From the topic Map Masculine.
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 22:14
Good evening, all.
Description much. A lot of things right but I wish this were not just words. So, I ask this question, what role are images on the card? Is a decoration or the essence of them? If I make a card with the same picture whether I will get the card Masculine? If the answers to these questions already was I apologize, please redirect give me a link. In this topic, the answer is not found.
Thank you! :o
Been thanked: 10 times
Re: Map Of Male.
Post by Мастер 108 » Fri Aug 21, 2015 22:41
Инкурват wrote:So, I ask this question, what role are images on the card? Is a decoration or the essence of them?
Know what is a hyperlink? Now, these images are kind of "hyperlinks" on the algorithms in the description of the map.
Инкурват wrote:If I make a card with the same picture whether I will get the card Masculine?
Accordingly, if you on paper write a hyperlink (even if it is the exact URL) - can you, using only this paper (and nothing more) to get to the appropriate online resource?
I hope the analogy is clear.
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 22:49
Master 108Yes, the analogy is clear. I would like to clarify unless of course you know what this map features link "on paper" from links "on the Internet"? That is what is so special about this map makes a transition in this analogy, in "Internet"? If I understand you correctly, this is not the picture itself then what? The material from which made the card? Or someone this card and then loaded then who? If you do not personally know I would like to forward the issue to the developers.
Бисо
Has thanked: 49 times
Been thanked: 38 times
Re: Map Of Male.
Post by Бисо » Fri Aug 21, 2015 22:55
Hello Incurvate,
Here is what was said at the beginning of this topic. I hope to be useful:
"It is ONLY a commercial product. About the light here, as in the old vulgar joke, who likes a friend of mine - "what"???
well, in short it is not technically possible, because in contrast to the complex of the BZ where the modules keeps the Peace (abbreviated explanation) this is a very complex thing, but collected via a special control module and using Pandora. Technically, the digital part of it "weighs" about 250 gig of Informatii on each card (roughly), and it still bound mentally; And it's all made in a special anomalous zone in the modified stove laminator :) and connected to Pandora... and how to do it "Lite" retaining at least a piece of the qualities?
T/e/ example "Litem" there is the base state but no info-filling of AMB, which is the main thing. And everything is smaller and simpler components.
So no chance - there is simply no technology to get it all to blend in working in a Lite version."
PS Well, if you are familiar with making homemade BJ, many issues will disappear. Also the theme of the broadcasts will be useful.
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 23:02
BesoI'm not going to do the same card or the Lite version)))))
Бисо wrote: And it's all made in a special anomalous zone in the modified stove laminator
That is the essence of the differences of a plastic card with the same picture from the card in the anomalous zone? What is this area can be more? Just at the time crawled Perm anomaly, so ask)) And what is the modified normal laminator? I apologize for such molestation if it's a secret so tell me
Бисо wrote:and connected to Pandora
As I understand it is also a map but with a different pattern? As a large number of some of the cards can physically be connected to a variety of other cards? Or by "connected" do you mean that your not that mean usually?
Thank you for your answer :)
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 23:07
Бисо wrote:and it is still attached to mental
Sorry a little unclear from the message that mental exercises, part of the map...or thing? ))))) I understand how are mental artifacts but then I wonder who created the mental part?
Бисо
Re: Map Of Male.
Post by Бисо » Fri Aug 21, 2015 23:26
Here is a recording webinars where Michael explains all about Pandora and map Men's start: viewtopic.php?f=31&t=5839
I understand that you have many questions and my advice is to start with webinars where everything or almost everything is explained specifically for Pandora and maps Male and the Female.
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 23:30
Beso damn cool "anomalous zones" and "modified laminator"))) Master 108 gave specific and clear response followed by a specific question: what if you do not own the picture in the map Masculine distinguishes it from ordinary plastic card with the same printed pattern? Precisely why am I using this card "go online" and using a regular plastic card with the same pattern have "link to paper"?
