Sacred purpose clothing
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
The promised theme of clothing, as the shell is changing the energy characteristics of a person.
Clothing is something with which our body comes in contact daily. The person based in your path to self-development, not dependence on external stimuli, it is recommended to approach the selection of clothing as transforming the quality of the inner energy shell, not just from an aesthetic point of view. Wearing particular clothes, we change not just his image, we change the input for your information double. Look closely at the people around: why there is a feeling that some clothes, though simple and cheap, supports “internal energy status” of one person and another, albeit bright and dear, the man is “not right”?
For the ancient clothing and accessories was more sacred object than ordinary. Every detail, material or colour was dictated more defined energy intentions than social (although they are linked). And now clothes, as an energy shell, or is able to maintain a cultivated inner quality, or to destroy them.
And even if You feel that You still deeply...that You wear, daily wear and choose clothes You Express (support) certain quality: the quality of the Chinese, who do not care for quality, superior price, and quality of the designer, which in addition to how crazy different and difficult to call.
Choosing the right clothes can develop a person certain abilities, and, most importantly, accumulate them. That is why it is impossible to transfer the garments to another person, and the more used clothes worn by another person. In this respect, interesting is the use of clothing as a universal drive of the current States of the operator and their source: if certain clothing, the operator experienced a particular condition, these clothes in the future is a source-a beacon in these States. We are able to go back to the same feelings and experience the same state simply by using a particular clothing. EMF clothing ARMOR with the use of metallic fabrics is enhanced clothing as a simple carrier of information, as a matter of fact represents not that other, as the antenna field.
Choosing the right clothes should not be subject to fashion, that is, not dependent on external rhythm. Follow fashion in this way is nothing more than a setup operator to external rhythms. Choosing the right clothes are able to make fashion that is influenced by the external rhythms.
Clothing capable of expressing human behavior and to influence it. The clothing can be compared with the application of a tattoo on the body: it is able to resonate with inner qualities of a person, repeatedly improving and transforming the current information the settings of the operator. Clothing is an intermediary between us and the outside world, as they are able to change the input to other assemblers (CPG). It is not in social status and not depending on other people's opinions. Every person who had contact with the operator, even once, creates an information channel that affects the operator through the creation of an "information copy", and information, which carries clothing, is one of the main. In other words, the infochannel, which forms through the breaking of internal energy clothing, as a connecting sheath, connects the operator with his “informational copy” which in turn is the result of the work of other assemblers.
It is not in fashion or public opinion, just any garment, its colour, form, material and combination changing properties of energy that subconsciously read out and is input for the other assemblers. And even full and genuine independence from other people's opinions (which is essentially an attempt to “rubbing” of this information) can affect it only to a small extent. And the impact of this information is really strong, though often not even recognized. This channel and the adjustment information copies has long been used and widely used techniques of manipulation of mass consciousness (think at least a school uniform).
How we can use?
Tactile sensation generated primarily by fabric and form are key. Ideal in this regard is the clothes, which, through material and form performs some kind of interaction and customization with the brain of the operator. And everything is important here, even the symbol or brand, which can set the brain of the operator as at the highest levels of GAAP, and the zombie mass. And the cost of clothing, as such, there is no longer has a value, the value is the understanding of the main laws of simbolotti few people understand what to do with their energies and hung himself “Nike” or “Louis Vuitton”. Meanwhile, this largely determines the behavior of our brain. But here one more important aspect: our consciousness has yet to “digest” the fact that we have metal on you: in one case, it means to take in another match.
And here it is possible to identify three types of clothing: the first is when the clothing itself is not, and we respond to ourselves from the position of the energy principle. The so-called “clothes of Adam” is a specific energy shell, covering us. That is, we essentially covered the energy shell, which is determined by the response of our energy to external energy.
The other type of clothing — when the body is covered with symbols that corresponds with the tattooing, which in ancient times was used by many cultures to enhance the perception of yourself or set yourself on a certain frequency.
And, finally, garment, how to develop the energy shell, which creates additional information filr in energy metabolism of our body, our CPG with what we wear.<
How we can use?
Aura
Re: About clothes
hats
Headdress as part of one of energotoniziruyuschim skins works mainly with vertical energies and supports the work of the 5 main points top of head:
These points divide the head into 4 sectors, each of which has its functionality, but all are able to perceive the energy of the subtle worlds. In this sense, all hats can be called “heaven” transformers, or transformers of energy of the Sky. The energy of the Earth passing in this case through the human body in varying degrees, depending on the alignment of structure, headdress not transformirovalsya, but persist. In other words, correctly using hats we can maintain and develop the energy of the head and brain in particular, and this, in turn, may lead to higher handling and control of your energies and control of the physical energies through the TLU.
At the software level hats affect the redistribution of information in the vertical information channels. Horizontal (Yin) energy is most receptive to such information, in fact, this is the reason why there is a rule of head coverings by women in the churches.
Re: About clothes
T e is obtained for protection, not to now I regret it or not developed that seems more likelyАура wrote:At the software level hats affect the redistribution of information in the vertical information channels. Horizontal (Yin) energy is most receptive to such information, in fact, this is the reason why there is a rule of head coverings by women in the churches.
Aura
Re: About clothes
For protection that is not developed in the male vector, and developed in its upside – down. Women from heavenly threads is stronger than “insert” (hence the myth that women are supposedly more sensitive, they are the best psychics, etc.), but not all of this information can transform in the usual horizontal operating plane. And if not to transform, and the store also does not work, hence the second myth – about the talkativeness.Корвин wrote:te is obtained for protection, not to now I regret it or not developed that seems more likely
Therefore men's hats - vertically oriented (cylinder, cone, etc.), and female - horizontally (the wide brim hat, scarf, etc.). Vertical headdress was traditionally awarded to women who have the power, that is developing in the male direction.
