Attention! The deck is a super-powerful tool. Use according the user can create a dangerous situation and is absolutely contraindicated!
Chopped consists of 9 color card size "credit card". The cards are numbered from zero to 8. 10th card (conditional 9) may be a piece of paper of a suitable size with a description or the name of your target or trend (not the goal, but the direction) or just phrase reference to him.
The deck is made by complex triple technology. This is actually a special picture, a special method of its manufacture (the manufacturing process used is not a simple "laminator"
The first rule which you should remember very, very well. A deck and work with your processes, you can deactivate adding all the cards in order. 0-1-2-3-4-5-6-7-8 (map with the target removed).
A deck is temporarily untied from the processes and of the latter aim, however, called her earlier "disturbances"in reality continue to operate (relatively speaking - kick Dan).
The second rule. When You have a feeling that You cannot cope with developments and are unable to harmonize them, consider using rule1 and deactivate the deck.
The formation of the target or trend.
It is important that You imagine and not what is written in words.
Words can be written (on paper for example) "Purple watermelon hanging on the moon for more than a day" (almost Simoron - a unique phrase), but really will matter is your personal understanding of the target or trend, which is written under this key phrase.
Do not have to write the phrase "карту9", may 9-ku did not use.
There are two ways to operate the deck. One intuitive. It is sometimes more efficient. The second software.<