You can reply to this question or not?
The question is simple and logical.
What does the video is kind of like a support forum or not?
And the author of the video can simply and clearly answer this question?
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 23:35
Beso you have not answered what is this anomalous zone and the laminator modified. If you do not know then why write about it?
.Ксения.
Been thanked: 91 times
Re: Map Of Male.
Post by .Ксения. » Fri Aug 21, 2015 23:36
Modules for cards recorded in the form of a mental broadcast as a programmable part (read the topic about the broadcast, and the topic of test translation on the cards), then these translation files with the help of specially written for this code is converted into "stars" on the back of the card and, as you correctly said, are "links" on them. Pandora kernel under them is the theme of Pandora you can read. Here they are for a more strong, coherent and safe operation of the contents of the card. Well, Yes, they are baked in a special way. Plus, relatively speaking, "charge" additionally, those same broadcasts. Michael, by the way, I answered a similar question somewhere in the early or middle of this thread.
Бисо
Re: Map Of Male.
Post by Бисо » Fri Aug 21, 2015 23:44
Инкурват wrote:Beso you have not answered what is this anomalous zone and the laminator modified. If you do not know then why write about it?
I did not write, I gave quotes which were at the beginning of the topic.
I'm sorry that I wanted to help.
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 23:44
.Xenia.thanks for the reply :) :o
If not difficult please specify:
1. What is an abnormal place where are the cards?
2. Than modificeres laminator?
3. Who still creates the mental part of the card?
4. What new information unit such Broadcast that they recorded some modules?
5. Do I understand that the chain of encoding and transmitting information mental someone programmed a part - modules to maps-broadcast has no physical media?
Thank you!
.Ксения.
Re: Map Of Male.
Post by .Ксения. » Fri Aug 21, 2015 23:44
At the end of this page, the answer of Michael on a similar question (to be continued on next page):
viewtopic.php?f=31&t=5843&start=25
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 23:45
.Xenia.good morning I'm new here I would greatly appreciate that posites with me before buying the cards :o
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 23:46
.Xenia.there is discussed what is a PC and the buffer and the card can hold 250 GB of information. The answer to my question is no((
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 23:48
Бисо wrote:I wrote, I gave quotes which were at the beginning of the topic.
These quotes are, unfortunately, not to my questions but still thank you very much!
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 23:51
.Xenia. with all due respect but just some sort of support on the forum nekompitentnyh interesting that all meets not answer questions and refer either to the hours-long video of Michael or message of Michael for altogether different topics but you seem unable to answer simple questions apparently will have to wait for the responses Michael.
Инкурват
Re: Map Of Male.
Post by Инкурват » Fri Aug 21, 2015 23:54
Beso.Xenia. the question is how do you use these cards and answer questions if they can't explain than an ordinary plastic card with this figure differs from card Masculine?
While I understand that you just all the difference in the anomalous zone of card production and modification of the laminator. Please add if someone that understands.
Re: Map Of Male.
Post by Мастер 108 » Fri Aug 21, 2015 23:55
Инкурват wrote: what is this anomalous zone and the laminator modified.
To Perm, etc. territorial anomalies is not relevant. The working area is anomalous (for different purposes) many ways.
You're probably too lazy to read the whole forum, and he has grown incredibly :? Well, I one way will be offered; take your favorite mug/Cup/jug/etc and write on it with a marker matrix a Panacea. Especially for lazy and hurried this matrix (3x3) is written as:
AIT
WYO
ONYA
And one day, voila! Inside the circles will be the anomalous zone with the properties of a Panacea. I hope it is clear that water is poured into the mug after a while too opensees :ay And that's what the Panacea - will somehow do brainstorm relevant thread on the forum. Huh? 8)
Инкурват wrote: and the modified laminator.
Well, this type of know-how, like... :oops:
Бисо
Re: Map Of Male.
Post by Бисо » Fri Aug 21, 2015 23:59
You asked: If I make a card with the same picture whether I will get the card Masculine?
