points in the Navigator slightly beat the current
Наталиа
Post by Наталиа » Sat Jul 30, 2016 13:44
Re: glasses in the Navigator slightly beat the current
Post by Андрей Патрушев » Mon Aug 01, 2016 10:42
of Natalia
Наталиа wrote:immediately points out at a greater distance
Наталиа
Post by Наталиа » Mon Aug 01, 2016 18:54
Post by Андрей Патрушев » Mon Aug 01, 2016 19:37
of Natalia
No, the Novapro 100 may not be - there is nothing to sciatica...
Наталиа
Post by Наталиа » Tue Aug 02, 2016 1:13
Post by АндрейКо » Tue Aug 02, 2016 1:43
Try changing the polarity of the adapter. Remove it from 220 then rotate 180 degrees and back to 220 volts install (or rather a phase with a zero in the fork sometimes)
If possible it is better to use the adapter with Galvanauskas.
But that's just a guess.
Post by Андрей Патрушев » Tue Aug 02, 2016 13:03
of Natalia
Yes, Colortree the same as in the Navigator matrix is...
In Pathfinder, it seems, had planned to varnish the contacts cover so as not pinching, but apparently not "grow together". :?
In principle, if slightly shift the glasses on his nose, the "problem" disappears. :)
Наталиа
Post by Наталиа » Tue Aug 02, 2016 15:03
Друид
Post by Друид » Tue Aug 02, 2016 17:30
I also have glasses pinch current. Which is extremely not conducive to relaxation!!!
The solution is to use the device on batteries, not AC adapter.
By the way, the ergonomics of the glasses is very unfortunate, because my restnice touch points. Please consider this point in next audit points.
Саир
Post by Саир » Tue Aug 02, 2016 18:10
Наталиа wrote:prefer not to climb in the running devices))
Not this andreyko Told you.
Pull the power plug from the outlet, flip it backwards (180 degrees) and plug again.
It is highly likely the problem may disappear.
Наталиа
Post by Наталиа » Wed Aug 03, 2016 7:47
Наталиа
Post by Наталиа » Wed Aug 03, 2016 7:49
Саир
Post by Саир » Wed Aug 03, 2016 11:20
Наталиа wrote:Short session in the Novapro is also not beat the nail, although after turning on the device specially stuck the upper eyelid to the LEDs to check if there is voltage, and I a little bit in the eye knocked current.
In General, the method works.
Just like in the saying: "the nail on the head!" :lol:
Good luck!
Post by Андрей Патрушев » Wed Aug 03, 2016 11:30
Yeah, you'd think a Taser of some kind. :) Barely noticeable tingling, if close to the eyelids to press and all. :?
Post by АндрейКо » Wed Aug 03, 2016 12:56
of Natalia
Unlikely to find ready... probably Easier and cheaper rechargeable batteries AA and charger to them to buy.
(and the prices on BP Galvanauskas rather big)
(Possible from using AC adapter with output voltage of 9V±5% connector
to connect the power supply DJK-02A (under the plug 5 mm with Central
pin 2.1 mm). Recommended current output of the network adapter - no less than 500mA;
• The ability to work from 4-x NiMn rechargeable batteries size AA voltage 1.2 V or 4 x
battery size AA voltage 1.5 V. )
Наталиа
Post by Наталиа » Wed Aug 03, 2016 13:02
Наталиа
Post by Наталиа » Wed Aug 03, 2016 13:12
Алексей Крячко__
Post by Алексей Крячко__ » Sun Feb 05, 2017 1:40
Андрей Патрушев wrote:of Natalia
In this respect there is a very nasty limitation : varnishes that are specifically intended for insulation boards and have elasticity are toxic even in dried condition and cannot be applicable in such a place. Other varnishes that meet the requirement of hygiene, on circuit boards to crack and chip (given that the motherboard Flex). The only option (albeit short-lived) fill with polyethylene. This option is tested.
