Kasina. Mind machine
Дмитрий Никитин
Has thanked: 10 times
Been thanked: 10 times
Post by Дмитрий Никитин » Thu Feb 06, 2014 18:04
Hello ! Someone used a new device Kasina ? http://www.mindmachine.ru/kasina/index.htm Share your experiences pzhl. :)
Re: Kasina. Mind machine
Post by Андрей Патрушев » Thu Feb 06, 2014 19:07
Dmitry Nikitin
Hello.
- The casing of the old iPod classic (under hard drive), a beautiful white, front surface glossy.
- Very easy to use - choose a session, or audio and pressed a button, then the machine determines what to do with it.
- Headphones included loose, the quality is good (bottoms, top, middle, detailing).
- Built-in audio player and USB flash drive 8Gb (not enough - my 4 disk in WAV format, took half of the free space, but maybe more pull - you must try it). Figured out - works fine with flash drives up to 32GB, inclusive.
audiostrobe good (with automatic setup) - all discs played without problems.
- a lot of mp3 music files that there are called Spectralab session. When bored, you can download a bunch more on the website (free).
- there are the usual session (22) - adapted from their old mashinki Sirius. Description of the sessions, apparently, did the professional marketer - read and think - "THAT's THE very thing!" include - as usual... :?
USB I not working (only charging) may need firewood for piggy (not yet understood), but you can from using the card reader (judging by the manual, which was faster still). Figured out - just doesn't work. :(
Glasses (eyes should be closed) not impressed, though, by their description, it must be something unimaginable... the Matrix (set to the center) of the 6 small svetodiodov for the scattering screen. Plus the fact that the light as it is everywhere (as in Pathfinder) and can, in some approximation, to synthesize any color and each led can be programmed to its frequency. Minus IMHOin futility (and therefore wasted money cheat) because of the perceived with closed eyes, the color depends solely on the frequency of flashes and their duty cycle. The presence of several frequencies at the center, except for porridge in the head, IMHOdoes not mean anything. In General, experience points, even compared to Innerpulse, I would say not outstanding. Among other things, the size of some children - my "booth" was fit with an interference fit, so that fell out plastmasa with diodes. :) I Made a couple of the usual relaxation (Spectrascan). During the session the condition is quite unusual - all the floats, as the carousel will perekineshsya, :roll: but after half the night I couldn't sleep... :shock:
The first impression is a good gift for women. :) After a couple weeks of use, I think that perhaps the women (loved :)) it is better not to give... Functionality for the usual utilitarian tasks (relax, relax, cheer up) works somehow ambiguous... :roll: But the fans get high, to catch the "Semenenko", or just a break from the world, perhaps, at the time.
What else???
Ask. :)<
Дмитрий Никитин
Post by Дмитрий Никитин » Thu Feb 06, 2014 19:42
Андрей Патрушев wrote:Overall impression - a good gift for women. :)
What else???
Ask. :)
Thank you very much for the detailed answer!!! If You have decided to give MM a woman, what would You choose of the two options Casino or MindSpa?
And last question, how would You rate (as a professional) Range Gate session Casini and where to download them?
Post by Андрей Патрушев » Thu Feb 06, 2014 19:56
Dmitry Nikitin
Well, of course, Casino - one body only which is... :) Yes, and extremely easy, all (or clearly :)), even compared to MindSpa. No, better still MindSpa...
The only small drawback (in comparison) - if you select the session duration is not specified (it is necessary with a piece of paper to check) and session from Sirius only by their numbers (again, a piece of paper with a need to carry).
Session session... In the Navigator, too we first planned this solution (three separate frequencies for audiostrobe), but then found it more simple... In principle, at a Central location of LEDs, all of this is unnecessary... Color scheme for Audiostrobe can be set only before the session in the settings.
Actually, I was under the impression that Casino done after a detailed acquaintance with the Navigator, but is not likely doper... :?
SPECTROLAB session is already loaded in Casino, and the download link is in the manual.
Post by Андрей Патрушев » Wed Feb 19, 2014 18:34
Suddenly discovered that my USB still works. :lol: It turns out to activeroles icon you want 100% charging of battery. Even weak discharge (the indicator 100%) already does not activate the icon with the USB. And here I machinko before him put it on the charger, so it charged, then lay for a moment, and then activated the USB. I wonder what will happen when the battery will sit down a little?...
Post by Андрей Патрушев » Sat Dec 13, 2014 13:28
Анька
Has thanked: 45 times
Been thanked: 12 times
Post by Анька » Tue Sep 15, 2015 21:56
Andrei Patrushev Hello! I bought mindmachine casino and I love headphones, cat.came in the kit, do You know what kind of headphones? or any similar har-am? but I can not find the same good, these are the coolest playing))
Post by Андрей Патрушев » Tue Sep 15, 2015 21:58
Anka
No, I do not know. :?
