The context-2
The context-2
Post by Михаил_ » Thu Sep 25, 2014 13:01
Комплект карт «Контекст-2»
Another social product "Context-2" can be called a stabilizer or Vice versa analog stabilizer to work not with the world but with society.
It is clear that society exists within the framework of their domestic laws. Most of my products are designed to work not with society but with the world. The number of social extension is associated with the use of the individual qualities/aspects of society. Only Facilities directly associated with control/camera function when dealing with society.
It should be noted that the society has a high inertia. And contains the concept of "norm" for a particular part. Any of your target actions in the world and in society can machine to stumble on the social reflex reaction of rejection if You do significantly and if it is "outside the norms".
New product "Context-2" is designed for carrier-attunement processes and society.
The product consists of a set of cards, each of which has its associative binding, and can be partially reprogrammed by the operator.
Using "Context-2" to resolve such issues as the response of society to the anomaly taking place and conversely, to create the anomalies in the society that allow the different processes to be something "normal" in the context of these anomalies.
The product includes the following cards
Operator — communication with the operator, the default (may be reassigned to another man mentally)
System — society itself, without localization of the impact zone (without clear boundaries)
Activation activation in the zone of interaction with flowing borders. Activates/processes/events/changes. Need you ask mentally.
Anomaly — Defines mental abnormality in the society for a smoother reception of the operator's exposure within this anomaly.
Norm — Sets the function "norm" in place of society. This function is a replacement or addition to the effect of "anomaly" - allows you to change the perception of those who in society (perceive something as normal)
the Object — For complex interactions it may be necessary to assign the object with which there is social interaction, thus dragged him into the zone of interaction, or to set him properties.
Area — sets more stringent limits for the zone operator's work (not necessarily territorial but on any principle).
Properties specifies properties of the object/area/operator/anomalies/properties of activation and so on.
When the cards are going in the right stack. Unused can be put aside or deactivated by mental command.
You can add a specific property to build more complex circuits.
The entire set of cards has a cost of 15t.
Additional card (any) is 2T if available. Initially the office will only complete sets, sell individual cards will be possible after satisfaction of initial demand for the kits and on the provisional application.<
Re: The Context-2
Post by Михаил_ » Thu Sep 25, 2014 13:02
The context-2 will be available on 6 October, to begin in limited quantities.
Алексей Федотов
Re: The Context-2
Post by Алексей Федотов » Wed Oct 08, 2014 21:19
Michael,a will-whether the free version for a test drive? )
Re: The Context-2
Post by Михаил_ » Wed Oct 08, 2014 21:33
Nah, it's not necessary conceptually, because it is the product:
a) for those who understand why is it and why should it spend money
b) fairly experienced in working with the society as a whole and does not have problems to organize themselves inkam financial in the right amount.
thus free version there will be a dangerous addition because the issue is not subject... people who have financial problems in such a small volume should not start with a society with a context, and those who do not understand/are not sure/ and so on - is also not necessary. It is advisable to take the context of those who confidently and with visible results, he uses other products and well aware of their carrier opportunities.
Андрей ВН
Has thanked: 9 times
Re: The Context-2
Post by Андрей ВН » Thu Oct 09, 2014 11:09
Michael in the lecture says that the operator (process) can be set as an anomaly, respectively, is removed or greatly reduced resistance
society.
But also the operator (process) can be set as the norm, and the effects are assumed to be the same? And if you can layout a simple example to explain the algorithm of the product.
Re: The Context-2
Post by Михаил_ » Thu Oct 09, 2014 14:38
depends on how you want to adapt yourself - the result will be different.
You take your real life example where it is necessary to apply on it and see.
Re: The Context-2
Post by Михаил_ » Thu Oct 09, 2014 14:39
for technical reasons, the Context probably will arrive by Friday evening or Monday - a little bit of time with the manufacturer.
Андрей ВН
Re: The Context-2
Post by Андрей ВН » Thu Oct 09, 2014 19:03
For example myself as a person seeking self-development, creativity and recovery capabilities - set as an anomaly, which it is anticipated will contribute to society.
Its activities present or future contributing to human circumstances and resources - set as the norm. You can do the opposite, what are the differences in the reactions of society.
And is it possible to specify both properties, anomalies and norms in one card "properties".
Евгений-М
Re: The Context-2
Post by Евгений-М » Tue Nov 04, 2014 18:44
Michaelwhether it is possible to use the Context to promotion of a new product (technology) on the market?
