Line shielding clothing and furnishings EMF ARMOR™
- Has thanked: 1 time
- Been thanked: 182 times
Line of clothing, accessories and products for the home ARMOR EMFshielding from electromagnetic radiation (EMR).
https://mindmachine.ru/catalog/shop/cat ... evice/emf/
Nowadays almost every person, including children, virtually around the clock located in the area of mobile phones, spends a lot of time at the computer, surrounded by many appliances – microwave oven, TV, fridge and even a hair dryer are sources of EMI.
We do not see or feel the radiation, and even used to the constant presence of different emitters so that it is perceived as the norm. It has long been known and proven that AMY, penetrating into the human body, can affect the functionality of the brain and other internal organs, cardiovascular system and even skeletal system. For example, it was observed that the deterioration of health usually occurs in “rush hours” of conversations on mobile phones, when the maximum capacity of the work cell towers, and removal from areas of maximum density of the EMI (for example, outdoors, in the woods, in the mountains) is associated with relaxation and rest.
Many people are having the opportunity to work on the free schedule the best efficiency and concentration at night and early in the morning, when the number of emitters and their activity is minimal. It is an individual observation that may feel almost every. Accurate research data on the influence of different AMY on the functionality of the systems of human body here we do not give, if desired, they can be easily found on the Internet.
But there is another aspect of EMR, which is not so widely covered. The human nervous system is designed to transmit electrical signals from the brain to the periphery of the body and Vice versa and in fact is a powerful antenna that perceives the external electromagnetic oscillations. As a result, AMY is able to influence the activity of the brain and nervous system in General, in particular, on the entire mental, mental, and emotional activities of man. A lot of people experience the inability to effectively manage thought processes or manage their emotional state (as well as various biological rhythms that are directly related to the electrical functioning of the nervous system) is not due to low skills of control and self-regulation, but rather because the electrical activity of their nervous system is exposed to constant, strong and chaotic influence of external AMY.
It is known that in the Soviet era began to develop psychotronic weapons, based on electromagnetic radiation. Science has long been known that electromagnetic radiation of a certain frequency, resonating with the spinal cord can cause electrical surge in the brain of a particular desired frequency. And we can only guess at what level these developments around the world are now. In today's reality, the totality of AMY's daily affecting every person, not just potentially dangerous, a real threat: we live in an artificially created wave medium, the radiation power which is several thousand times higher than natural.
Just recently, in early 2015, in connection with the development of mobile Internet, cellular companies in Metropolitan areas began to actively place a cell tower in the area of residential areas, in areas with high density – almost every 15-20 m. they can observe the inhabitants in any district.
Now, virtually all use water filters or buy bottled water, choose environmentally friendly products, but perhaps even more important to protect yourself and your family from the effects of EMP.
Series of shielding clothing and accessories ARMOR EMF produced using metallic screening material and is designed to significantly reduce (several 1000 times in power) the influence of external AMY. These fabrics are novelty in everyday life, but for a long time have proven themselves in industrial environments with increased radiation.
Shielding metallized fabric composed of fibers of cotton (fabric ECOTEX)/spandex (knitted fabric MSILVER)/polyester (fabric VSILVER indoor), entwined with a very fine metallic wire containing silver that in addition to the protective effect gives products and anti-bacterial effect.
EMS clothing ARMOR is not only a passive protection against the adverse effects of EMI, but the device significantly help on the path of self-development. For example, the use of shielding headgear, becomes noticeable almost immediately (within a few tens of minutes) - it helps to reduce the activity of the internal dialogue, initiated by external AMY, achieving meditative States, allowing you to relax from the chaotic neural activity, concentration of intellectual activities, to manage their emotional States, as well as allows you to effectively get rid of the so-called stress.
For people interested in self-development, conditions caused by decrease in the intensity of EMR, can be a starting point to search for the desired, for example, lucid dreaming or various altered States of consciousness used for deep diving in themselves (including a meditative state).
It is important in the description of the clothing line EMF ARMOR will be noted that in contrast to the known prototype – cap of aluminum foil is a special metallic fabric that provides protection in clothing EMF ARMOR, not shields electromagnetic radiation completely, but significantly (several 1000 times in power) reduces the level in the range of major adverse household electromagnetic radiation, which include:
radiation from mobile phones (300 MHz — 3 GHz, in Russia — 900-1800 MHz)
radiation microwave ovens (2.45 GHZ)
radiation of the computer (system unit — 50 MHz — 1GHz)
radiation wi-fi routers (900 MHz — 5 GHz)
— other.
It is known that there are favorable electromagnetic fields, including the natural field of the Earth (10 Hz), full long the shielding which would be unfavorable for humans.
All fabrics do not require grounding, so without any problems can be used in clothing and accessories.
Evaluation of radio-physical characteristics was carried out in the Institute of Medicine of Labour of Academy of medical Sciences and testing laboratory of the Ministry of Defence of the Russian Federation . The fabric has a health certificate.<
— other.
Re: coming Soon!
The first product we developed and will soon be completed, production is
3-layer shielding EMF bandana ARMOR
Manufactured using shielding fabric ECOTEX. In contrast to the protective clothing from the category of workwear, three-layer bandana EMF ARMOR except the metallic fabric has an upper layer and a lining made from 100% natural materials (linen or cotton), so aesthetically you can use it not only at home but also outdoors and possibly even work.
Specifications:
The attenuation of the intensity of AMY:
In the low frequency range (from 0.3 to 1300 MHz) at the level of 70-30 dB;
In the high frequency range (8,4-16 GHz) on the level 22-16 dB;
Surface resistivity: not more than 1.0 x 106 Ohms;
Composition: polyester 25%, cotton 25% , electrically conductive filament of 50%
Surface density: 220 g/m2
Bandana is made in two sizes: S/M and L/XL
And three colors.
