Road safety / travel
Андрей Ка
Has thanked: 10 times
Post by Андрей Ка » Thu May 05, 2016 14:53
road Safety / travel
1. Ekonorm+Svetlitsa-Super
use of the device Ekonorm together with the device Svetlitsa-Super significantly increases its efficiency as a means of improving driving safety.
2. Nookular level I "Armor"
the Protective package a “quantum Leap”. Is activated only in the most serious cases, for example when there is an imminent threat to the life and health of the operator. Made the jump to another variant the line for the operator is the most energy-intensive option, but it works almost 100%. The operator can be seen as a rapid, often uncontrollable event stream. May cause temporary disable some other programs.
3. Nookular I level "Intuition"
1. Connect intuitive channel of information.
2. Getting information from dreams.
5. Viewing the variant lines
4. Versatile outliner space
Аура wrote:
Андрей Ка wrote:how to improve security, if you take with you on the plane?
With the aircraft not the most unique situation, one fall to another discord. All mass disasters fall under either variant of the funnel, or under conscious care. In most cases Yes, activated the range safety contingency lines. Let's just say it forced, that is, fall into the funnel, the situation is reduced to a minimum. Conscious care is a systemic phenomenon, in such a situation, harmonious space, most likely, will not be allowed on Board. Here is also important the trust factor space, as the aspect of the energy relaxation. 've probably heard about the story when one passenger from the flight before departure, say, a broken leg and complained about a "hostile" situation...and then thanked a higher power for that)
4. Broadcast
4.1 road Safety
4.2 Trust
Аура wrote: Here is also important the trust factor space, as the aspect of the energy relaxation. 've probably heard about the story when one passenger from the flight before departure, say, a broken leg and complained about a "hostile" situation...and then thanked a higher power for that)
5. Bracelet of Life 2.6 / Map transfer 2.6
- increase event weight, stabilization, implementation of situations due to the huge mass of the object (You) relative to other events. Other effects as in 2.2 enhanced version.
For version 2.6, which can be called "harmonizer-Wishmaster" ... the Carrier BJ any version, and in particular 2.6, it becomes a very lucky man. It is objectively observed fact. Of course this does not mean that some of your desires may not be feasible from the point of view of the external situation in the world, not visible to you, immediately find ways of implementation, but most use the technology, noted the increased number of useful and lucky coincidences and events that benefit or alternatives in life. Typically, BJ is able to create a barrier on the path to serious trouble. For example, the human car won't start, it avoids unwanted meeting and its consequences.
6. Bracelets life Panacea
- function of 2.9, which is the combination of skills 2.5, 2.6, 2.7, and 2.8 in a single product. These are also that one of the qualities can be chosen and enhanced by a team that will create from Panacea "software" obtained an analogue of the corresponding version of the BZ (2.5, 2.6, 2.7 or 2.8 ). This is the analogue power will be similar to the original bracelet the appropriate version, but may differ slightly in shades quality (versions 2.5, 2.6, 2.7 and 2.8, these qualities manifest more natural and natural way).
the Matrix a Panacea
7. AK — Artifact Keys and Doors
Keys and Doors uses the principle of increased access, open to new opportunities, branches, probabilitiesinformation, connections, in other words, certain combinations of the principle of open doors that most of us have a bunch of keys and key — a very ancient tool that works in society, for differentiation of access and the provision of such benefits to certain internal algorithms are not public access and other things, not all things.
8. AW-2 Roads, transportation, travel, travel
Uses the principles of movement, transport, travel, visit, tourism. The purpose of the operation of these principles — the creation of the most successful, safe, less costly and the most user friendly environment for all trips, flights, and other movements.
9. AR-2 Travel
Affect the flow of people which You meet all types of transport (and not only) in a certain favorable way.
10. Device SK 1M
to be Solved in this way tasks can be of any kind:
-work with situations (which could be considered, and work to achieve some goals of different degrees of long term);
The device has three modes of correction, the type of exposure: activation of the process, braking process, harmonization process.
In case of activation of the process in the system there is a factor increases the chance of the desired (preset) scenario.
In the case of a braking process - the chance of the adverse scenario begins to decrease (the inhibited process).
In the case of harmonization process - start to considered the adverse factors that hinder the process to proceed in the best way.
11. Stabilizer. Products. Homemade.
Михаил_ wrote:Stabilization technique.
