Noopendant "Intuition"
- Has thanked: 1 time
- Been thanked: 182 times
Nookular I level "Intuition" includes:
I. a Package of basic programs (questions and discussion here http://www.mindmachine.ru/forum/viewtop ... =35&t=5791)
II. The package of specialized programs to connect the channels of information, protection and stability.
Connect intuitive channel information ver 3_1
Opening information channel of dreams ver 4_2_1
The connection to the communication channels of information double ver 2
The connection of channels for direct access to GAIP ver 17
Viewing the variant lines ver 3
Protection of channels of information ver 5_2_2
Protection against the use of bilateral channels ver 5_3
1. Connect intuitive channel of information.
Intuitive channel - main channel information on the 1st level. Characterized by a General advanced search information in horizontal and some vertical levels. Normally, all these phenomena receive information through this channel describes the General concept of “intuition”.
2. Getting information from dreams. Setting dreams of obtaining certain information. Comment: request to better shape the day and not before bedtime.
3. Connection to some channels of communication information twin.
Information double – the conventional concept, it is information that exists only at the program level. On the one hand, all the thoughts, deeds and actions of man affect his information counterpart, on the other hand, information is double and is formed with other assemblers (TLU work of others). Can be called information double a “infopathom” operator acting in its interests at the software level. As the informational counterpart exists at the software level, i.e. in the hierarchy of programs is higher and has more accessibility than the actual operator, you may have access to information, access to which the person would have left much more time.
4. Connection to some channels, and direct access to GAIP. To some, it means the relevant current access keys. In other words, this package will work more effective than longer and more productive was working with other neocolony I level. The most advanced keys for access to the I-level is neocolony Master, the body and the Microcosm.
5. Viewing the variant lines
And basic programs “navigation possibilities ver. 8_1”, “1-the essence of ver. 2_1” and “operation of the integral field ver. 4_3” allows you to view information from other variant lines. Information may be requested based on the current situation, situations of the past or the future.
In add-in packages includes:
a) Protection of channels of information. Protection is triggered when you try virtual programs to introduce information on a particular channel of information.
b) Protection against the use of bilateral channels
Comments: usually used complex of connecting multiple channels. The connection channels are on the basic principle of operation of neocolonial, that is connected to the channels of information cannot be constantly and forever the connection of a packet takes place under the task query after executing “tasks” channel is disabled. This kind of “safety” as the absence of a directed request, but an active channel is connected, firstly, it is very energy-intensive, and secondly, admission is fraught with chaotic (unstructured) information.
To work most effectively specials. programs Intuition is recommended to combine with the spices. packages Microcosm. Gently combine with the Corsair (a strong influence on the external space).
III. Group domain
IV. Individual domain level I.
Re: Already in sale - nookular "Intuition"
If you collect everything sold in the store - and so it is possible to predict the matches. For 10 years forwardРоссомаха wrote:With this pendant you can guess the results of matches?
Not, in fact, different manufacturers and many strong study intuition.
Guessing scores is rational thinking, which allows to determine causal relationships and output in the form of concrete results
Indicia is irrational thinking, which allows relationships to choose something based on "I think...", "I feel", "I have a feeling." When running intuition - everything you say in this state - all the truth. I have repeatedly observed is when a man finds long lost things, knows exactly where he made a mistake, knows how to act and what's best for him and so on... Purely a practical condition, the only trouble is that very vague, blurred.
If you have both types of thinking, and even gained in the process of training and corpus callosum of the brain - you will not be difficult to translate the irrational (but 100% true knowledge) in a rational (but often incorrect) without loss of fidelity to knowledge and rational precision. Perhaps numbers, all depends on the person
In itself it will not develop even if all the magicians of the world will sit around you in layers of magic stars and will cast over you. You can't build muscle, depending on TV strokes.
Pendant, judging from the description, this flow does not offer (it would be strange)
For the development of the corpus callosum requires personal mental and physiological exercises that will increase that spike hemispheres. In order to see the results of matches. I imagine it is.