There is a new device with a completely unfamiliar society functions, and we "call" normal, usual and ask the world to help us with this (that people quickly got used to it)?
Re: The Context-2
Post by Михаил_ » Wed Nov 05, 2014 1:21
1) can I do that
2) the difference in the examples described, I propose to define experimentally, because it depends on the operator
3) a map of the properties is only be used once on one target and not multiple times ( or have several )
Юлиана
Has thanked: 61 times
Been thanked: 2 times
Re: The Context-2
Post by Юлиана » Tue Nov 11, 2014 2:58
Hello))
Michael, You said in the lecture that it has added "Context-2" additional features (properties), I'd like to know what :) :o
Re: The Context-2
Post by Михаил_ » Tue Nov 11, 2014 18:36
There will be 3 extra cards context that are not included in the basic package. The sale will be days, and with them and their description...
Been thanked: 182 times
Re: The Context-2
Post by Андрей Кабанков » Fri Nov 14, 2014 11:46
The context-2
Post by Андрей Кабанков » Sun Jan 18, 2015 14:01
Additional maps Context-2.
Дополнительные карты «Контекст-2»
Has thanked: 5 times
Been thanked: 16 times
Re: The Context-2
Post by Вячеслав. » Sun Jan 18, 2015 19:31
Terrible thing...
Petr99
Has thanked: 3 times
Been thanked: 15 times
Re: The Context-2
Post by Petr99 » Sun Jan 18, 2015 20:06
And I think there is nothing terrible, but a very handy thing, if anyone knows how to do it without interfering personally, and so not to keep constantly in mind.
Re: The Context-2
Post by Михаил_ » Sun Jan 18, 2015 21:50
Additional map function:
Deactivation is intended for braking, reducing the activity of communication/egregor/process/object/operator/zone indicated by the basemaps. (Operator not necessarily the one with the maps running, the operator can be one of the operators on the field areas of the alignment).
Conflict - causes energy (egregorial) conflict structures the basic kit. Can be used for example vacuum map for a clearer baseline of the existing conflict of interests of those or other objects on the field(area) of the deck. The classic example is a pair of structures with competing products (businesses). In General, they are in a conflict of interest if You represent the flow of energy associated with this process occur in the area of your work (including can be partially allocated to external needs - there are a lot of as in hydroelectric).
A vacuum removes the excess energy in the direction of the specified object (for example, operator area, etc.) from the energy-active process between objects.
Collaboration is another aspect of the installation is the interaction between the described objects. It seems clear without further description.
All additional cards have a value of 5T. p. and are sold individually.
Is still available from December (no time to describe it but :) )
Андрей ВН
Re: The Context-2
Post by Андрей ВН » Tue Jan 20, 2015 22:38
If you make copies of the cards the Context of whether it will turn out the Lite version by analogy with the alpha-wit
Re: The Context-2
Post by Михаил_ » Wed Jan 21, 2015 0:02
If you make copies with alpha Vita will not turn out the Lite version, but will moooooolto problems on his head. Similarly with context.
Not to be confused with the published Lite version and scan with the commercial - it's not the same! though and pictures can be the same. There's not a picture of the active principle.
Re: The Context-2
Post by Михаил_ » Wed Jan 21, 2015 0:04
And Yes-I'll do the light version of the context is the filter :)
АМарта
Has thanked: 2 times
Re: The Context-2
Post by АМарта » Wed Jan 21, 2015 0:19
Michael,and a map of the properties after a single use you can throw away?It is disposable?
Re: The Context-2
Post by Михаил_ » Wed Jan 21, 2015 0:38
disposables I don't remember :) well, only labels 1-copy :) MovieClip many times.
recommend keeping a journal or even on a magnetic Board the whole layout pinned and communication/quality set to sign, not to forget what and where...
АМарта
Re: The Context-2
Post by АМарта » Wed Jan 21, 2015 0:42
Михаил_ wrote: 3) a map of the properties is only be used once on one target and not multiple times ( or have several )
And how it to understand then?
Re: The Context-2
Post by Михаил_ » Wed Jan 21, 2015 0:55
Literally and understand - a map of properties to use for the same goal! not many times :) at a time clinging to one purpose, another for another time. If you want to set multiple properties SIMULTANEOUSLY, you need multiple cards, which made the opportunity to buy their piece (if available of course).
АМарта
Re: The Context-2
Post by АМарта » Wed Jan 21, 2015 1:02
Thank you,Michael,now I understand.)) Another question pzhsta.In terms of bounce from Контекста2?