To stabilize the equipment, enough to set the anchor, detailing the aspect that requires stabilization and to place the anchor in the area close to the braking, but in Neutro field. In some cases, after checking the effects, it is possible to shift in the Homo field. It will increase the efficiency of stabilization techniques, but for some types of equipment may be violating the normal functioning factor (e.g., I don't think anyone is interested a very stable car that can't start).
Not necessarily to prescribe stabilization of a particular technology can be used process - for example, "my road for business and home." I.e. stabilization of all trips, from emergency situations and confounding factors.
12.Stoppage
Ban on deformatio the world is not material ways, temporarily suspends any external influences and / or other artifacts.
Андрей Ка
Re: road Safety / travel
Post by Андрей Ка » Thu May 05, 2016 14:56
Андрей Ка wrote: 1. Ekonorm+Svetlitsa-Super
2. The Matrix Is A Panacea
1. If applicable:
1.1) For a passenger aircraft?
1.2) Will there be a positive effect on the pilots?
2. The idea is to glue the airport while waiting and then the cabin :)
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Post by мимоходом » Thu May 05, 2016 15:24
If a person is afraid to break on the plane or get into an accident... sooner or later it will happen. And all sorts of protective artifacts just bring it - because the man himself on that goal constantly and focuses, adjusts itself to it, and a bunch of money to spend on this installation. And after it crashes - can it be called a prophet ))
Well, anyway, we all die, it would be strange to assume that some of the product (without any reason) can stop it.
Fear of flying such a level that one wants to glue the airport and airplane something - it's a small mental disorder. I'd recommend instead of spending money on all described to spend them on psychotherapeutic consultation. Normal psychotherapist psychologist you calm this fear will be removed and fly yourself to not be afraid ))
By the way, would recommend checked also on the subject you introduced plants (brainwashing, hypnotization). Because judging by the list - you are a very good client. And quite possibly someone suggesting that it should all have to buy, so that you are not knowing why - buy, coming up with paranoid reasoning. Don't want to offend - but your mind probably doesn't even know about these settings. Tell you webinars Michael watched? Maybe it is you? Inspired something? I needed to take more.
Can you Monasavu courses went, and you were treated? Or something to this kind of dubious activities.
Андрей Ка
Post by Андрей Ка » Thu May 05, 2016 15:34
Fatalism is not our method :) All products in this forum aimed at the improvement of (health, business, etc.) + the transition to other options, and this is a correction of events. For example, AMB. Users in the reviews said that a lot had happened during the period of wearing. Changed thoughts (the thought-habit-destiny), ways of responding, and therefore changed of cause and effect.
мимоходом
Post by мимоходом » Thu May 05, 2016 15:43
Just... all the artifacts... They actually help people believe in themselves and to set a stimulus-goal, something to focus on. You buy the artifact and sure that now you will be healthy, wealthy, and so on... and sometimes people change your attitude and everything changes. Of course it's good, though, and the crutches.
And in this thread you actually concentrate on the fact of an accident and how to protect themselves... But this is not a positive incentive and negative. Attempt to protect against crash you bring her, considering to himself that such a thing is possible and is more likely and it is necessary to guard against that.
Андрей Ка
Post by Андрей Ка » Thu May 05, 2016 16:18
Situation: the stretching of muscles during physical activities. Know that this is possible. Use protective artifact - workout or orthopedic brace, etc. by Doing this we increase the probability of stretching?
I understand that you need trust in the world (under spoiler 4. Universal structurer space quoted Aura about trust space) but still fears that are being implemented, and if you apply the artifacts, they can either help them out, or thrown at another option.
Иван Славов
Has thanked: 650 times
Been thanked: 150 times
Post by Иван Славов » Fri May 06, 2016 1:56
Andrew Ka,
13. Module BJ - "a Big sphere of Water":
"a Big sphere of Water" - creates a protective sphere around man-made object (Car, plane, train) where the person is. Sector can to a significant degree to demirovici different effects (crash for example), from the devastating effects due to the increase in inertial mass of the object. This improves security and allows to avoid some unpleasant consequences of technogenic accidents.
In principle, if the person is thoughtful, and the Designer of Cocoon, Designer ties, Pandora, PC, BRM, Z, etc. to include /and even Navigator. But, as I understand, above is the finished program on the topic.
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Fri May 06, 2016 3:31
Panacea - proactive protection.
It is possible and free versions.
Neocolonial to predict a situation or information on upcoming events used nookular Body. (maybe others are better and don't know)
