ВИТАЛИЙ ГИНЗБУРГ wrote:Good day! Is it possible to observe the performance of this product or any of its parts using the "Points to observe the aura"? and in General for other BRM ?
With glasses PranaVision I guess you could see we didn't try. The goal?
Glasses many aspects of the subtle world it is clear that something may be seen. The observed more difficult to interpret.
ВИТАЛИЙ ГИНЗБУРГ wrote:If I understand correctly, is an attempt to combine the operation of the micro-generator orgone, modulated audio oscillations with the work of the pyramidal structure and a complex effect promoborudovanie radiation on the crystal emerald with design intent?
What are the results of observation of the apparatus and first tests, if any?
What is the potential difference from the schematic with BRM+RAD 2400 + pyramid ?
Thank you in advance)
Not quite. To a greater extent - by electromagnetic oscillations. With this purpose, the selected playback device, which is based on coil and magnet, although xperiment were conducted with piezoelectric elements.
The results of the first test will come a bit later.
