"Sarcophagus" - the shielding box is for storage of artifacts
Integrated control technology a reality
Been thanked: 182 times
Post by Андрей Кабанков » Mon Sep 07, 2015 22:49
Экранирующая коробка «Cаркофаг»
Material steel 3 mm.
Size 10х10х6 see
Weight 970 gr.
Aura
Has thanked: 22 times
Been thanked: 1124 times
Re: Shielding box for the energy-information products.
Post by Aura » Thu Sep 10, 2015 13:57
Shielding box "Sarcophagus" is intended for storage of products, which the operator wishes to suspend.
First, the box to store artifacts provides shielding on the physical level. Manifestations of products at a physical level, is electromagnetic in nature, and the walls of the box, made of steel with a thickness of 0,3 cm, provide protection from the active radiation in a wide frequency range (including from background radiation). Since the effect of artifacts directly related to the electromagnetic wave processes in GAAP, the shielding properties of the housing box, made of thick steel, the artifacts provide protection from electromagnetic background of GAIP.
Second, the lid of the box installed 3D media with access to the program "Castle" that gives an opportunity to significantly limit energy and information exchange with the environment at some distance from the product. That is, if desired, partially (information) block the effect of any product, not necessarily to put him in a box, simply put next. Presumably the "program Lock" applies to all energy-products, we propose to make, a guaranteed screening products technology SEM and Bio-resonance modulators.
It should be noted that the program "Castle" does not affect the inertial effect of the products, though, and reduces them, that is the Sarcophagus does not involve a full wipe of data about the tasks of the operator, it limits the interaction with the surrounding electromagnetic (wave) and energy information (GAAP) environment.
The sarcophagus is designed so that the information stored in it previously, products not saved.
Aura
Re: the "Sarcophagus" - shield storage box artefacto
Post by Aura » Thu Sep 10, 2015 14:37
To whom and in what situations we should use “Sarcophagus”:
1. Basically the shielding box is for storage of products can be useful for operators that have an impressive Arsenal of energy-funds. More isn't always better, a large number of active products can lead to imbalances, some of which are periodically stored in the Sarcophagus.
2. Hypersensitive operators in adapting to the powerful effects of the products periodically to keep them near the Sarcophagus. This will greatly reduce chatter and overloads and to adapt to powerful products gently.
3. There are a number of products that do not require constant use of their work – implementation of certain objectives. The goal, when the action of the product in the new changed circumstances is not required, store it in the Sarcophagus until the next need to use.
4. It happens that the effects of the product are sufficiently powerful only with respect to a particular operator, due to the fact that he was not willing to work with him, and the periodic detuning from the product is necessary for the accumulation of intermediate experience and training to work with the artifact.
5. For “cleanliness of experiment”, when using new products, you want to separate its effect from all others used by the operator at the moment. For this purpose, all items except the one under test, are temporarily placed in a Sarcophagus for storage.
мячик
Post by мячик » Thu Sep 10, 2015 15:37
When chitaesh at different speeds posted in the description has different thoughts and associations.Still do not understand the essence of the offense of the box,you know razvivaet relationship with GEIP something you need to hide and be free.So again, it doesn't matter.
Aura
Post by Aura » Thu Sep 10, 2015 22:49
Don't destroy yourself with lack of understanding. Misunderstanding this is also the position...contact with the unknown.
Россомаха
Been thanked: 11 times
Post by Россомаха » Wed May 25, 2016 13:52
мячик wrote:razvivaet relationship with GEIP something you need to hide and be free
To be free from products have to buy more of them box.
мячик
Post by мячик » Fri Sep 30, 2016 11:00
Collect other people's experiences?
Гита
Post by Гита » Sat Apr 20, 2019 18:57
Sejchas na pri fotografirovanii pasport lazerom nevidimo vnedrjajetsja Isotopic font style, emitters on human skin, psychotropic antenna . Specialist mozhet li sozdatj zashitu ot izmenenija DNK ?
Ili kak nejtralizovatj nachertanije ? ili srazu after vnedrenija skoljko to pozzhe ?
