ColorTrack glasses where to fix
Джаниец
Post by Джаниец » Wed Mar 11, 2015 13:10
Good afternoon. ColorTrack glasses ,stopped working the led.Where can be repaired? Ekaterinburg.Thank you for any help.
Been thanked: 182 times
Re: ColorTrack glasses where to fix
Post by Андрей Кабанков » Wed Mar 11, 2015 15:44
Can be repaired in Moscow with us.
Try pressing button increase the brightness of points a few seconds is often that brightness removed to zero, and it is perceived as a failure, although you just need to increase the brightness of the zero position.
Джаниец
Post by Джаниец » Thu Mar 12, 2015 11:54
Tried that, even changed the connection cable,the result is zero.The feeling that the diodes came to an end because they then would blink then stop blinking and slowly faded.
Post by Андрей Кабанков » Thu Mar 12, 2015 13:55
Definitely not the case for diodes, as their resource is not comparable with the life of the glasses.
Джаниец
Post by Джаниец » Thu Mar 12, 2015 14:31
And in Your opinion , what could be the reason and what should I do? Points are not dropped not wet at all were treated very carefully.
Post by Андрей Кабанков » Thu Mar 12, 2015 14:46
I think the most simple and effective is to send them to us for diagnostics and repair. You can also turn to your local professional electronics.
A specialist to repair them is easy, we have engaged in this our engineer and Navigator. Send for repair to the manufacturer is expensive, subject to postage at the new rate.
Джаниец
Post by Джаниец » Thu Mar 12, 2015 15:19
Understand ,and where to send address details?
Post by Андрей Кабанков » Thu Mar 12, 2015 16:14
129329, Moscow, Kolskaya street building 1 building 3 , LLC "Computer"
tel 499-180-99-52
