Wallpapers for rise of the energy of the room
новый Искатель
Post by новый Искатель » Wed May 20, 2015 16:39
hi all. doing the repairs, and I wondered what Wallpaper to choose from the point of view of the energy space ?
leaning towards bamboo. But suddenly there is any ways ?
or any ideas on what realties there is torsion of the Wallpaper, or ionization, or from abdominal structures....
in General, what Wallpaper is better to stick to raise the energy of the room and seekresults from bad radiation ?
for meditation:
Bamboo fiber, fabric, shungite - PSI shielding. Shielding and space.
http://iskateli.info/showthread.php?t=1083
bamboo inside:
or maybe the tube ?
+ there is a good idea in the treatment of glue for sticking.
Friend insisted adhesive on the emerald water + FSC, + something else. In the end, the glue has a high energy and changing the space of the room.
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Re: Wallpaper for the energy of the room
Post by Ланцелот » Fri May 22, 2015 9:58
High, artificially hiked energy, is not good. Judging this indirectly. Classes on various practices are often held at home by the organizers. They sleep in this room. Many envy them, they live where they remained opened channels. If this happens for several years, then in life of such people, the problems begin.
Energy the energy of strife, but you need carefully to approach this.
новый Искатель
Post by новый Искатель » Fri May 22, 2015 15:32
and the more specific you can advice ?
and something like that vaguely, and about anything.
what will the Wallpaper ? what are the ways to raise energy ? not interested in the philosophy and practice scoring energy of the room. you give me the method, and with the dose I'll figure it out )
Смелый
Has thanked: 2 times
Been thanked: 79 times
Post by Смелый » Thu May 28, 2015 6:27
новый Искатель wrote:and the more specific you can advice ?
The Wallpaper in the photo rolls, wooden strip, will increase the energy of your space. At the same time will remove the dirty energy from the room. The glue does not matter, and the energy of the premise is not particularly changed. Except that smell. These Wallpapers need to glue the strips vertically.
новый Искатель
Post by новый Искатель » Thu May 28, 2015 16:00
I everything you said about the way you feel. the only question is - you need to glue the strips vertically - this is because it is more natural ? growth of man ? what type of tree grows from the bottom up.
ie why vertically ? to meet the natural energy - so the flow will be right to go ?
Смелый
Post by Смелый » Fri May 29, 2015 4:42
новый Искатель wrote:i.e. why vertically ? to meet the natural energy - so the flow will be right to go ?
So the flows will naturally flow. Just as nature intended. Thus, in addition with the natural flow of Energy (Downward and Upward streams), the Subconscious mind is constantly seeing before him the vertical bar will be to adjust Your own Power to make it more accurate. That is why it is helpful to wear clothes coated with her strips vertically. Vertical stripes on clothes adjust the Power of the person, cross and all the squares in the pattern on the clothes smear. In any case, the person is constantly wearing clothes printed vertical stripes, much more energetic than many others.
In a word, Ascending and Descending Energy Flows invented by the Creator, and that would be closer to the Creator, it is useful to them precisely to fit.
Been thanked: 2 times
Post by ЗОМБИ » Fri May 29, 2015 11:39
and the floor and ceiling?
Смелый
Post by Смелый » Fri May 29, 2015 12:29
ЗОМБИ wrote:and the floor and ceiling?
Openings for entry and exit of the Upward and Downward flows. Strip them of no relationship.
Depends on the imagination.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 14:59
on the floor I now have pine flooring, and plaster around shungite alfapol 2 cm thickness )
here I about it wrote:
opinion on ALFAPOL PCS-1 (radio-shielding schungite plaster)
http://iskateli.info/showthread.php?t=1 ... #post57969
now here up it want Wallpaper pokleit competent
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Post by мимоходом » Fri May 29, 2015 15:51
The Wallpaper can be? The eye is pleased, the energy is lifted up :?
новый Искатель
Post by новый Искатель » Fri May 29, 2015 16:30
in any case !
yeah, and plastic flowers all make.
and turn on the NTV channel.
No. Only natural, only hardcore. Your eyes delight in the deception - not our way.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 16:32
and maybe even LCD screens panels all force ? channel ZEN
so these LCD panels Purley torsion AMY Phonak for the aura, Yes ?
but it looks good !
мимоходом
Post by мимоходом » Fri May 29, 2015 17:07
Not very clear what advice you are looking for. "Psionic radiation", as you put it is not exist, it is normal electromagnetic radiation that has an energy component and information. Accordingly, materials for the screening of "psi" and "scoring energy premises" does not exist, as there is no the effect of "scoring". This invention is for suckers. And electromagnetic radiation - it's everywhere, it's everywhere. If you saw him fully (you can narrow his range in the form of light) - not trying to shield himself as it is impossible in principle and is the very essence of the fabric of our world. Even if screen light, radio waves, stay in the bunker deep under the earth there will be his EM field, our ball.
"Scoring" energy of space, and management does not exist except through geometrical shape (sharp corners for example for thickening, or Vice versa, rounded to dissipate). Well, or the flame of a candle for example, and the like (works through the ionization of the air, changing its properties as a conducting medium for the radiation), but definitely not the Wallpapers and stuff.
There is the subjective human perception of a circle, I wrote "happy eyes". The green color is most soothing to the psyche (according to your review I noticed that more green will not hurt). And the types of nature - forest, lake, sky, deceiving a brain and he's not languishing in a box 2*4*5 where you spend 50-90% of life. Instead, rejoice in nature.
