Area Mental Activation objects and macro-objects
Сергей Ивлев
Has thanked: 109 times
Been thanked: 433 times
Post by Сергей Ивлев » Wed Jun 22, 2016 14:13
Items and water mentally programmed and sanctify, but then I discovered that you can mentally create the Activation Zone, in which the items themselves have a powerful bioenergy for the watch. As it turned out, different materials on different accumulate bioenergy, and the water here is the champion, and the web, cane, rare earth metals, etc.
The angle of swinging of the pendulum after activation reaches 90gradusov but more serzno indicator is the angle of clockwise rotation. And in addition, you need to ask the pendulum at frequencies which chakras are bioenergy measured. The shop, for example, are not to be recharged above the level solnechnogo plexus.
Further, it turned out that it is possible to activate itself multidimensional Space.
In the Zone of Activation, all food improves the taste, odor and less spoiled. Manure and feces lose their smell.
See more http://www.earthup.info/home/85-myslenn ... roob-ektov
After activation pocket the batteries "charged" the current in the loop creates a static electric field activated. For example, between a large sheet of foil and a radiator. Between the tower and standing next to the car, on the surface of which is filed Plus. Everything in metal tanks so easily activated.
Any concrete and metal structures for 3 hours to activate, getting the swing angle of the pendulum at 45gr
But the grass, the trees, the earth without stones poorly activated.
If you only drink such water with an angle 45gr and above, then your urine will have no odor. It is amazing.
If you live and work in the Area of bioenergy plus, there will be accidents, accidents, theft and crime. For the safety of all vehicles, especially aircraft, should have the charge of at least plus 30g of rotation of the pendulum and it must make the safety standards.<
Седой
Has thanked: 13 times
Been thanked: 36 times
Re: Area Mental Activation objects and macro-objects
Post by Седой » Wed Jun 29, 2016 1:00
You suggest a new air freshener. Do I understand correctly?
ЗОМБ
Has thanked: 28 times
Been thanked: 2 times
Post by ЗОМБ » Wed Jun 29, 2016 9:29
Седой wrote:You suggest a new air freshener. Do I understand correctly?
:lol:
https://www.youtube.com/playlist?list=P ... IHfer0baHC
Nazan oncel steers accurately.
Седой
Post by Седой » Wed Jun 29, 2016 18:35
By the way, if you drink ammonia, urine will smell of roses.
Сергей Ивлев
Post by Сергей Ивлев » Thu Jul 14, 2016 23:57
The project was a step in the direction of tourism and resorts, has built a hex huts type of summer cafe
Рита С
Has thanked: 4 times
Been thanked: 30 times
Post by Рита С » Fri Jul 15, 2016 0:22
Cheto quite unpleasant, especially klumbochki.
Сергей Ивлев
Post by Сергей Ивлев » Sun Nov 13, 2016 11:32
To strengthen the impact of thoughts, desires and meditations include all the hubs of bioenergy. Next, open the file with the desires on the flash drive at the end of the USB cable into a strong biofield, for example in the chamber of the Reich, See my post viewtopic.php? f=32&t=6309
In the last 2 months successfully activate VIRTUAL offices, places people sleep, Flexible activators of bioenergy.
