ASD faction 2
Re: ASD-fraction 2
A lot of useful and good razgovornoi information is in the subject small off-topic On the forum Michael.The bracelets of Life,for those reasons, I can't give the link.I hope I don't give in the head).Аз есмь wrote:Search gave nothing, so I had to start a new thread.
What is the duration of the break between doses? Ie Drank 4 times in 5 days with breaks for 2-3 days and then how many weeks a break?
Re: ASD-fraction 2
And try to find the bracelets of life or the mind-machine! They probably also will not find - only a couple of times more common.
However, I laugh, thank you)))
Re: ASD-fraction 2
You use the search engine of the forum (which is below, less the blue magnifying glass), and not by the application to it from Google (the one above, and magnifier of his orange). He, somehow, better looking, and more convenient. I don't know why the forum 2 search, one of which sometimes does not want to work
Re: ASD-fraction 2
When I started taking ASD, immediately thought of the practice of a sect of Bon-po, which read in the book "Mystics and magicians of Tibet", Alexandra David-Neel . If not messed up, there is dead put in a stone sarcophagus, where the body decomposes. Remove bones and putrid fluid to leave. Then the tub goes into the person lies for some time. Thus, such is achieved, if not immortality, then a very long life. The smell of the first few days are really associated with "concentrated death," as one validating at OM. But, surprise, thirsty.
Phew! Just took a bath with ASD. No the cold is not felt, but on the contrary, it was very hot. So far (already 10 minutes passed) still hot.
Well, it smelled a bit of ammonia and a dead jerboa
but it's doable.
And yet can someone tell me - what dilution of ASD in the nose to drip, so as not to burn the mucous?
Нетрезвый Сурдопереводчик
- Been thanked: 1 time
Re: ASD-fraction 2
Banned for always helphttp://www.google.com. Of regimens there are many,from official,to bespoke. exactly the same range of doses. I have no smell feel. All home disgusted,and I probably soaked through. ASD you can just drink diluted in a large quantity of water. Not snack
ASD should be given the opportunity to be in the digestive tract alone
Re: ASD-fraction 2
I'm not talking about regimens asked, because for almost 2 months drink ASD, and about breeding for instillation into the nose, so as not to burn the remnants of the mucosa in the nose.
Dug into the topic "Small offtopic" and came across ASD and others. Although search persistently shows nothing. Maybe I'm being obtuse or glitches...
Re: ASD-fraction 2
but why dig in his nose or take an enema? ASD,subject to the recommendations to accept,effectively acts on the entire body. With a weak kidney or liver precirrhosis it is better not to drink. asdvopros.wordpress.comАз есмь wrote:I'm not talking about regimens asked, because for almost 2 months drink ASD, and about breeding for instillation into the nose, so as not to burn the remnants of the mucosa in the nose.
Re: ASD-fraction 2
Well, of course - naphazoline he is... It is addictive, nasal mucosa is not operating properly and will atrophy over time. Half of my friends doctors it is firmly seated - sometimes a tube or two a day in the nose fill (buckets take it to the pharmacy once a month) or just can't breathe... He does not cure the nose - it just narrows the blood vessels in the sinuses and this complicates the output of dead white blood cells and other fighters from the infection through the nose, but they are still there (again, extra load on the kidneys).
I do grandmother forbade nose drops to treat only antiseptics (onion, honey, lemon juice, pressed Kalanchoe) - they treat the nose more through a barrier to new infections when she runs out of blood, snot nowhere to be taken.
Re: ASD-fraction 2
usually chronic rhinitis overload of the kidneys very much. It is necessary to remove from food products,grooving kidneys. beer,milk gallons. to study emotions,"grooving" of the kidney. The benefit here than thereАз есмь wrote:Chronic rhinitis zadolbali. you have to constantly drip naphthyzinum. In the summer, if the heat (hot) easier
Re: ASD-fraction 2
Sumamed , strong antibiotic, so by not knowing I almost ruined the gastrointestinal tract daughter, who was only 5 months, wrote it in the TCG. d. clinic. Then very problematic to restore the flora. And it was just cold and temperatures-reaction to prorezalsya teeth...Causes of common cold are different. Amicii too whiny snot(sorry) coming out and as a consequence are deposited in the kidneys ( fears and depressed tearful) . So what about kidney ...somewhere probably correctly - to remove extra liters ...but what if the manure is used in high quantities , then again ...blood sugar, early onset diabetes, then and the dryness can be and other reasons. Well ...snot is better than all the rest of" evil" , it's the least if much is lacking. Gasolin and naftisin is not a solution..strong addictive to it.Нетрезвый Сурдопереводчик wrote:usually chronic rhinitis overload of the kidneys very much. It is necessary to remove from food products,grooving kidneys. beer,milk gallons. to study emotions,"grooving" of the kidney. The benefit here than thereАз есмь wrote:Chronic rhinitis zadolbali. you have to constantly drip naphthyzinum. In the summer, if the heat (hot) easierAnd then,that you may be rhinitis and sinusitis-sinusitis. Then the nose drops to only aggravate their situation. Need special medicines. Helps a bunch of cinnabsin-"4дневный" Sumamed....