The decibel dB is a logarithmic unit of attenuation , for example, attenuation at 30 dB is 1000 times attenuation.
Specifications:
And three colors.
Re: coming Soon!
Planned for release:
— shielding covers for mobile phones
— shielding underwear
— shield t-shirt
— shielding jacket
— shielding blinds and curtains
— shielding cover for baby strollers
— shield blanket and plaid
— shielding canopy for the bed
— shield t-shirt
— shielding jacket
Re: coming Soon our new development!
It seems that soon will come back in fashion pajamas and night caps.
Невесомость
...goodbye tin foil hat.
Very good field of creativity. I also propose to sell the fabric strips!
The weightlessness of the fabric and is now in the open market it footage.
Can't say that enjoyed a long and what exactly gave wearing bandanas. Wore for a few hours in the office with interruptions. Usually all sorts of interference and crosstalk from AMY give ringing in the ears under a bandana a bit or very much reduces this effect. Praktichesski noise is not audible , despite the fact that different devices on poles on the street across the road (such as the above photo posted Andrew) . Rather, we can say that after working day a little easier , as there is less harmful effects from various devices on the brain. Wore , on and off, because to say what will happen if worn all day, yet can't. But the fact that it is easier and less ostrosti , it osutils. The rest can say when I will be able to use a longer time.
I also managed to test a bit of the finished product.
I have periodically come to such a state that you want to do something, for example at the computer, and anything it does, but don't want to do, and instead just sits and postpone it for later. Or comes from an overload of incoming information, when Skype, at the same time someone in ICQ, you need to answer the letter next to someone else, loading your questions, it puts me in a stupor and I drastically lose performance.
Bandana these States are removed, there comes some peace of mind, stop rushing from one thing to another, increases productivity and concentration.
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
Here are the things, in combination with the Mat of Grace..
I like the new direction. Good luck!
The bandana will be in three colors
Oh, super, just the other day thought that you should receive something similar (protection from EMP)
Well, at least I have written already how much for the bandana! I've tried myself to imagine) ,clearly colors for girls is not enough ))) in the first photo Andrew similar to doctors, the second - well, the obvious tourist, to last exactly Cook well, or his assistant.
The inner layer is cotton , the middle layer fabric with protection from EMI , the outer layer is cotton.Астероид wrote:sandwich is a three layer real? Or as often happens - one, and the rest will be considered fictional?
The cost will be 4500 RUB.Аиша wrote:Well at least I have written already how much for the bandana! I've tried myself to imagine) ,clearly colors for girls is not enough ))) in the first photo Andrew similar to doctors, the second - well, the obvious tourist, to last exactly Cook well, or his assistant.
Started with three neutral colors, it is not very clear, what is more interesting for the buyer in terms of product range in terms of colors.
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Re: Already on sale our new development!
One day of testing bandanas EMF ARMOR.
The product looks like, though NAT. crumple tissue quickly. If you wear this product "to the people", then you need to iron every day. Len (orange bandana), I've enjoyed it more. The effects:
After 20 min. there is a state of calm, centeredness, self-absorption. You can call it a meditative state as much as possible a meditative state at a constant active involvement in social processes. The state is both suitable for work and leisure. My phone usually rings a few times an hour, pulling out of the current processes, and there are certain reflexes on the ringtone. Bandana is tracking: the sound, the call, the caller...response disappeared. The same and certain EN. quality and flows.
The status of work in bandana recalled her time in Chiang Mai (Thailand): practically there is no distinction between art, work and free time. The feeling of doing what you want and what you want is your job. There is no need something to get done, everything is calm and happy. There is a feeling that being in the city, inner rhythms as occur in nature.
After 2-3 hours. Observations in the external sphere: there is an obvious extension, the external field becomes more fluid and responsive to conscious control. On the other hand, well-monitored third-party influence and all the influence at all. If you want – the impact is skipped if not screened. To some extent this is an automated process. Can be called a bandana “energy filter”, but it is possible that this filter works harder, most likely, due to the fact that the energy-effects in its material manifestation are almost always electromagnetic in nature.
There are changes in information from GEIP, navigating the InfoSpace higher quality in terms of more controlled. No information is received, it is not clear why and what, and the operator receives the right moment information. Interesting sensation (it is still necessary to check) that the line variant, which seemed distant, as if closer.
Test day was eventful (three trips in different parts of Moscow and a few meetings), all painted up in minutes with a margin of a maximum of 10 minutes for unexpected traffic. Wedged another case (minimum one hour), and the schedule had to be reconstructed. Here comes the impulse of the need to let go of the situation. Testing so testing is necessary to see what happens. It was decided not to even look at the clock. The result: everything is wonderful docked, the maximum delay is 10 minutes.
But the most interesting must have been to sleep in a bandana. The consciousness is not affected in any way, but the dreams were very positive, you can say “pink”, children and inspiring those who give attitude for the whole day.
Apparently, despite the functional simplicity and clarity, a bandana is an artifact, more interesting and unusual than it seems at first. Of the minuses, after all, is the artifact for home use, unless you are a hippie or not doing advanced stalking. While the primary observation that we managed to track one filled with Affairs of the day. Will experiment further, maybe something interesting will pop up on the weekends.
Aura
Size S/M for head circumference 54-58 cm, size L/XL - 59 to 65 cm
- Иван Славов
My favorite belt though I rarely wear/ black with skull and bones /popular to the masses pirate sign/..Андрей Кабанков wrote:what will be more interesting to the buyer in terms of product range in terms of colors.
Complete loss of signal the phone depends on the phone model and signal level in a particular place.
