HEPHAESTUS
HEPHAESTUS
Post by Андрей Патрушев » Wed Dec 25, 2013 19:41
As a user with more than 10 year of experience I can say that Gefest a very useful device for the home environment. It is more painless than a full replacement of mustard (cough, runny nose heals quickly and efficiently), this treatment all sorts of problems with pain in the joints and lower back (also very effectively, but with a slight delay in removal of pain in 20-60 minutes from the session), and fatigue, and magnetophones (increased absorption of drugs through skin under the influence of a magnetic field) and finally, and Express rehabilitation and healing after fractures, sprains and wounds.
I should add that Hephaestus is not only a home appliance, it has been successfully used in clinics around the world.
Israel has developed and successfully applied methodology for the treatment of alopecia (hair loss) is a combination of burdock oil and magnetophoresis.
In Yekaterinburg developed and successfully applied the method of treatment periodontal disease is a combination of a special antibacterial gel and magnetophoresis.
In Yekaterinburg for many years until recently (closed as a result of "reorganization" :( ) successfully worked with the Cabinet for the treatment of obliterating endarteritis.
The efficiency of Hephaestus, compared to other devices electro-magnetic therapy, is determined by the particular pulse shape and constant (for a special program, through the feedback sensor) changing parameters of the pulsed electromagnetic field slozhnosochlenennogo that makes the body get used to this kind of impact.
Usually the body quickly (over 1-2 sessions) to get used to the impact of any electromagnetic fields (even if they change by a simple algorithm) and simply ceases to respond to them. This explains the almost magical effects of the first sessions of most devices, which is used for treatment with magnetic or electromagnetic field, and the rapid decline in the performance in subsequent sessions.
Contraindications:
severe hypotension, systemic blood diseases, anticoagulation, tuberculosis, acute suppurative process of any localization, toxicity and high temperature reaction, Basedow's disease, diencephalic syndrome of early post-infarction period, severe coronary heart disease, the presence of magnetic fields magnetic foreign bodies, uncompensated glaucoma.
CLINICAL APPLICATION: treatment of diseases of the vascular system (lymphedema, lymphatic-venous insufficiency, obliterative endarteritis and obliterating atherosclerosis), diseases of musculoskeletal apparatus (arthritis, of artrose-arthritis, osteochondrosis, post-traumatic States), childhood infections (rhinitis, laryngotracheitis, bronchitis), diseases of the peripheral nervous system (neuritis, radiculitis, of lumboischalgia), diseases of the skin (keratoderma, lichen of various etiologies, neurodermatosis, pruritus, urticaria, acne), diseases of the teeth and oral cavity, gynecological diseases.
The use of psychophysiology for the treatment of stress, recovery after a big physical and mental stress, preventing fatigue in the complex rehabilitation of drug addicts and alcohol dependent people.<
КАА1970
Re: HEPHAESTUS
Post by КАА1970 » Sun Dec 29, 2013 4:43
The instructions for the diseases included in the kit?
Re: HEPHAESTUS
Post by Андрей Патрушев » Sun Dec 29, 2013 12:30
КАА1970
Yes, of course. In addition you can always consult with a developed by Professor bankowym by Valery.
Also look here: http://www.bodymachine.ru/gefest/
Троица
Re: HEPHAESTUS
Post by Троица » Fri Feb 14, 2014 13:21
Andrew, prompt, please, suitable apparatus for cosmetic application?
Re: HEPHAESTUS
Post by Андрей Патрушев » Fri Feb 14, 2014 14:16
Trinity
Yes, of course. - See for yourself http://www.bodymachine.ru/gefest/ :)
Троица
Re: HEPHAESTUS
Post by Троица » Fri Feb 14, 2014 14:43
Thank you :)
Has thanked: 478 times
Been thanked: 264 times
Re: HEPHAESTUS
Post by ЛИЛИЯ-Р » Mon Feb 24, 2014 16:20
Троица wrote:Andrew, prompt, please, suitable apparatus for cosmetic application?
To kosmeticheskogo massage has not yet reached, but for a long time (about six months)was struggling with back pain. Diagnosis is not done so often (once a year or couple of years) sometimes you know the problem. Many have tried,pills , shots , even some friends on the forum helped in different ways get rid of the pain and to remove the very problem. Temporarily helped , then come back. After the Christmas holidays took Hephaestus to sample. Maybe I'll feel better. The first 3 days at 24 minutes, and the result was not given at once, and I gave up, but it became easier later. Consulted with Andrei Patrushev, can that not doing so once doesn't help? Decided to resume the procedure. Certainly not immediately , but after a couple of hours after the procedure relieves the pain.you can sleep more or less normally, too it is possible to sit without much pain. After five days of daily application of Hephaestus in the evenings , on 24 minutes , I can say that it has become much easier. Until complete recovery is not reached yet, and so they want all this hassle to get rid of. Continue to study))))).
P,With Tried son Hephaestus to relieve pain in the lower back and shoulders , said easy , some clips are gone. It is true what the clips did not understand,but he asks for the procedure.