The answer from the quote: "Technically, the digital part of it "weighs" about 250 gig of Informatii on each card (approximately) ...."
I apologize if I did not understand what you are asking and I gave unprepared.
.Ксения.
Re: Map Of Male.
Post by .Ксения. » Sat Aug 22, 2015 0:01
Инкурват wrote:.Xenia.thanks for the reply :) :o
Thank you!
1 and 2. Well, the laminator is "charged", for example, similar to bracelets Panacea, simply speaking, are mentally programmed to work a certain way, plus at the time of sintering is placed next to the turntable Rinat, well, at sintering, the material slightly changes its properties, and this contributes to the fact that at this point the content (information part) is more powerful than "prescribed" on the material.
3. The mental part of the card (broadcast) made by Michael and me.
4. Modules broadcast included in the content of the card, named for convenience. You could also call them the programs/buttons/anything...
About translation better read a branch about broadcast :)
5. Know how to ask the "material information" :) broadcasts are stored on the computer as files. Material whether files stored on the computer? :)
Инкурват
Re: Map Of Male.
Post by Инкурват » Sat Aug 22, 2015 0:08
Мастер 108 wrote:many ways
it's obviously too know how? ))) Perm anomaly, we measured the length and breadth are there any data from this is as I understand it created the anomalous zone cards? I apologize if you really dig that is my mind. I say we have to believe a word that area of card production abnormal? Or all the same will be called the coordinates, or specific data?
Мастер 108 wrote:You're probably too lazy to read the whole forum, and he has grown incredibly
Do I have to search a simple otviewit all those 80 than the several hundreds of messages in each? I spent almost several hours of time to explore a few themes and have not found the answer so I'm asking.
Мастер 108 wrote:I to you one way will be offered; take your favorite mug/Cup/jug/etc and write on it with a marker matrix a Panacea. Especially for lazy and hurried this matrix (3x3) is written as:
AIT
WYO
ONYA
And one day, voila! Inside the circles will be the anomalous zone with the properties of a Panacea. I hope it is clear that water is poured into the mug after a while too opensees And that's what the Panacea - will somehow do brainstorm relevant thread on the forum. Huh?
I ask You not how to make operatsinnoy water, and the Masculine card is different from a normal plastic card with the same printed pattern. Do not leave from the answer.
And another question was about the anomalous zone and a modified laminator. But this I understand will not be answered.
Инкурват
Re: Map Of Male.
Post by Инкурват » Sat Aug 22, 2015 0:12
.Xenia. and you honestly know than the usual modified laminator for the production of these cards? It is possible without disclosing know-how to answer than how or what technology. And how it becomes suspicious as many properties as many words and yet no response. Well, just so the cat in the bag do not buy. And then maybe I hand over the laminator'll take what that secret men think watching some all-male video ;) and will my card Masculine ;) or not?
Re: Map Of Male.
Post by Мастер 108 » Sat Aug 22, 2015 0:13
Инкурват wrote:[
Thank you!
1,2 - anomalous zone and the laminator answered above.
3. The mental part of it for cards of Male/Female was created by Michael and Xenia
4. Stream is not "new information unit", is a new technology, and you are too lazy to read the forum - short answer is not to explain, but you can try
5. Some confused the issue, but I'll try to answer.
Modules to maps - "mental someone the programmable part" - converted into a digital stream that (not card!) weighs in at 250Gb.
With the help of a translation this is, uh, shall we say, the information component, "sewn" (created the same hyperlink, you just want to write on paper) to physical media=the map.
.Ксения.
Re: Map Of Male.
Post by .Ксения. » Sat Aug 22, 2015 0:17
Инкурват wrote:than conventional plastic card with this figure differs from card Masculine?
I wrote to you about it :) the file broadcasts using a specially for this purpose written program is converted to these pictures ("star" or "blots" on the back). Very simplistically we can say that they are these translation files in graphical form.