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Maybe Yes, maybe no. More precisely, it depends on who is guessing. It is important not to confuse intuition as a way of getting information from information. Nookular Intuition gives you the opportunity to expand the scope of information, but to make the operator of the navigation work is unable, or rather, only partially, using some basic programs. Any unit of information does not wander randomly in the universe, GEIP is hierarchically built structure with a clear system of levels and their corresponding markers (key) access. They say that “information rules the world”, and this expression (as is often the case) actually has a deeper meaning than the one that was put in there ezrachi it. In other words, information about the results of matches, intuitively or logically, can't get to the person “accidentally”. In the first case, this condition will have a corresponding access key, in the other – in principle, the same he, only having material expression as developed analytical skills. Those who consciously developed intuitive abilities, I know that there are certain times when developed intuition, perfectly manifesting itself in one area, stumbles as if on a wall in another area. This “wall” and are certain keys to access the different structural elements of GAAP.Россомаха wrote:With this pendant you can guess the results of matches?
Can be roughly compared to the work of Intuition pendant with a hit of the operator in some library. The operator receives access to certain information,that is, gets the ability to search and retrieve information. But the hit man in the library is not identical to the possession of all this information. Information you need to be able to look for (setup) and even more importantly – to absorb. The programming is carried out via the information channels of the triads, which were described in the subject mindmachine.ru/forum/viewtopic.php?f=35&t=5791">viewtopic.php?f=35&t=5791 That is, if the person is irrelevant to the matches, the information on an intuitive channel will be difficult. If he assume works in this field, or just deeply interested, watching, reading about it etc., then it is likely (depending from the fact whether he has the ability this information to learn).<
Aura
Can, interesting combination, special. packs of the Corsair and intuition will complement each other. Try it first mate, if all goes well, then no.Жанночка wrote:Can I use both "Le Corsaire" + "Intuition" and how to make it more effective?
Aura
Will not interfere. The bandana works with AMY, though locally in the area of the brain, nookular works with the integral field, "software shell". Rather, will help the orderly processes in the brain, not subject to constant external chaotic influences, positive impact on the structuring and the ability to operate independently with its integrated field.Жанночка wrote:Aura Tell me, bandana not to interfere with Neocolony Intuition? Should they be worn separately?
All kind time of day!
Intuition wear for 2 weeks ,along with a Corsair. I write here because the opinion seems to me more to intuition applies. It turns out that intentionally does not work spontaneously work. I tried to give the pendant relative to the task of guessing of match results - something pedalos what is not conventional about the result. But the unintentional stuff works great. For example, I don't eat meat but something possessed me to buy bacon, in the evening comes to me friend and says that he dreams of fried bacon. Once again, go past the shop window with clothes and suddenly very tempting to buy some red women's belt, in the evening gave the girl because where else to put it, she squeaked with pleasure, said it wanted to buy. And so many small things. The question how to attune with the pendant and make it work in a specialized field and not in General? or is it a kind of side effect of the combination of intuition with the Corsair?
Hmm. Intuition has not yet acquired. But why do You think that giving a specific order or instruction, intuition will Wake up and say everything you need? Intuition is guided by your unconscious, not Your wishes and orders. Even in Your examples can be traced that You were able to do what was not aware but apparently wanted? And friend ate and the girl were happy with?)) of course all this is my IMHO. But let's face it. In your example, the result of the matches. Why are You trying to predict the result? As You interpretiruya clues, signs or whatever else You think of? I do not think that the pendant is able to clearly say who will win or lose in a particular case. especially if You are partially fixated on that. Ie has its own selfish interest.
Because as I understand it was stated in the pendant is configured to me and reads with me.Тоха wrote:But why do You think that giving a specific order or instruction, intuition will Wake up and say everything you need? Intuition is guided by your unconscious, not Your wishes and orders.
So in these cases I'm happy with but it was accidentally, and without my conscious desire. That is, it turns out that the pendant is only subconscious listen? Why not make him and the mind was listening too? And that is about all we can say - and this is your subconscious wantedТоха wrote: Even in Your examples can be traced that You were able to do what was not aware but apparently wanted? And friend ate and the girl were happy with?))
Selfish or not selfish I just wanted to check. And that selfish interests intuition is not supposed to work?Тоха wrote: Not think that the pendant is able to clearly say who will win or lose in a particular case. especially if You are partially fixated on that. Ie has its own selfish interest.