Re: ASD-fraction 2
The doctors are now "eager to cut". to prescribe Sumamed 5-month-old girl. I have this doctor would have killed with his bare hands. If you are dry mouth,it jumps insulin. in principle many things can be changed in the method of supply. nobody's really campaigning for a raw food diet,but you can adjust your insulin by simple methods supply with products that you can find in any store. causes of runny nose really different. Is rhinitis,a disease more dangerous than it usually think. The cold causes the dominant emotion(lack of recognition by others in society,pride,conceit, etc.) that emerge from the dominant passions,which subtly exists in the mind of each person. We should not think that this very Passion can be removed,or just having cried after listening to MM about two weeks. It is quite a complex process,often occupying whole lifeЛИЛИЯ-Р wrote:
Runny nose and constant "pokalyvanie" indicates a problem with theenergy kidney,kidney qi. of course,then it is projected onto the physical body... the deficiencies of kidney qi says:
the most primitive thing to do-is not a lot of salt or colestyramin products and adjust their energy behavior. after all "breakdowns" and "damage" is our interaction with ourselves. Traditionally, the regulation is subjected to sexual life. With Emotions will be more difficult...<Soreness and weakness of lower back, weakness of knees, frequent urination transparent light urine, weak stream urination, abundant urination, urine drops after urination, incontinence of urine, enuresis, urination at night, nocturnal emissions without dreams, premature ejaculation, spermatorrhea, prolapse of the uterus in women, chronic vaginal discharge of white color, fatigue, pulling down sensation in lower abdomen, recurrent miscarriage, feeling cold, cold extremities.
Re: ASD-fraction 2
the most primitive thing to do-is not a lot of salt or colestyramin products and adjust their energy behavior. after all "breakdowns" and "damage" is our interaction with ourselves. Traditionally, the regulation is subjected to sexual life. Emotions,depressing the kidneys will be more difficult...Нетрезвый Сурдопереводчик wrote:The doctors are now "eager to cut". to prescribe Sumamed 5-month-old girl. I have this doctor would have killed with his bare hands. If you are dry mouth,it jumps insulin. in principle many things can be changed in the method of supply. nobody's really campaigning for a raw food diet,but you can adjust your insulin by simple methods supply with products that you can find in any store. causes of runny nose really different. Is rhinitis,a disease more dangerous than it usually think.Sometimes sinusitis-sinusitis. This sore is more related to the implementation of our Set of Necessary things in Life(Dharma) and the quality of the acts. As a rule,this disease comes from someone who has done some irreversible action in relation to its structure,it is very similar to HIV. The cold causes the dominant emotion(lack of recognition by others in society,pride,conceit, etc.) that emerge from the dominant passions,which subtly exists in the mind of each person. We should not think that this very Passion can be removed,or just having cried after listening to MM about two weeks. It is quite a complex process,often occupying whole lifeЛИЛИЯ-Р wrote:
Sumamed , strong antibiotic, so by not knowing I almost ruined the gastrointestinal tract daughter, who was only 5 months, wrote it in the TCG. d. clinic. Then very problematic to restore the flora. And it was just cold and temperatures-reaction to prorezalsya teeth...Causes of common cold are different. Amicii too whiny snot(sorry) coming out and as a consequence are deposited in the kidneys ( fears and depressed tearful) . So what about kidney ...somewhere probably correctly - to remove extra liters ...but what if the manure is used in high quantities , then again ...blood sugar, early onset diabetes, then and the dryness can be and other reasons. Well ...snot is better than all the rest of" evil" , it's the least if much is lacking. Gasolin and naftisin is not a solution..strong addictive to it."Cold" happens when people neglect their Ayurvedic Constitution. For example,the human body is dominated by "water" component in the tissues,joints,in the energy system("Yin"), and so it "crushes" the original Yang-qi of the kidneys,and he having read "leaves from healthy" eating (powdered)milk gallons and fibrous abusing "sirtinol". here,for example I,according to my machine,almost nothing to eat. Don't eat dairy,not all fruits...you can count on one hand the foods that I eat. I have Pitta-Vayu predominates. This means that I have no shortage of "digestive fire",I don't need to step up,as is done in the beginning of the session ,say,qigong. From this I have threatened joints ,my structure formed around the abdomen,and in spite of the meager diet,I always look like I dine buns
Runny nose and constant "pokalyvanie" indicates a problem with theenergy kidney,kidney qi. of course,then it is projected onto the physical body... the deficiencies of kidney qi says:Soreness and weakness of lower back, weakness of knees, frequent urination transparent light urine, weak stream urination, abundant urination, urine drops after urination, incontinence of urine, enuresis, urination at night, nocturnal emissions without dreams, premature ejaculation, spermatorrhea, prolapse of the uterus in women, chronic vaginal discharge of white color, fatigue, pulling down sensation in lower abdomen, recurrent miscarriage, feeling cold, cold extremities.
Re: ASD-fraction 2
Also started taking ASD 2. there is a movement...about the kidney all true...I was so. Even the kidneys is fear and oppressed due to this, will...I started to work - is the result of...http://www.consmed.ru/lekarstvennye-sre ... iew/62645/ here people share their experience with ASD. Can someone come in handy.
Re: ASD-fraction 2
It's yours - I have one friend cured of tuberculosis.Россомаха wrote:And hunting people to take this stuff.
There are times when the taste value almost does not matter.(under the heavy threat of life, for example...)
Re: ASD-fraction 2
There are drugs far more effective, but not so nasty to taste and smell. ASD for necrophilia thing.АндрейКо wrote:there Are times when the taste value almost does not matter.(under the heavy threat of life, for example...)