Анька
Post by Анька » Tue Sep 15, 2015 22:04
Andrei Patrushevsorry :) okay))
Стешка
Has thanked: 2 times
Post by Стешка » Wed Dec 02, 2015 21:25
Good day! Prompt, please, where you can find the manual in Russian for Casini? Lost manual now can't figure out which session to use for learning! :cry:
Post by Андрей Патрушев » Wed Dec 02, 2015 23:49
Steska
Hello.
How to lose if it's right in mindmachine?
Actually, native site they have Russian.
Стешка
Post by Стешка » Thu Dec 03, 2015 0:59
Oh, really! Holy cow... I hope it's another session to improve brain activity! :)
Thank You very much!
Only there is no translation guide for the sessions.
Post by Андрей Патрушев » Thu Dec 03, 2015 9:45
Стешка
Post by Стешка » Thu Dec 03, 2015 14:05
Thank you very much!
Максим Данилушкин
Has thanked: 18 times
Been thanked: 2 times
Post by Максим Данилушкин » Wed Dec 13, 2017 8:09
Андрей Патрушев wrote:razmerchik some children - my "booth" fit with interference
A similar story I had with glasses mindmachine Procyon the same Corporation MindPlace, in my pie hole stretched with difficulty, but to their credit the crack in the middle of the rim was formed only after 11 years of use.
Лева
Has thanked: 9 times
Post by Лева » Tue Jul 03, 2018 11:55
Privatewww))
Does it make sense to compare Casino with the new Navigator?
Machine interested for training and self-programming. Is it possible in the editor sessions Casini add your affirmatsii and to overlay the music as in Pathfinder? How there really all the key points worked out? In casino attracts compactness. In Pathfinder, a lot of that is what I don't understand , but I do know that alarm, timer, exit on the second goggles/headphones, recorder (I can with a computer all to pour) I most likely will never need . 50 or 169 sessions for me too, big difference there. Interested in themselves quality sessions and submission of these sessions by device as they are in fact different ?
Help with a choice poggiatesta!!!
Post by Андрей Патрушев » Tue Jul 03, 2018 13:23
Loew
It is always possible to "Dodge" - for example, to record to mp3 with your navorotami and run any session support.
From personal experience with this car, good causes altered States of consciousness (consciousness floats), but the main (for me) functionality - to relax, or, conversely, cheer up, tune into perception of information, it seems, did not work out.
May have to get used to - I only played a week and gave up. But Sonny I have this machine pressed, and still is.
Дмитрий П
Post by Дмитрий П » Sat Nov 03, 2018 13:32
Good afternoon.
really need help to understand mindmachine.
own Casinos from mid-2014. bought was almost impulsive, as to make an informed choice did not allow lack of knowledge in this area.
bought after in a sanatorium first tried mindmachine to relax. I have VSD, panic attacks, hence the problems with blood pressure, bowel and other rubbish.
have since used it a dozen times, as after purchase very disappointed.
if "sanatorskaya" car I've seen literally did a trip among the clear geometric shapes and the result was stunning - the stress went away completely, in casino colored iridescent light field at me practically does not have any impact.
more or less it works if I use the program "relax". but to completely "turn off and drop out" does not work.
I have two pairs of glasses from Casini is common, for use with closed eyes and a newer model for use with open eyes.
big difference in the results I see.
in the end, I'm looking for the chance to relax and relieve stress with the help of this machine.
all other features are secondary for me. now there is a deterioration of health and the issue is particularly acute.
however, if someone would recommend a device which can do ready to buy a new device.
my wishes - built-in programs (to be able to use at least basic functions without external players). well, it is desirable built-in player, not to bother with a CD / DVD.
in the principles of machines deal very superficially. but, I think, a greater effect on me are those that "generate geometry".
p.s.
ironically, I'm the author of the Russian-speaking interface Casini :-)
(after purchase, tried to find out from support - "what am I doing wrong". the point of this for me was not enough - the subject is complex, and here and in English... as a result, in the course of conversation asked them to do Russian translation of the interface.)
Post by Андрей Патрушев » Sat Nov 03, 2018 13:54
Dmitry P
More likely and faster You will help transcranial electrical stimulationor Hephaestus.
Дмитрий П
Post by Дмитрий П » Sat Nov 03, 2018 14:46
Андрей Патрушев wrote:Dmitry P
thank you very much for your prompt response. I mean these devices are well know nothing at all. can't judge the effectiveness and try, too, never can (I live not in Moscow and a little mobile)
still more interested in mm can give him advice?
Post by Андрей Патрушев » Sat Nov 03, 2018 16:55
Dmitry P
When the tightness in the money - Lumina, if wealth allows Navigator.
Дмитрий П
Post by Дмитрий П » Sat Nov 03, 2018 18:11
thank you. now let's study the difference between them.
