InnerPulse. Connecting an external audio source
Владимир Слободянюк
The car I bought. Four years. Used a little. Decided to resume experiments.
Reading the manual - don't understand where is connected the CD player or other audio source?
And another connection to a computer to download the programs is only possible via COM-port or something advanced
Re: InnerPulse. Connecting an external audio source
Vladimir Slobodyanyuk
Via "Aux".
Only through "COM"
Via "Aux".
Only through "COM"
Владимир Слободянюк
Андрей Патрушев wrote:Vladimir Slobodyanyuk
Via "Aux".
And where is he?
Only through "COM"
From the top, between sound and light.
Владимир Слободянюк
The manual says "exit" - and I'm lost...Андрей Патрушев wrote:Vladimir Slobodyanyuk
To connect to the computer and to the USB via an adapter USB-COM (500 rubles on average), only in the settings of the com ports is necessary to assign to the adapter, the first number (I have the second did not want to work).
Александр А
- Has thanked: 1 time
- Been thanked: 2 times
You pick the topic.
Recently came InnerPulse glasses standard, green. The problem with the glasses in the mode AuS.
Sequence of actions:
1. Headphones into the right slot
2. the player in the secondary.
3. points to the left.
4. choose Aus, press Play. blink two LEDs: the upper third.
Glasses do not work.
In this case with standard points programs work fine: brightness adjustable, burning the same, no problems, who debated on this forum.
Included sessions of the Novel and the healing down the river.
Tried all sound sources: all smartphones and a few computers.
Bought player Sony Walkman NW-E393, the stated range of 20-20000hz, and the firm not the last one.
Brightness points twisted.
The volume of the player spinning.
Cords places changed.
The equalizer and modification of sound player disconnected.
Updated the firmware to a newer player.
The machine was overloaded (using 4 buttons), first writes ee1, ee3 then, then eep and so it remains.
To have to do this to work?
PS After reboot, by the way, not only writes her up, but flashes alternately and the glasses synchronous with the sound in the headphones.
Alexander And
Try this one: https://cloud.mail.ru/public/7346/wRw5QGXCf
There is a reference audiostrobe. If you do not go, it is only, IMHO, to change.
Александр А
Yeah, unfortunately, not gone. I propose to move to PM, as you usually trade?Андрей Патрушев wrote: There is a reference audiostrobe. If you do not go, it is only, IMHO, to change.
Александр А
The machine was changed. Now everything is working.