Interestingly, feedback neocolony "Intuition" very little, judging by the survey results, intuition is the most desired quality, and the reviews on it all less.
"Here are the TOP 10 desirable qualities obtained through processing of the responses of 720 people.
1. Intuition
2. Energy
3. Rejuvenation
4. Ideal weight
5. Sexuality
6. Alternative vision
7. Dedication
8. Determination
9. Clairvoyance
10. Charisma"
And then wonder why wishes don't come true. Having to hand tool for "sbychi dream", who is really ready to use it?
The following 4 points - Energy, Rejuvenation, Ideal weight, Sexuality - can be attributed to working with neocolonial "Body", but, alas, it is too far from the leaders in the number of reviews.
Leading "Master" and "Le Corsaire", although quality, are working with them, are at the bottom of the list. Still, the question of self-affirmation in society for the majority remains the main. Dependence on the opinions of others? The importance of social status? The desire for power? So... thinking aloud. All IMHO, of course.
1. Intuition
2. Energy
3. Rejuvenation
4. Ideal weight
5. Sexuality
7. Dedication
8. Determination
9. Clairvoyance
10. Charisma"
It is unlikely that the creators of the pendant "Intuition" really was able to find the right keys to GAAP: them no they can't open it, because getting reliable information about the future, which in our case will be the manifestation of intuition ,will endanger entire sectors of the economy
The bankruptcy of a casino, bookmaker offices and organizers of lotteries will have an impact not so much, but the exchanges will happen, quite frankly, trouble. And will not let the global financial crisis to develop alternative (the owner of neocolony "Intuition") scenario
It is likely You soon.. about a prediction or prophecy..some..)Дэм wrote:reliable information about the future, which in our case will be the manifestation of intuition ,will endanger entire sectors of the economy
And You by "intuition" you know something else?нева wrote:It is likely You soon.. about a prediction or prophecy..some..)Дэм wrote:reliable information about the future, which in our case will be the manifestation of intuition ,will endanger entire sectors of the economy
Well, sort of "intuition" closer to the feeling, it is more subconscious than logic. Undoubtedly, the ability to translate a vague feeling into a logical form, and to interpret authentically feel is a great gift worthy of a seer. But to a greater or lesser extent, all people have intuition, but to understand exactly what is felt can not be many. That is: first, intuition and foresight somewhere after.Дэм wrote:And You by "intuition" you know something else?
Aura
The past and the future no, it's just one of the programs. 2nd integral field GAIP timeless. For this reason, there is no clear and "credible" information about the future. In GAAP there are all options for the future, because GAAP more accurately described as geometric field, it has the structure, or architecture, with its "peaks" (the most probable variant of the line) and "depressions" (less probable variant lines). You can view one or another variant of the line, so any information about the future will be more or less likely. Reliable information about the future there. More interesting, the future is not more difficult than predicted. You can just shape it consciously, and it is possible to reflect on external effects, then Your future is behind You creates someone else. Intuition is a very specific software concept, and applies it to the present, not the future. This is one of the information channels. Similarly, you can say that when a person reads a book, he anticipates the future.Дэм wrote:because obtaining accurate information about the future,
And this question had already been raised and understood, read the topic from the beginning, especially just 1 page
The first few times she was very surprised - as I pointfile? A thought - now open the door and enter this. A minute later and it happens , and we have employees about 500, and in walks the one and once a week do not meet in the hallways.)) It was interesting to analyse the origins of this feeling that it's not even intuition, as I understand it-a faint feeling of something, and as though this action has already happened and I just know that to be the case))Аура wrote:Past and no future
The pendant, which, at first didn't notice at all. Now I can clearly see his work. Of course this is in combination with other pendants, plus do is work on yourself. To search and dig information is no longer necessary. The query response come easier and easier.. From searching for parts on the car, to global issues the nature of Existence. As a clear understanding, comprehension, truthfulness, certainty. It's not that when someone gives you a ready answer that is not understood. Here is the answer, even if you came across someone that has the authenticity you can feel it with your whole being. It is funny, ask the question day on the forum, by the evening you already have a ready answer. And the forum already has the answer and is not needed at all. With the same success it was possible to write in the notebook work. And it really is better to record things to track will be much easier.
