Need help. The creation of the stomach.session in beat 8*8секунд
Are you new to using Inner Pulse, can't figure out how to burn the stomach.program in the rhythm of 8 seconds inhale, 8 seconds exhale. Is there any live active people. to help create this program. Will be very grateful.
Recording your own session through the device is not obtained. Breath beyond the realm of possibility in the program. According to the new user through 5 steps, the program should avtomatichecki to adjust to the increase in sound during inhalation and exhalation. Do not go out.
To record using программуL/S Disigner. Frankly speaking, to deal with this not want.
I would be very very grateful!!!!
My room: 89032190012 - Anastasia, Moscow
Re: Need help. The creation of the stomach.session in beat 8*8секунд
Garcia
In Innerpulse it is impossible to put 8 seconds or 7 or 10.
Here is a simple session 7x7 (I think the difference is negligible): https://cloud.mail.ru/public/N6fH/CWjnJVJ4y
Andrew, thank you very much. If no trouble please salati session 10*10. The rhythm of the stomach.7*7, not really slow. To increase the breathing is easier than slow. Still, a more detailed study of the capabilities of the device and its use. Been thinking to go to a better unit, what would you recommend?
Well, there's only one option - Navigator.Дарсия wrote:been Thinking to go to a better unit, what would you recommend?
https://cloud.mail.ru/public/9Vtq/HW4hGEAPfДарсия wrote:If no trouble please salati session 10*10. The rhythm of the stomach.7*7, not really slow. To increase the breathing is easier than slow.
And the next question. Program L/S Librarian - downloaded, the cord connected all the required ports. But you have sent the session is not loaded in the program. It opens only LSL files. you sent me LSS. How to be?
How is recording the program into the device InnerPulse?
Garcia
LSL is a library file which You form, gathered in the library the desired session of the LSS, and calling this library somehow. This menu is all elementary and obvious (even for a poor mastery of English).
In the library you can choose machine, which are going to load session and to ping the device.
http://www.mindmachine.ru/sessions.htm
One session You can access and download directly from LSD, not from the library. We must remember that the LSD for Innerpulse for the Nova Pro 100 is a different program.
To ship program made for Innerpulse, to Nova Pro 100 and Vice versa, you just need to open the session in the appropriate LSD and resave under a different name.
Opened the file in LSS L/SDesigner, via download/set comm port/ it gives connection to the inner pulse, then Download(append) come flashing on the device and it shows the number 01. How to preserve session in the device? is it possible to make rename it?
Thank you, managed to understand)))))