СтаниФилмТВ
- Has thanked: 24 times
- Been thanked: 63 times
Re: About clothes
Still wondering about the lower attributes of clothing, such as pants. Once upon a time there was a fashion for wide leg pant, jeans were the "pipe" or "pipe from the ship"
What can I say? Old, long sunk into oblivion, lame fashion. But on the other hand, as said, the Aura, the clothes builds energy in a certain way. For example a man wearing a jacket with broad shoulders, he appears to be a more physically strong, and courageous. Subconsciously people will form different views and relations to male or broad shoulders, or the man whose ears are wider than the shoulders. The very same people putting on clothes for example, emphasizing or amplifying qualities of the physical body also subconsciously feels like it visually perceive us, and unwittingly reaches a certain energy state which eventually gets used.
Wide leg openings (pipes) dressed man, subconsciously perceived by others as "strong roots" , "strong Support", "strong Earth energy or a strong connection with the Earth" the Opposite (female) gender subconsciously, to perceive the man in the wide trousers, as a person who can be "counted on." Therefore we can say that wearing wide-legged pants, builds energy on the good connection with Earth energies.
And what is interesting: the modern home fashion, dealing massive impact on the public consciousness, preaching clothes in a unisex style, which so well evokes the energy of the person in a certain way, and the result that gay pride parades happen more and more often.
Now normal "patsanski" pants in the afternoon with fire not to find.
It's the fact that you stupidly follow the fashion turning into who knows what, but the same can also through the clothing to shape their energy body, approaching this case with the understanding of the energy processes.<
Aura
Re: Sacred purpose clothing
Aurathank you very much for the useful information!
Inspired on new ways to use not only the shielding scarf, but also clean up deposits of conventional scarves and stoles in the closet
Particularly interesting were
), it turns out, everything is there
I will try.
Been waiting for, when will the female version of the shield pant (envy the success of her husband with the shield cowardsАура wrote:Further, the female aspects of wearing a scarf. Shielding the scarf can be used as a belt or wrap around the hips. The most important aspect of such use of the shielding scarf is the preservation of the energy of the uterus, which is the coordinating center for women. Through this body, the woman builds both physiological and energy and it is also important that the mental plane (in other words, women can think of the uterus). Properly circulating the energy of the body allows the women to work with space and to capture the energy of the space.
Aurano matter how much I try to nicely tie a scarf shielding, it will still eventually wear is laid out on the male version. Still the fabric of the scarf that the external that the internal is very slippery, hard to tie nicely and hold over his head. Does this mean that I have to be dominated by masculine traits?
Aura
The scarf is more associated with women's garment, the fabric was chosen so that in the first place to make to make it possible for men option of wearing, the woman essentially could make candy out of everything. Soft, Varsova that cloth would not be suitable. Maybe women will take a little more effort, but it is familiar, and easier and more natural. The male version is easier to implement, perhaps that's why You come to him. There is gravity, so the horizontal folds to form, by definition, difficult. But brighter the result. The more effort is invested in creating the image, the more the image works for You. Perhaps You just have not practiced and mastered the ways of tying scarf on the female version, so the result depends on the principle of "like work". Do not forget about additional accessories for scarves and their fixation, such as rings, scarves and brooches. But as has been said, everything is based on objectives: what energy You want to bring.ОльгаВВ wrote:Aurano matter how much I try to nicely tie a scarf shielding, it will still eventually wear is laid out on the male version. Still the fabric of the scarf that the external that the internal is very slippery, hard to tie nicely and hold over his head. Does this mean that I have to be dominated by masculine traits?
Very interesting topic, thank you. I do apparel professional, and a pleasure to read. As for the shielding of clothes I wear that scarf for quite a long time - I am glad that it can be worn to work where protection from radiation is more relevant than at home (at home I try to pull out of the outlet unnecessary appliances, especially at night). Kill the scarf special this clip and create a horizontal crease. Did it unconsciously, probably for aesthetic reasons, but it turned out here that it has more energy, and rationale. Now I will be even more deliberately to wind him and lay the folds.
a pointless exercise )) Because when the device is deactivated, it emits nothing, physically, the circuit is open, no electrical processes. Also not clear is the desired result of disabling the electrical appliances. In the walls of your apartment (house) wiring, which runs the current, such as a refrigerator - you don't unplug it at night? What do you have in the walls are almost always 50 Hz frequency. Wifi home and you are apparently turned off is a constant 2.4 Ghz. And even if turn off the fridge, spiteful and unadvanced neighbors definitely do not ))) And if the telecasting and broadcasting to consider, along with cellular networks entirely...(the house try to pull out of the outlet unnecessary appliances, especially at night)
With regard to the effects of radiation on the brain when closely attached cell to your ear - there is such radiation, which can wirelessly led light for its power. Wow - power. And the rest of the radiation decreases proportionally to the distance, and quadratic. So... off in the night something out of the socket is meaningless.
Maybe it's then up to the kit "kerchiefs" to release "protected sleeping bags" ?
Aura
Probably only person, it happens in the campaigns at least a few months of the year, the house can sleep in a sleeping bag. For the rest there is shielding sheet and the blanket, giving not less protection during sleep besides bass+treble range.
I think even if the sockets in the work, the wifi just first goes to the expense) and rightly so)мимоходом wrote:wifi home And you are apparently turned off is a constant 2.4 Ghz.
although.. it is still necessary to coordinate with other wifi-adname at their presence and that they have a disagreement)
which would be to achieve..) because the difference in recovery for the night when on./off. router clear and unambiguous in favor off.
however, we have not in the apartment, the neighbors are not close.. but in any case, the "minus one brodilka" better than non -
