycle of listen – 21 times (any number of auditions in one day counts as one time), with a break of not more than 2 days (without breaks). It is recommended to repeat the cycle every three months during the year (i.e. 4 repetitions). It is advisable to update skills every 4 years.
Optimum time classes with 16 to 18 hours.
PS To hear the voice Навигатор1 should be pereproshit on version 1.2or above. Highly recommend version php?f=38&t=6404">2.11and the owners Навигатора2 version 3.12
Save a combined session in a special folder (SES_SPEC) on the drive in Pathfinder. To find and run a combined session in the Navigator, select:
Navigator 1: Training\extra modes\Combe. session;
Navigator 2(green): Player\Combe. session of the csp.
Before class and after it is helpful to drink at least half a Cup of clean water.
On the absolute the majority of your even not asked questions :) you can find satisfactory answers in "Guide to disks".<
Re: Remember that read (MTK)
Andrewgreat session, thank You for new opportunities of development!
The memory is Everything!
I have a question does this session with other MTK session "Learn quickly"?
More about
recommend listening to one of your drives (do not remember exactly the "solar wind" or "Massage Brain") NOT headphones, and speakers?!
Question - how recommended to place speakers\stereo position relative to the head and some volume pick up?!
Wanted to clarify these 2 sessions: "Learn Quickly" and "Remember that read," it is possible to combine listening to the CD "Ultra Brain", which I now work (the tracks "Star flight", "Super training", "Integrator")?
More about
I remembered that You alsoHeadphones are not required (without them even easier to relax), but the use of stereo is highly recommended.
Unexpected question... And then what do You mean by "combined"?Алехандро wrote:I Have a question does this session with other MTK session "Learn quickly"?
You are wrong. There was a recommendation to use speakers along with headphones.Алехандро wrote:remember that You
recommend listening to one of your drives (do not remember exactly the "solar wind" or "Massage Brain") is NOT in the headphones and speakers?!
What do You mean by "combine"?Алехандро wrote:also wanted to clarify these 2 sessions: "Learn Quickly" and "Remember that read," it is possible to combine listening to the CD "Ultra Brain", which I now work (the tracks "Star flight", "Super training", "Integrator")?
Symmetrically.Алехандро wrote:as it is recommended to place speakers\stereo relative to the position of the head
Comfortable.Алехандро wrote:what is the volume to pick up?
AndrewАндрей Патрушев wrote:Unexpected question... And then what do You mean by "combined"?Алехандро wrote:I Have a question does this session with other MTK session "Learn quickly"?
...What do You mean by "combine"?Алехандро wrote:also wanted to clarify these 2 sessions: "Learn Quickly" and "Remember that read," it is possible to combine listening to the CD "Ultra Brain", which I now work (the tracks "Star flight", "Super training", "Integrator")?
the word "combined" I understand that the effects from the sessions were not blocked\not interfere with each other subject to known time intervals (e.g. 1 day listening to "Learn fast 2 day "Remember that read" continue the cycle).
The word "combining" I understand about the same, but given the fact so as not to run into "diffuse inhibition of the cortex"... ie.
now for the specifics - I daily (except weekends) for 3 - 4 hours to devote to the study of the Tax Code of the Russian Federation, and related literature for professional purposes.
For absorption use the tracks "Super Training" and "Integrator" with Ultramega ("Star flight" about 25 days listened to in the morning, on a break now).
I know that between sessions of the Navigator, the interval dB. 3 hours minimum and no more than 2-3 sessions per day, but on the breaks between sessions of the Navigator and listening to "Ultramega" I have not completely clear.
I would like to include in your learning process by listening to the "Learn fast" and "Remember that I read" like before or directly after the training (i.e. reading material)
I was escorted by Ultramega. Just wondering as it's the right thing to do to post real-time "Navigator" and "Ultramag" in the process of reading\learning?!
Ie for example I am engaged from 10 to 14 with Ultramega, then let's say 16 - 17 want to listen to "Learn quickly" or "Remember that you have read"... or Vice versa I want to do with ultramega after 20:00, then again will not interfere in the day session "the Navigator" from 16 to 18?
Something like that
Or don't mix and the first to complete the 21 day cycle on the "Ultramega?
clarity at me to no end
Also wanted to clarify, still this session you can listen in the headphones without a separate stereo system ie speakers facing with 2 sides from the head because it is not particularly convenient to place on the bed?<
Yeah... More or less clear.
Everything is combined and is combined in any ratio if between any sessions and programs to keep the breaks at least 3 hours.
There's no reason to specifically tailor lessons with combined sessions to study something, because they only start to apply after a natural normal sleep.
If it is written "not necessarily", then, IMHO, so it is possible.Алехандро wrote:also wanted to clarify, still this session you can listen in the headphones without a separate stereo system ie speakers facing with 2 sides from the head because it is not particularly convenient to place on the bed?
Yeah... More or less clearАндрей Патрушев wrote:yeah... More or less clear.
There's no reason to specifically tailor lessons with combined sessions to study something, because they only start to apply after a natural normal sleep.If it is written "not necessarily", then, IMHO, so it is possible.Алехандро wrote:also wanted to clarify, still this session you can listen in the headphones without a separate stereo system ie speakers facing with 2 sides from the head because it is not particularly convenient to place on the bed?
And, if it is written: "but the use of stereo is highly recommended", whether it is understood that it is possible to use either headphones or loudspeakers, but the effectiveness of
this is changing?!
Alejandro
Che's the use in talking? Try both - you will understand what is best for You.
Understood, I will try. It's just unusual that this session and so and so can do.Андрей Патрушев wrote:Alejandro
Aastha
"Remember what I read" is abormot, and "Ultramag" - autostimulation.
It's like "Explorer" - it is based on the text.ЯестьЯ wrote:what is abormot
Yes, even as (in the common sense, of course).ЯестьЯ wrote:how to combine itineraries between
