The aggravation of the diseases and vague condition. How to be?
Ваня
Post by Ваня » Tue Jan 05, 2016 18:28
Good afternoon. I would like to address to Sergey Dinovich and other knowledgeable people.
I really want to use the Parlor and get results. But, unfortunately, can't do this for the following reason:
About 3 years ago bought a SS. Started wearing her on his chest and put under the pillow at night. But survived only two days.
The first half of the day, the euphoria, a good mood, all right, but then begins some weakness in the body, to do anything you do not want to move, become some kind of cotton. The head starts not to work properly, there is forgetfulness, inattention.
First night slept more or less normally, the second night it's constant awakenings and superficial sleep.
All the time headache, heart pounding more than usual and appears a little out of breath. Increase the symptoms of VSD.
Also on the second day, all exacerbated by my chronic illness: inflamed nasal mucosa, throat (chronic rhinitis and pharyngitis), and increased symptoms of chronic urethritis. Become irritable and nervous.
All this was after the first time when I got the Room in the mail. Two days later, tired of enduring these symptoms, I put the MOP in the closet. A day all symptoms gone.
A week later I again took the Room and the whole situation repeated itself.
Later in the year I have tried several times to wear it, but always felt the same. Disappointed in her in the end.
But two years later I again remembered about the SS and hung it on his chest. The entire history of exacerbations and poor health again, as a blueprint.
I understand that something is wrong with my energy, aura, she's probably too weak. For example, I have a very weak immune system for life, just that immediately get cold. Very hard to communicate with people, because communication always feel bad, as if the energy goes away from the body. The body is very sensitive to any stress. Long restored. Although the child was healthy.
We would like to keep the SS helped to recover my condition. But its application is very deteriorating health.
Can you please tell what it could be, why such a reaction? How to use SS in such a case?
Maybe you first need to put the SS away from yourself, for example, at night on the other side of the bed and slowly get used to it?<
Акела
Re: acute and troubled state. How to be?
Post by Акела » Tue Jan 05, 2016 18:58
Ваня wrote:Maybe you first need to put the SS away from yourself, for example, at night on the other side of the bed and slowly get used to it?
The crisis will have to endure if you want something to change in your life. And You better wear yourself SS closer, and by the time for example 2 hours and then to increase for being.
Dreaming about healthy, the brighter the image the more precise life events will be adjusted to the expected result.
Ваня
Post by Ваня » Tue Jan 05, 2016 19:58
I would be happy to endure the crisis, but it is getting worse and the longer you wear, the more. If you like to know exactly how many days to suffer, then probably would have decided on it, but it is not clear when there will be normalization and whether it is at all.
The more I read such a message here in the forum:
once started to carry the Parlor, deteriorated, constantly sleepy, began to gain weight, become irritable, after waiting two months from a chamber to get rid of. Now you write that it is necessary to change everything about myself down to work and environment. If it were so simple in life, there would be all these bright-rooms, and questions / feedback. Nothing personal, and no one does not want to offend or even hurt. Just get rid of mirrors in the frame.
Two months and no change. And I two days is enough for me "shut down" in full.
To wear two hours a day, then increase by feel is good advice, thank you. I'll have to try that.
But still, I would like to understand why this is happening to me when wearing a Chamber.
Post by к-13 » Tue Jan 05, 2016 21:40
Vanyasuch problems often have those who started to work with alpha on mind-machines. Here I explained http://www.mindmachine.ru/forum/viewtop ... 35#p145735
You probably just run so much and it's great complicates Your life and move forward, and the chamber is trying to push to the surface, so You finally decided that you can.
Акела
Post by Акела » Tue Jan 05, 2016 22:46
Ваня wrote:But still, I would like to understand why this is happening to me when wearing a Chamber.
To search for causal relations need to be an experienced specialist in the field of your consciousness, try your best to use the "Joy 108".
ММ
Post by ММ » Tue Jan 05, 2016 23:26
Ваня wrote:I would be happy to endure the crisis, but it is getting worse and the longer you wear, the more. If you like to know exactly how many days to suffer, then probably would have decided on it, but it is not clear when there will be normalization and whether it is at all.
I on your place would connect themselves to broadcast "kids calm", frm, dolphins 3 months. Stream good will pump you with energy.Then you can borrow the Parlor.
Акела
Post by Акела » Wed Jan 06, 2016 0:19
I recommend to use a ROM "the HEALING: On the Magic River" he linked to СС108, description here
http://www.mindmachine.ru/forum/viewtop ... =17&t=5848
Enough to include as a background, it's a working idea, it is a pity that the developer did not develop. The same General safety rules in the work with disks of Andrey Patrushev, i.e. drinking water. Good Luck To You!
Ростислав
Post by Ростислав » Wed Jan 06, 2016 0:22
Акела wrote:Recommend to use the CD "HEALING: On the Magic River," he "linked" with СС108
:ay very strong drive together with the Svetlitsa - recommend!!!
АСД
Post by АСД » Fri Jan 08, 2016 17:41
Ваня wrote:Also on the second day, all exacerbated by my chronic illness: inflamed nasal mucosa, throat (chronic rhinitis and pharyngitis), and increased symptoms of chronic urethritis. Become irritable and nervous.
Ваня wrote:I Have a very weak immune system for life, just that immediately get cold. Very hard to communicate with people, because communication always feel bad, as if the energy goes away from the body. The body is very sensitive to any stress. Long restored. Although the child was healthy.
The forum has been discussing a similar case. Also the man wrote that fever and deteriorating health after using the Chamber for several days. Then I was advised to undergo examination the doctors. The survey revealed some chronic diseases. After one treatment the effect of the use of the Room disappeared.
Svetlitsa normalizes the immune system, which begins to actively deal with chronic diseases that You are experiencing. About how the normalization of the immune system when using the Parlor is a research report.
Need to drink more water.
In fact, You have a chance to get rid of their chronic diseases and strengthen body systems with the help of the Parlor. But do not neglect medical help. Keep in mind that You continue to act negative external factors, which have led to the breakdown of Your body.
Make a note of the latest report on the study of the influence of the Parlor to work DNA. It clearly shows that the reduction of the influence of various interference with Parlor, allows you to show what had not manifested. That is, users of the Parlor starts to turn what had not worked. By the way, this applies to all aspects of human activity, not just health.
In Your case it may be noted that the use of a Chamber Your immune system worked poorly and could not recognize the detrimental effect of various bacteria. After applying the front Room, the immune system starts to rearrange its work and to actively deal with the pathology, so the body's defenses are activated to fight.<
