If this film completely come off, will it affect like that to "work" the Room?
What an amazing coincidence! I also carry in the bag. Both of my front Room in perfect condition, only peel films. I just wanted to know what the nature of this films, only protective or functional.ЛИЛИЯ-Р wrote:All I wear in tight plastic bags
Judging by Your posts, You consider yourself a specialist in manufacturing technology of plastic cards. But there are observations: 1. Your Bank card must have been other conditions of wear compared to SB. 2. In Your card there are no additional layers like SB, so I made it for a different technology. Not every technology of manufacturing cards suitable for SB. We tried a few and a number of materials while staying on this. 3. In any technological process can be deviations from the norm. 4. For the future I advise you to avoid prolonged contact with the skin SAT. On the one hand the skin is too aggressive environment for cards, another for skin is also not good to have prolonged contact with plastic
SB is moisture proof and is not afraid of water. When we developed the technology of making the Parlor of the first generation in systems card, to check the moisture resistance and laid them in the washing machine and washed for several hours. Everything was fine and card was not stratified. To our surprise after the release of their on sale rained complaints from users because of the constant contact with human skin within a few weeks began to peel off the laminate. SB made a few other technology and are more resistant to moisture. But prolonged direct contact with human skin (for several weeks) it is also contraindicated (even if only for hygienic reasons). Now we are preparing a new edition of the instructions for the SAT with limits prolonged contact with human skin.
To carry multiple products in a single case is possible. Better if the case does not allow them to move freely relative to each other. Though minor scratches do not affect performance, only worsens the appearance with time.
<Not recommended for direct contact of the cards with the human skin.
When worn on one rope or in one pocket of the product it is desirable to Orient parallel with respect to each other as follows |:|: Here, a solid line - front, a colon - reverse. Front side - the side with the product name. This "sandwich" to better Orient to person on the reverse.
LIVE+ wrote:Sergei Dinovich That the Svetlitsa-Super is that the Svetlitsa-Good, from all four corners there is the following problem(see photo)
The peelability of the laminate does not affect the operation of the Parlor. Performance characteristics of products not worsen.LIVE+ wrote:If this film is to completely come off, will it affect like that to "work" the Room?
If the card is not stratified, nothing terrible happened. A slight bend maps not hurt.ММ wrote:Accidentally washed Svetlitsa Super at a temperature of 95 degrees.Laundry service was 3 hours. The card is bent. What to do? To throw away? Continue to wear? Wouldn't the card to emit harmful energy?
OptimisticЛИЛИЯ-Р wrote:Svetlitsa will stop working only when you will burn it or it will dissolve in acid, for example .
Such feelings can depend on the material of the cover. If you take a thin cotton cloth, the feeling will be different.LIVE+ wrote:the Theme at the expense of cover for the Parlor was still open. The thing is, Svetlitsa without case better . . . take it in hand, and something happens, I don't know what, but something is . . . put the case, the feelings are the same but an order of magnitude weaker. This question worries me since the purchase of a Chamber-Super, two years have passed and the issue remained.
ASD , Please comment on my post!
So in fact the structure bends with the surface. Or I something not so understood?ЛИЛИЯ-Р wrote:globe Not affect , does not work a protective surface and structure that is under it.
If she's just going to collapse or are bent -NOT SCARY.If you it all break, then YES. The box salaminian, it also pull should be good that it broke. You have a product that you are so worried for the health of it? People are curious even managed Svetlitsa Super to disassemble more of the plastic mug, and even from the card to see what's inside and nothing back laminated and worked. Don't invent problems for yourself.глобус wrote: damaged the "box", if you bend or dent the work surface?
Now it is clearЛИЛИЯ-Р wrote:If she's just going to collapse or are bent -NOT SCARY.If you it all break, then YES. The box salaminian, it also pull should be good that it broke.глобус wrote: damaged the "box", if you bend or dent the work surface?