Also, I honestly don't understand how the view of nature may impair your existence in a concrete box in a huge anthill, whose inhabitants scurry about in constant bustle in cyclic applications such as robots. Also viciously respond to quite a benevolent advice. The distorting mirror of some kind...
новый Искатель
Post by новый Искатель » Fri May 29, 2015 20:30
1. psi radiation, relative term negative radiation, the totality and AMY, and emotions of the city, etc., the same as a conventional "living water"
2. why say PSI and not AMY ? because right otoniel emission spectrum. In order to fight not only with AMY, but with negative emotions of the city including the negative geopathic energy...
Not everything can be measure by instruments. For example, the negative mass of emotion that is often the city produces, and not just the city. The same theme with the ziggurat in red square, strange falls state causeless emotions, etc. not everything can be measured in the EMI range. Psi is the emotional and mental range
3. so about doesn't exist - it exists, it's just that the meter is your emotions, not devices
4. nice Wallpapers, certainly will to deceive and calm the mind - no questions. But I want a stronger effect, and in my opinion stronger is a natural nature you have on the wall - namely natural Wallpaper. + can faostino to do. http://iskateli.info/showthread.php?t=1227
something like that
generally the conversation is not only about AMY but also about other unproven science radiation )))) but which are quite easily felt by people, and creating harmonious spaces which are less felt + harmonious spaces are generating good radiation. something like that
+ for reflection
http://torsiontubes.com.ua/
torsion tube Dolgachev - made of BAMBOO
мимоходом
Post by мимоходом » Fri May 29, 2015 20:36
so what about does not exist - it exists, it's just that the meter is your emotions, not devices
That's for sure. Here you are, my dear, tonite emotionally so much that I don't know what you are going to close. You and mother see should be very comfortable. Not suggesting anything, you still acquire cork Wallpaper and you will assume that protection. Well and on health.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 20:39
You and the mother see should be very comfortable
Pichalka what, and you from deep zamkadya therefore ?
and this is bad ? and can I still poison to drink in order to fonit ? can I handle this where I fonit.
I put specific questions, and you go to the individual. Goodbye.
and will assume that defended.
I don't think, I know. The theme of bamboo is studied for a long time. He's got such a structure. You are on the edge forum.
I actually wrote this resource as a border. And you are here for me to prove what science has not proven.
I think the true target audience asking questions. Not on ixbt realties.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 20:45
also viciously respond to quite a benevolent advice. The distorting mirror of some kind...
adequately respond to the diversion from the topic distorting mirror it is just a Wallpaper and plastic flowers. Non-alcoholic beer, rubber women, and other surogaty natural there.
some sympathetic and Coca-Cola suggest.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 20:53
and the bamboo was chosen not because of my lunacy.
completely different people came to the same is a material having a effect. You can also recall ideas Grebennikov cavernous structures. Ideas torsionic.
+ due to superfast growth, I suspect this growth (energy) is stored in the bamboo - ie is the movement speed.
I have here two examples
1. torsion tube Dolgacheva
2. bamboo linen
on the 1st there are live reviews. for the 2nd one psychic was a serious psi-attacks when he was covered with bamboo linen - attack was reduced. Bamboo fabric is difficult.
In Russia similar properties possessed nettle cloth. Vidil as a hair shirt 200 years that the Russians wore. There's a very interesting energy was. Holographic.
in General, it is not my shiz, are observations of different people. Therefore, the topic is being studied.
through the pipe Dolgachev for example, the dealer wrote me the following:
"the idea that bamboo grows quickly and its fiber creates a torsion effect"
no idea didn't do initially. dolgacev ideas do not use it. he took it and experienced the actual sensitivity of a lot of different materials and combining them with a magnet (that it creates a torsion field). previously successfully auditioned in aspen, the horns of animals not yet caught the bamboo. the magnets don't all fit, but only one manufacturer.
all selected purely empirically
мимоходом
Post by мимоходом » Fri May 29, 2015 20:55
Can you explain what is hidden under the word "holographic"? Is what?
новый Искатель
Post by новый Искатель » Fri May 29, 2015 21:06
can. The linen shirt felt a single layer. On the shirt of nettles felt a LOT of layers.
that's from flax
my feeling in nettle worked the holographic principle. Due to this and this effect.
it is solely emotional-psychic feeling ) I suspect that ancient magic was very aware of this and picked up the cloth in such a way that in them as in a maze view, a negative impact was STUCK.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 21:08
here it can be seen and felt:
on flax no such
+ the nettle there microbology, but it is also torsionic.
мимоходом
Post by мимоходом » Fri May 29, 2015 21:18
Hmm... Well here is your level people there, hardly anyone will be able to help you at such a deep level of psychic sensations. Feel free to choose any option, just the soul orders.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 21:30
thank you for that )
well, I'm not guilty, have long been the subject study )
мимоходом
Post by мимоходом » Fri May 29, 2015 21:33
Yes that there, the gift is a gift... Torsion bars in holography not everyone sees.
новый Искатель
Post by новый Искатель » Fri May 29, 2015 21:41
"want tons of poop ? write about your personal psychic sensations in Internet - crowds of fans )"
I thought I wrote to the address. here you are passing doing here on this resource ?
